Old Jun 17, 2015, 05:57 PM
dontrinko is offline
Find More Posts by dontrinko
Joined Nov 2013
Cox 020 fuel leak fix?
i got another ebay engine, froze up , fuel line plugged ect. (Cox 020)
I got it running but there is a small fuel leak between the back and the tank. I do not see any gasket. Any ideas to stop this leak?
It runs about 1 min 30 seconds if i start it quick . I have tightened the 4 screws and that helped some. Thanks; Don
dontrinko is offline Find More Posts by dontrinko
Old Jun 17, 2015, 08:46 PM
Balsaworkbench is online now
Find More Posts by Balsaworkbench
A man with a plan
Balsaworkbench's Avatar
United States, MO, Osceola
Joined Nov 2014
There's supposed to be a gasket between the crank case and the tank. You could make your own. Take it apart and put a very thin coat of oil on the rear of the crank case. Press the crank case on a regular sheet of copy paper to leave an impression. Cut out the gasket with an X-Acto knife. Reassemble the engine with the gasket, and it will probably run better.
Balsaworkbench is online now Find More Posts by Balsaworkbench
Old Jun 17, 2015, 08:53 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
IIRC there is only a gasket in the middle, around the intake tube. Nothing between the OD of the tank and the rear plate.
There is a paper gasket between the tank and the crankcase. The outside edges of the "ears" can rip, then the tank will leak.
See pictures here:
http://www.coxengineforum.com/t3175-...e-missing-part
You can get the overhaul kit that includes both gaskets from Cox international
http://coxengines.ca/cox-.020-pee-wee-overhaul-kit.html
pmackenzie is offline Find More Posts by pmackenzie
Old Jun 18, 2015, 06:49 AM
Joined Nov 2013
Thanks. It is leaking by the back plate. It could be from around the screws, I am not sure.
I put a little gasket cement between the tank and the engine and that fixed that leak.
i did put a different back on from another 020, earlier version from the photos i have seen.
Don
Old Jun 18, 2015, 08:39 AM
proptop is offline
Find More Posts by proptop
Airplane Gearhead
Central N.Y.
Joined Jan 2005
Sometimes the backplate distorts around the screw holes, and can crack just under the screw heads...fuel will leak from under the screw heads...especially if those tiny screws have been a bit over-tightened...
Done that (over-tightened) a few times myself, many moons ago whwn I was a kid and didn't realize...learned the hard way...
proptop is offline Find More Posts by proptop
Old Jun 18, 2015, 08:51 AM
Joined Nov 2013
I'll check by the screws. I'll put a tiny amount of gasket cement under each screw. Thanks; Don
Old Yesterday, 05:15 AM
Dave Campbell is offline
Find More Posts by Dave Campbell
United States, MI, Commerce Charter Township
Joined Dec 2000
Make sure you debut the threaded holes in the crank case, sometimes they prevent the tank from sealing.
Dave Campbell is offline Find More Posts by Dave Campbell
Old Yesterday, 07:48 AM
Joined Nov 2013
Thanks; Don
Off Site New Cox Pee Wee .020 & Tee Dee .020 on eBay hlnpgr Aircraft - Fuel - Engines and Accessories (FS/W) 0 May 09, 2015 08:19 PM
Discussion Cox TD .010 & .020 Fuel Question Nicksbbq 1/2A Planes 7 Feb 11, 2014 11:04 PM
Discussion cox 020 fuel nipple broke off flying scrap Engines 10 Dec 03, 2012 10:17 AM
Wanted Cox TD .020 fuel tanks? RocketRob Aircraft - Fuel - Engines and Accessories (FS/W) 3 Feb 05, 2009 06:49 PM
Question Help fix OS 40 Carb fuel leak. Pics inside darmiejr Engines 9 Jan 22, 2004 05:28 PM
