Old Dec 10, 2014, 03:23 PM
Shane Sunday is online now
Find More Posts by Shane Sunday
United Kingdom, Northern Ireland, Belfast
Joined Jun 2011
Motor/prop/model size advice please.
Hey guys. I've recently acquired an extra 300 of 74" wingspan and I reckon the all up weight to be I. And around 10 to eleven lbs. my question is this. I have a scorpion 4035 460kv motor that coupled with a 15x10 prop and a 6s lipo should produce 85amps and @ 1700-1880 watts which is more than enough to fly a model of this weight although the recommended prop for this model is @ 18x8 and up. Do you think my setup will be good enough?
If I can get the model to within 11 lbs then it will meet 154 watts per lb. which is suppose to be good enough for aerobatic performance. All oppinions are welcome thanks.
Shane Sunday is online now Find More Posts by Shane Sunday
Old Dec 11, 2014, 02:41 PM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
I have a 71" Xtra Wot (a Chris Foss low-wing sport model that looks a bit like an Extra) that now weighs 10lb 10oz with battery, and used to fly on an OS120AX. It now flies on 12S with a Hyperion ZS-4045/12 motor (Kv=247) and a 16x10 prop, giving me 2028 watts, or 190 watts per pound. That's plenty for me, and in fact I normally cruise around at such low throttle that my amps draw is only around 15A
If you can get 1880 watts out of the motor, then that should be enough for normal "sport" flying.
abenn is offline Find More Posts by abenn
Old Dec 11, 2014, 08:48 PM
Doug Bartley is offline
Find More Posts by Doug Bartley
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
I believe the motor would be fine, but I'd be tempted to run a 16/8 with about the same draw/load. The Scorpion's can be run right on the max edge with adequate cooling, no problem. 150w/lb should be plenty for acrobatic flight. jm2cw Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old Dec 11, 2014, 11:00 PM
scirocco is online now
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
You can probably get the power you need with what is a relatively small motor for that size model, and but you'll be pushing everything hard. And with such a light motor, you'll probably need ballast anyway. I would seriously consider 10s or 12s and pick a much larger motor with Kv to suit the prop you want to use.
scirocco is online now Find More Posts by scirocco
Old Dec 14, 2014, 06:28 AM
Til is offline
Til
Find More Posts by Til
Til
Leeds/Bradford Leeds, Great Britain (UK)
Joined Sep 2004
Got to agree with 10~12S li-po, motor no more than 250 Kv, rated at 60 Amps, will fly just fine. 3000mah battery will give about 6 mins of sport flying, so bigger battery if you want longer flight times.
Til is offline Find More Posts by Til
Old Dec 14, 2014, 08:14 AM
viva_peru is offline
Find More Posts by viva_peru
Oakland township, Michigan
Joined Jun 2005
Hi -
I fly a Vanquish 2M (74" wingspan, about 11 lbs RTF) on a 10S lipo pack (2 5S in series) and a Plettenberg motor with a KV of 220. The prop is a 20x13 and the plane has plenty of power to get through the AMA Advanced sequence.
I believe that the Kv of the motor you have is mismatched for the size of the airplane. Although the watts are there, you would be better off putting that power into a larger prop (16 or 17). If you want to stay with a 6S pack, the motor Kv should be in the 380-400 range. That would allow you to spin a 16" or 17" prop. If you have a lot of 6S packs sitting around, then a motor with a Kv of 180 or so would work if you want to go 12S. Keep in mind that you want to spin a largish prop (17-20" depending on set-up).
Good luck,
Teo
viva_peru is offline Find More Posts by viva_peru
Old Dec 14, 2014, 08:39 AM
RickAvery is offline
Find More Posts by RickAvery
Moorpark, Ca.
Joined Apr 2004
I wouldn't discount an intermediate solution, such as an 8s system. Power 90 , (325kv), on 8s with a 16 - 18" prop will give you the numbers you're looking for without stressing the components. Probably a slightly lighter system with say, 2X 4s 3300-4000mah batts. As mentioned, if you're going to need balast, might as well be in the form of power/battery. If you can achieve balance with a lighter system, that's the road I'd follow. Good luck. Blue skies.
Rick
RickAvery is offline Find More Posts by RickAvery
Question Need advice on pancake motors and large props. Test Pilot Mafia Multirotor Power Systems 2 Nov 14, 2014 03:07 PM
Discussion Motor / Prop / Battery Advice squishio Power Systems 4 Nov 05, 2014 04:13 PM
Discussion Looking for Advice on Direct Drive Tail motor for 700 size scale heli wazzer Electric Motor Design and Construction 3 Oct 24, 2014 05:34 PM
Discussion Newb needs motor & prop sizing advice kdc415 Multirotor Power Systems 3 Dec 16, 2013 08:42 AM
Discussion Prop/battery/ESC size advice please! Diwrnach Electric Plane Talk 16 Oct 12, 2013 10:23 AM
