Old Apr 18, 2011, 12:25 PM
Spain, Aragón, Huesca
Joined Apr 2011
Thanks once again Willy.
Pleased to hear that Snoopy was OK after his adventure.
I have 1500mah and 1800mah 3S lipos which I believe would be perfect for the plane. I also have a DX6i Tx, RX's, and suitable servos etc.
My only concern is finding a suitable motor because if I buy this plane I will want to mount the motor inside the fuselage.
Would like to see the pics of your set-up.
artisan.
artisan23 is offline Find More Posts by artisan23
Old Apr 18, 2011, 02:24 PM
willy163's Avatar
Italia, Piemonte, Strambino
Joined Feb 2010
artisan.
Hi!
This is my motor.
Here are pics
You can see motor points down. Otherwise plane will go up very fast with throttle.
Through air hole, you can see white motor mount and "L" shaped metal support (built by myself)
A lot of damages caused by crashes: this is the plane I've learnt to fly with.
Inside you can see motor mounting and "L" shaped metals.
Willy.
PS: sorry for my poor english: I'm Italian
willy163 is offline Find More Posts by willy163
Old Apr 18, 2011, 03:39 PM
Joined Apr 2011
Thank you very much Willy. You have been very kind and helpful.
Now I can see that a brushless outrunner of up to 28mm diameter can be fitted with some small modifications. Thus, I should be able to order everything from one place here in Spain.
No need to apologise for your English, it's very good. i have lived in Spain for 4 years and my Spanish is much worse than your English.
Un saludo.
Artisan.
Old Apr 18, 2011, 04:42 PM
willy163's Avatar
Joined Feb 2010
no need to apologise for your english, it's very good. I have lived in spain for 4 years and my spanish is much worse than your english.
Un saludo.
Artisan.
ciao!
Old Apr 21, 2011, 08:18 AM
Joined Apr 2010
Are you running stock electronics or have you converted to a brushless set up? If so, any pointers to a good motor/esc combination that will work with 3S lipos and fit into the nose of the fuselage.
I'm still flying mine! I used it as standard for a while, and it does actually fly OK on the standard brushed motor and NiMH pack. Finally my NiMH battery exploded in mid-air. Since I had to do some repairs, I also made some modifications while I was at it.
I went for a crude and simple motor conversion, putting a bell outrunner on the front.
I had to repair the wing, so I scrapped the poor torque-tube arrangement in favour of separate 5g servos in the wing ...
I use a 1300mAh 3S Lipo, which needs to go right forward into the nose, because the brushless motor is so much lighter than the original brushed motor.
Good luck with yours .... Tony S
aesmith is offline Find More Posts by aesmith
Old Aug 09, 2011, 06:17 AM
Romania, IS, Iași
Joined May 2011
I have a Soaring Eagle TW738 that have a Motor: 390A and a 30A brush ESC.
I just burn my motor and I am searching for a replacement .
Weight is 600g
using a folding prop 6.5x4
thank you in advance.
ccatalin is offline Find More Posts by ccatalin
Old Dec 30, 2011, 04:44 AM
Joined Apr 2004
Bought the newer "Phoenix 742-II" version of this today. Pretty good for $120AU including all gear!
Put it together tonight, hope to fly soon...
Had an easystar a few years ago, that was a great plane I must say.
tyrell is offline Find More Posts by tyrell
Old Jan 17, 2012, 01:37 AM
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
I got a heap of random plane parts from a dude giving it up, so I pulled out my old TW-742 (which I was flying as a beginer, stock) and gave it a new life. Among other stuff I got an unknown motor with its matched ESC (~25A I think), a hand full of 8x4 props and a lighting kit. I am using 2200mAh 3S LiPos. This is the result
It flies wicked, will just hold a short hover, even with its small control surfaces. I am going to put separate servos in the wings, maybe get a larger pitch prop for more speed (I can easily sacrifice some thrust)
sammyc is offline Find More Posts by sammyc
Old Feb 13, 2012, 01:45 AM
Romania, IS, Iași
Joined May 2011
it's private,
please make it public
Originally Posted by Alcyon13 View Post
Here is my new video
http://vimeo.com/13833056
I had a lot of fun this day.
The best parts are not on the video because i didn't have enough battery on my recorder to capture the last flight... Next time i'll do the stunts in first
Old Apr 07, 2012, 07:32 AM
Joined Apr 2012
Hi,
Hi everyone i've recently purchased a skyhawk tw-742 and it's been loads of fun.
I'm new to modal aircraft so i've spent longer on the ground then i would have liked
Crash No. 1 = Broken wing (Fixed)
Crash No. 2 = Broken Prop and rear tail fin (Fixed)
Crash No. 3 = Broken Prop (Fixed)
Crash No. 4 = Motor Stuck on full when battery is connected! I assume this is a damaged ESC, if you agree then does anyone know where i can buy a new one?
Thanks in advance for you time
Richard
Ratio1234 is offline Find More Posts by Ratio1234
Old Apr 09, 2012, 04:20 PM
Donjuanzx9's Avatar
Canada, QC, Stanbridge East
Joined Jul 2010
Test flight FPV Tw-742 with mini camera (7 min 20 sec)
Donjuanzx9 is offline Find More Posts by Donjuanzx9
Old Apr 10, 2012, 01:06 AM
willy163's Avatar
Joined Feb 2010
Richard
I kindly suggest you to upgrade to brushless motor and lipo battery.
Willy.
Old Apr 13, 2012, 06:47 AM
sammyc's Avatar
Joined Nov 2011
Another lease of life for my Sky Hawk
gonna need a big battery to balance it out
Old Apr 26, 2012, 10:26 AM
Donjuanzx9's Avatar
Joined Jul 2010
I found my plane turns very sharp when I want to ..I'm running with a 2200mah 3s battery.
Buzzing The neighbors ! (4 min 24 sec)
Old Jun 06, 2012, 04:44 PM
Yes, I am from Texas.
Joined Sep 2011
Just bought this: http://www.nitroplanes.com/skyhawk.html
Is this the same thing?
TrueTexan is offline Find More Posts by TrueTexan
EDF EPS Global Hawk building thread mrbaseballny Foamies (Kits) 3 Jun 03, 2009 08:51 AM
Discussion Familiar with this Ebay plane? TW-742 Sky Hawk 46'' RTF ace5000 Electric Plane Talk 6 Oct 14, 2007 02:31 PM
Micro Sky Hawk Chopper TERRYG Micro Helis 0 May 06, 2004 10:20 AM
Anybody know the Sky Hawk ? MTT Thermal 0 May 04, 2004 11:36 AM
Who makes Firebird/E-Gull/Sky Hawk,Vector, Wave??? emarkay Parkflyers 3 Apr 12, 2002 10:22 AM
