Old Nov 07, 2012, 02:21 PM
mikes68charger is offline
Find More Posts by mikes68charger
Why kamikaze pilot wear helmet
mikes68charger's Avatar
United States, IL, Rock Island
Joined Jul 2010
Balsa USA NorthStar water profing
OK, I really wanted a boat plane, and just pick up a used Balsa USA NorthStar from a guy.
He converted it to electric, useing 5000mah 6s lipo with HK motor.
I have to say this bird rocks! I have never had a duel / muiti purpuse bird before and Im additicted
I have flown it off the grass now a few times to get everthing right, and Im thinking this or next weekend of trying it on the water
So I need to know how dose one water prof these boats are do you even?
The rudder rod would be under water, what and how do you get gress in there?
Do you put tape over you top hach cover to cover all seems?
Or is it just consider a wash if she flips over?
Thanks Mike
mikes68charger is offline Find More Posts by mikes68charger
Old Nov 07, 2012, 07:36 PM
Jim Stepp is offline
Find More Posts by Jim Stepp
Grumman Flyer
Joined Jul 2012
Hi Mike,
The Northstar is designed so the back end of the control rods are under water but the front ends are above the waterline. As long as there is a good seal between the pushrod tube and the fuselage side it should not leak. I built mine with lots of silicone inside the hatch so it doesn't leak. If it doesn't seal well you should tape it. Good luck. I plan to fly mine Saturday weather permitting.
Jim
Jim Stepp is offline Find More Posts by Jim Stepp
Old Nov 08, 2012, 06:05 PM
kingsflyer is offline
Find More Posts by kingsflyer
We shall serve the Lord
kingsflyer's Avatar
United States, TX, Kingsland
Joined Sep 2005
You should consider treating all of your electonics with CorrosionX before you fly off water.
http://www.rejex.com/corrosionx.html
It's not a question of "IF" water will get in or on your receiver and ESC, it's only a question of "WHEN" it will get in or on them. Remember, Murphy loves water planes.
McD
kingsflyer is offline Find More Posts by kingsflyer
Latest blog entry: LEDs on my T-28
Sold Balsa USA Northstar BNF plasticjoe Aircraft - Electric - Airplanes (FS/W) 6 Oct 26, 2012 08:01 PM
Discussion Balsa USA Northstar matthew954 Fuel Plane Talk 8 Jan 26, 2011 11:08 AM
Sold Balsa USA NorthStar kit Biper/Piper Aircraft - Fuel - Airplanes (FS/W) 0 Apr 29, 2009 01:25 PM
Wanted Balsa USA Northstar plumberdeluxe Aircraft - Fuel - Airplanes (FS/W) 4 Dec 19, 2008 11:04 AM
