Old Apr 28, 2015, 09:58 AM
triibutu is offline
Find More Posts by triibutu
Estonia
Joined Dec 2006
FlySky / Turnigy iA6 (not iA6B) voltage telemetry mod
Since I haven't seen this anywhere else yet, here's a relatively easy mod to enable the cheap and light iA6 receiver to monitor flight battery (or any other) voltage instead of the RX own regulated power and send that back to the i6 or i10 TX.
On the first pic is the ADC input circuit for the RX voltage telemetry, it's a 1/10 (I suppose, mine is more like 1/11, the resistors being 47,1k and 4,77k) voltage divider and is connected to the + pin of channel 1. The + pins of all channels are connected together on the other side of the PCB, all that's needed is to separate the voltage input from the rest. Remove the cover, wiggle the plastic spacer off the pins and just cut the trace between the two pins like on the second pic.
Now, instead of that useless RX voltage from the BEC, you can have some other voltage sent back to the TX and displayed on the screen without any additional sensors.
I tested this with 3S battery (up to 12,6 volts) and the i6 TX displays it nicely, but I don't know what the real upper limit is. RX voltage alarm works fine too, the only small problem is that the i6 TX will let you set RX battery level up to 10.0 volts and the alarm can only be set up to 9.8 volts. If that is not suitable, it's possible to reduce the telemetry voltage by half by connecting a 51k series resistor with the voltage input, only have to remeber that the displayed voltage is then half the battery voltage, but you can set the alarms more freely (I have mine set to 5,4V, which then means 10.8 volts flight battery voltage).
triibutu is offline Find More Posts by triibutu
Old May 01, 2015, 02:37 AM
Denis Poulain is online now
Find More Posts by Denis Poulain
France, Aquitaine, Pau
Joined Oct 2014
Very interesting your modification !
I wonder if it is possible to modify iA6B in a same manner.
I am using iA6B because the receiver range is better. Add a sensor for it is not very expensive, but it adds wires and plugs... It would be better if TGY iAxx receivers had be designed to support a plug for the main battery. You are right in your concept !
Denis Poulain is online now Find More Posts by Denis Poulain
Old May 01, 2015, 08:40 AM
triibutu is offline
Estonia
Joined Dec 2006
It seems possible to mod iA6B the same way, but it's not easy and requires some decent SMD skills. The ADC input is on the PCB and not easily accessible near the servo pins. Since the PCB and components are very tiny, it's probably beyond most people's abilities.
Old May 02, 2015, 08:45 PM
FutureX_ACE is offline
Find More Posts by FutureX_ACE
FutureX_ACE's Avatar
Singapore, Singapore
Joined Sep 2014
So after cutting the trace i can jus connect the pins of say mayb channel 6 to tbe flight battery? Or is there another step? Thx
FutureX_ACE is offline Find More Posts by FutureX_ACE
Old May 03, 2015, 01:49 PM
ahamerh is offline
Find More Posts by ahamerh
Joined May 2015
Hello, I'm about to do this mod and see.. But one question I have.. Once you break the link , where does the servo for Channel 1 get it's power supply from? Or is there something I'm not understanding.. Sorry if it's a stupid question but my first RC
ahamerh is offline Find More Posts by ahamerh
Old May 03, 2015, 04:25 PM
triibutu is offline
Estonia
Joined Dec 2006
No. Only the middle pin of channel 1 will become voltage sensor input, all the rest remain as they were. So if you connect flight battery to channel 6 and this flight battery is >2S, you will have the excuse to buy some new electronics.
Well, servo 1 will have to get it's power from somewhere else then, so you'll need to get creative with the wiring a bit.
Old May 03, 2015, 04:34 PM
ahamerh is offline
Joined May 2015
Ok, I did it and yes it does read the voltage correctly from Channel 1, center pin.
I guess if you want to still use channel 1 to drive a servo, you need to power the servo from one of the other channels instead by splicing it in.
