Old Mar 19, 2007, 04:11 PM
bobthefish50 is offline
Find More Posts by bobthefish50
bobthefish50
United States, OR, Salem
Joined Jul 2006
Side Slipping A Model Sailplane
I have read that full-scale sailplane pilots use this maneuver.
Do model sailplane pilots? How is it done? Does it require 3-axis control?
Thanks for sharing the information.
Bob
bobthefish50 is offline Find More Posts by bobthefish50
Old Mar 19, 2007, 05:31 PM
Esprit2 is offline
Find More Posts by Esprit2
Minnetonka, Minnesota, USA
Joined Jan 2005
Models can slip too. Just roll it one way and appy rudder the other way (cross-controlled). Slipping kicks the plane around a little sideways to the direction of flight, creating a lot of drag. It's a way of slowing it down or steepening the decent of a plane not equipped with flaps or spoilers. If you have either of those control options, use them... they're more effective.
Good rudder authority is required. Longer wing spans are harder to horse around with the rudder, so slipping is relatively less effective with longer wings.
Tim
Esprit2 is offline Find More Posts by Esprit2
Old Mar 19, 2007, 05:46 PM
bobthefish50
Joined Jul 2006
Thanks, Tim. Do you use any elevator?
Bob
Old Mar 19, 2007, 06:31 PM
Phoebusflyer is offline
Find More Posts by Phoebusflyer
Full Scale Better! UOHHHH!
Phoebusflyer's Avatar
United States, TX, Lytle
Joined Dec 2006
You're going to have to do this with a plane with ailerons, rudder and elevator. I don't believe you can do this with one equipped with RES.
Phoebusflyer is offline Find More Posts by Phoebusflyer
Old Mar 19, 2007, 08:02 PM
LVsoaring is online now
Find More Posts by LVsoaring
Unrepentant Paragon addict
LVsoaring's Avatar
United States, OK, Moore
Joined Jan 2006
Phoebusflyer is correct, you need 3 axis control. By it's very nature, and the way wings are banked with a RES ship, RES won't do it. As for elevator, it still functions as normal, controlling nose up or down attitude.
LVsoaring is online now Find More Posts by LVsoaring
Old Mar 19, 2007, 08:48 PM
bobthefish50
Joined Jul 2006
My understanding of sideslipping is that the nose is perpendicular to the direction of the aircraft, i.e., the belly of the plane is where the nose should be. Thus the entire fuselage and wing bottoms are creating drag, correct?
If so, I would think that the components of the manuever would be
1) Bank
2) Maximum elevator
3) Rudder in a direction opposite to that of the bank as was noted.
However, what has been reported suggests that the elevator isn't as important as the rudder. Do I understand that correctly?
Thanks.
Bob
Old Mar 19, 2007, 08:58 PM
seanpcola is online now
Find More Posts by seanpcola
USA, FL, Pensacola
Joined Sep 2004
I watch full scale gliders weekly and seldom see it used. Though it does have it's time and place, it is not as effective as in power planes, all things being equal. Sailplanes, while having generous wing area, do not provide much side plate area. It is a neat trick, and does help in some situations but as mentioned in previous posts, in our particular applications, spoilers, flaps and their variations work much better. I have tried it pretty often with full house stuff and I have seen no benefit other than looking way cool on scale gliders!
seanpcola is online now Find More Posts by seanpcola
Old Mar 19, 2007, 09:23 PM
Joined Dec 2006
Slipping works much better in full scale on the older, more slab sided planes. The newer glass ships benefit from it much less. I would think a full house 3 or 4 meter ship would see little benefit from it especially some of the newer, low profile ships.
Old Mar 19, 2007, 09:28 PM
Darold Lobb is offline
Find More Posts by Darold Lobb
dlobbster
Snohomish Washington
Joined Oct 2006
Technically there are two different kinds of slips. A forward slip is used
for loseing altitude fast and a side slip is used for landing in a crosswind.
In a forward slip the fuselage is crabbed slightly diagonal to the runway
with one wing low and the rudder used to keep the aircraft heading
straight down the runway. In a side slip the wing on the crosswind side
is lowered just enough to offset the force of the crosswind and rudder
is used to keep the fuselage parallel with the runway. Haveing said all
that, I agree that flaps or spoilers are easier and more effective on an
RC sailplane.
Darold Lobb is offline Find More Posts by Darold Lobb
Old Mar 19, 2007, 09:34 PM
schrederman is online now
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
If you do try it, and have ample side area to make it work, you will need some down elevator to keep the airspeed up. Any way you add drag slows the ship down. A 2-33 or a Blanik will benefit nicely from a slip. My PIK or Allen's Phoebus won't be nearly as draggy. The pencil thin fuselages of most of the F3B and F3J models would almost be useless as drag devices... just my take on it.
Jack
schrederman is online now Find More Posts by schrederman
Old Mar 21, 2007, 03:47 PM
bobthefish50
Joined Jul 2006
Thanks, guys.
For a great story about sideslipping a 767 that had run out of fuel, check
http://www.casa.gov.au/fsa/2003/jul/22-27.pdf.
Bob
Old Mar 21, 2007, 05:12 PM
histarter is offline
Find More Posts by histarter
Permanently Banned
Dallas TX
Side area
Jack
I was more concerned with anti slip! Trying to nail a spot with small yaw angles using a regular Legionair was difficult; whereas, using the Shuttle (Legionair) fuse with it's 'billboard' sides made it a lot easier.
To get into small feild construction sites that were supplied/serviced by a Cessna 175; my T'Craft with repair parts, had to use the forward slip frequently. Hard aileron, rudder to kill off 55 mph aproach speed, then settle down onto 3 points (actually the tailwheel would be rolling first). Take off was usually 3 points also (rough feild automatic liftoff at 45 mph).
histarter is offline Find More Posts by histarter
Old Mar 21, 2007, 06:59 PM
David Forbes is online now
Find More Posts by David Forbes
David Forbes's Avatar
United States, FL, Gainesville
Joined Dec 2005
Bob,
That link was fascinating, thanks for sharing.
Dave
David Forbes is online now Find More Posts by David Forbes
Old Mar 21, 2007, 08:39 PM
equest is offline
Find More Posts by equest
Questio scientia
equest's Avatar
Texas
Joined Apr 2003
Take a look at this. Slide slipping to the extreme. A good visual representation to those that do not understand what it looks like.
Equest
equest is offline Find More Posts by equest
Old Mar 21, 2007, 09:14 PM
IwantaJet is offline
Find More Posts by IwantaJet
Laughs at his own jokes.
IwantaJet's Avatar
Missoula, Montana, United States
Joined Feb 2002
IwantaJet is offline Find More Posts by IwantaJet
Question Designing for side slipping rcav8r2 Modeling Science 5 Aug 11, 2007 06:51 AM
Discussion Lipo battery monitor- only 5 grams, 1/16" thick and sticks on the side of your model SSG Scott Batteries and Chargers 0 May 20, 2006 11:45 PM
Two Model Sailplane Winches for Sale Seth Aircraft - Sailplanes (FS/W) 6 Apr 15, 2004 09:58 PM
