Old Nov 14, 2015, 10:31 AM
bergfalke4 is offline
Find More Posts by bergfalke4
Germany
Joined Apr 2003
Question
Build box for transportation
Hi!
How do you protect your fragile indoor models when you bring them to the gym/venue where you fly? When it's windy outside I find it very difficult to carry a lightweight model without damaging it. On several occasions I have had control surfaces blow off or damaged hinges, even when I parked my car just outside the doors and tried to be as careful as possible.
I tried to build a wooden box for transportation, but it did not turn out very well. Would love to see pictures and descriptions of how to build something appropriate!
Cheers,
bergfalke4 is offline Find More Posts by bergfalke4
Old Nov 14, 2015, 06:30 PM
Vince Caluori is offline
Find More Posts by Vince Caluori
United States, WA, North Bend
Joined Dec 2002
I have had the exact problem as you. So i built a "coffin". It turned out too big to fit in my car so a friend finished it. here are some photos. 1 inch foam board for insulation ,glue and tape.
Vince Caluori is offline Find More Posts by Vince Caluori
Old Nov 15, 2015, 05:15 PM
Free is offline
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
Here are some photos of my box I checked under a plane when I went to OH. Worked perfectly.
I also made a smaller box of cardboard and foam and that works great for car trips.
Free
Free is offline Find More Posts by Free
Old Nov 15, 2015, 06:09 PM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Making the box is one thing, the other is how you secure and locate the model inside the box.
Try to keep it light, and also make sure there is no way it can come loose.
You don't need much at all to hold the model in place because it is so light.
Even a piece of foam like Free is using can just about destroy a model if it comes loose.
One of our guys found this out the hard way when we went to Poland last spring.
When we opened the box we were too shocked to take a picture. The foam holding the wing on one side had come loose from the box but was still attached to the wing.
The model was folded in half, one wing tip touching the tail . Took two days and a lot of work to get it flyable, but it was never quite right.
Coroplast is pretty good for making a box if all you want to do is get in and out of the place you are flying. Duct tape and hot melt to hold it together.
Pat MacKenzie
pmackenzie is online now Find More Posts by pmackenzie
Old Nov 15, 2015, 06:15 PM
Free is offline
Free's Avatar
Joined Jan 2012
Yes, I see how that would happen.
Some of the foam did come dispatched during transportation, but because my model was a brick, it didn't do any damage.
I will look for better ways of securing my model next time I travel.
Free
Old Nov 16, 2015, 01:17 PM
Germany
Joined Apr 2003
Looks good!
How thick was the plywood you used? Did the box come out very heavy?
,David
Free
Old Nov 16, 2015, 01:23 PM
Germany
Joined Apr 2003
Interesting solution! Especially the idea with duct tape to hold it all together. My problem is that I can't source foam board locally. I once tried to laminate thick paper and thin 20 mm foam sheets to build a box. However, as the glue dried the foam would warp... 20 mm foam sheets are cheap but it ding very easily.
Old Nov 16, 2015, 02:07 PM
Free is offline
Free's Avatar
Joined Jan 2012
I used duct tape just to keep everything smooth but it wasn't necessary structurally.
Free
Question Transport box 160x30x20 for F3B glider roth_georg Flight Accessories 2 May 15, 2014 11:29 AM
Discussion Transport box 160x30x20 for F3B glider roth_georg Sailplane Talk 1 May 12, 2014 10:53 AM
Mini-HowTo Tips for How to Make a Finished Airplane Storage/Transport Box Chophop The Builders Workshop 17 Oct 13, 2013 07:59 PM