Old May 03, 2015, 04:49 PM
triibutu is offline
Estonia
Joined Dec 2006
Correct.
Old May 04, 2015, 03:28 AM
ahamerh is offline
Joined May 2015
Wiring diagram for TGY-iA6 power sensor mod
Here is the wiring after I did the mod suggested by "triibutu"
I've also taken a reading with a volt meter and there is a little bit of a difference from actual battery voltage to reported voltage.
I will probably also add the 51k Ohm resistor in series to the sensor input on channel 1 to halve the voltage so I can use the alarm function on the remote.
Would be nice if there was a new FW for the i6 TX to allow us to use a higher voltage for alarm setting rather than the 10v max.
Old May 04, 2015, 06:16 AM
triibutu is offline
Estonia
Joined Dec 2006
My guess is the resistors in the original voltage divider are not very accurate to begin with.
Also the 51k may need to be adjusted if you want to get more accurate readings. I just used a 100k linear pot and trimmed it until the TX display matched half of the real voltage, then measured the resistance and replaced the pot with close enough fixed resistor.
Old May 04, 2015, 09:09 AM
ahamerh is offline
Joined May 2015
I just came back from the first test flight with the new setup.. I set the alarm as high as it could go on the remote and as soon as I got the alarm I probably had about 30s of flight time left.. Flaps out and landed
So the fact that the sensor is under-reading the voltage was good, but I think adding the resistor is the final solution.
Old May 16, 2015, 12:18 PM
Joined Oct 2014
Multiple alarms for TGY-i6
I agree !
And it would be nice too if a new firmware adds the possibility to have multiple alarms : for example one for the voltage sensor of the iA6B or iA10, one for the feedback sensor data from RX (Err 1 - Rx error percentage ?), and I imagine one for a temperature sensor, etc...
Old Jun 04, 2015, 04:50 PM
djdazzy is offline
Find More Posts by djdazzy
United Kingdom, Leics
Joined Dec 2005
Excellent work Triibutu.
I think the voltage divider is supposed to be a 11:1 ratio, the nearest standard resistors are 4.7k and 47k.
The hidden menu has a TX battery calibration menu option, I am not sure if that also influences the RX voltage display.
djdazzy is offline Find More Posts by djdazzy
Old Jun 21, 2015, 03:38 AM
DarekW is offline
Find More Posts by DarekW
Joined Jun 2015
Works for me, thanks for Triibutu ;-)
DarekW is offline Find More Posts by DarekW
Old Jun 28, 2015, 09:51 PM
99yellowgt is offline
Find More Posts by 99yellowgt
99yellowgt's Avatar
Modding the IA6B as well
Hi all, haven't posted in a very long time but I thought I would add to this post. this is to mod the IA6B RX so that you can monitor Main Pack Voltage or any voltage without add the TLM Modules. Really no need to monitor the Regulated 5.0V from the ESC. If that is bad you are probably going down anyways. Also on the previous mod for the IA6 if you cut the trace between the headers and the resistor and add a wire, you won't have to worry about trying to plug into the servo connections or supplying the wrong voltage to the rest of the board. Again for fine tuning you could add a 50K pot in this line you added and shot for 1/2 the battery voltage. easier to set the alarms now.
99yellowgt is offline Find More Posts by 99yellowgt
Help! Turnigy 9x telemetry mod with Frsky DJT module( not DIY kit) tongsiup Radios 2 Apr 04, 2015 07:12 AM
Discussion Using telemetry with Flysky i6 : iA6B or iA10 ? Denis Poulain Radios 2 Mar 12, 2015 04:51 PM
Discussion turnigy 9x/ flysky 9x mod to dsm2 problem old82cutlass Radios 1 Mar 20, 2014 12:58 PM
Sold NIB FrSky Telemetry 2.4 module for JR/Turnigy or FlySky 9ch flynut67 Aircraft - General - Radio Equipment (FS/W) 0 Jul 07, 2012 05:07 PM
