Old May 31, 2008, 12:04 PM
Hemmi is offline
Find More Posts by Hemmi
Raleigh, NC
Joined Mar 2008
Servo Twitching! Bad ESC?
I burnt up a motor due to excessive heat casued by a loose magnet. The ESC did get real hot, because it melted loose from the hot Glue holding it on. I replaced the motor, and not I git the wierd twitching of the servo and motor as soon as I power on the transmitter, but it stops after I cycle the controls.
I'm just wondering if the ESC is damaged. I dont want to find out at 300ft. Anyone ever seen an ESC causing twitching?
Also the reciever was involved in a crash, but it was not even scratched, so I dont think thats it.
Please help
Hemmi is offline Find More Posts by Hemmi
Old May 31, 2008, 12:54 PM
Hopalong X is offline
Find More Posts by Hopalong X
Geaux Saints
Hopalong X's Avatar
Grafton, Il
Joined Nov 2007
TX is first on last off!
You should be turning on the Tx BEFORE plugging in the airplanes batterry.
There can't be twitching of servos etc. when you turn Tx on if there is no power to the plane.
Turn Tx on.
Then plug battery into plane.
Let us know what happens then.
Also
Disconnect airplane battery 1st. Then turn Tx off when finished.
Hopalong X is offline Find More Posts by Hopalong X
Old Jun 01, 2008, 11:53 AM
max jones is offline
Find More Posts by max jones
lawton,ok
Joined Dec 2007
[QUOTE=Hopalong
Also
Disconnect airplane battery 1st. Then turn Tx off when finished.[/QUOTE]
hopalong , of course, is right, and you probably are aware of that, but from my experience, it COULD be an esc problem. Al
max jones is offline Find More Posts by max jones
Old Jun 01, 2008, 12:23 PM
thewz is online now
Find More Posts by thewz
"It's a Quad" :O
thewz's Avatar
Temecula
Joined Jul 2004
As others have said always turn on the Tx first. That'll cure a lot of the initial twitches.
If it is still twitching there are a number of things:
You are getting interference
Your Rx crystal is loose
Your Rx is bad
Your ESC's BEC is not providing the correct current (or one of your servos is damaged or binding)
thewz is online now Find More Posts by thewz
Old Jun 01, 2008, 05:11 PM
Hemmi is offline
Raleigh, NC
Joined Mar 2008
Your Rx is bad
Shouldn't I not get interfernece on a 2.4ghz system?
Old Jun 01, 2008, 05:25 PM
thewz is online now
"It's a Quad" :O
thewz's Avatar
Temecula
Joined Jul 2004
Well...I didn't know that....
So that rules that out and a bad crystal.
Are any servo's binding?
Try pulling the red wire from the ESC (don't cut it just pull up the little plastic tab and slip it out of the plug. Now use a regular onboard Rx battery (4 AA cells) to power the system. This will ruleout the BEC.
You may want to rebind the Rx if the above test produces no different results.
Old Jun 01, 2008, 07:05 PM
Xpress.. is offline
Find More Posts by Xpress..
Hitec RCD CSR
Xpress..'s Avatar
United States, CA, Alpine
Joined Oct 2007
No, no. 2.4ghz systems also get interferance, just read some of the threads on the manufacturers pages. Also, just be sure to turn your radio on before you turn your plane on. Visa versa when you turn everything off.
And did you bind the receiver too?
Xpress.. is offline Find More Posts by Xpress..
Question bad servo frys 1 esc, and almost another topforce Radios 2 Jan 30, 2004 11:58 PM
4 servo BEC . bad news JensJakob68 Electric Plane Talk 2 Dec 11, 2001 06:07 PM
Servo Twitching/Glitching.. soholingo Beginner Training Area (Aircraft-Electric) 5 Dec 10, 2001 11:44 AM
Servo twitching? Josh C Foamies (Kits) 3 Jul 18, 2001 02:14 AM
Bad ESC??? Steve-S Electric Plane Talk 6 Jun 02, 2001 07:58 AM
