Old May 25, 2014, 09:08 AM
meerkat13 is offline
Find More Posts by meerkat13
meerkat13's Avatar
United Kingdom, Birmingham
Joined Jan 2013
Question
Pivot Position on an all moving Tail / Elevator
Hopefully someone can help.
Iím designing / building a 30mm EDF Hawker Hunter over on the micro jets forum.
Could someone tell me the correct way for working out the pivot position for an all moving tail plane?
I assumed that it would be on the COG of the elevator as calculated on the drawing below, but you know what they say about assuming Ö
Thanks, Steve
meerkat13 is offline Find More Posts by meerkat13
Old May 25, 2014, 10:04 AM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
A little hard to follow the drawing but it looks like you are identifying the mac there? I would put the pivot at 30% back along the mac then at least partially static balance the surface with a slug of lead in the nose. Although, at this size you can skip the static balancing I suppose .
Chris True is offline Find More Posts by Chris True
Old May 25, 2014, 11:02 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Steve, give this thread a read. Might be of some help?
http://www.rcgroups.com/forums/showthread.php?t=1365315
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old May 25, 2014, 11:49 AM
strictlyscale is offline
Find More Posts by strictlyscale
Dream Build Fly Scale
strictlyscale's Avatar
Philadelphia, PA
Go about 2/3's of the way down this page. Lots of good info.
http://www.ultimate-jets.net/blogs/f...ols-on-rc-jets
Btw, you know the Hunter doesn't have an all flying stab right?
strictlyscale is offline Find More Posts by strictlyscale
Old May 25, 2014, 08:32 PM
turbonut is online now
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
25 to 30 % Mac
turbonut is online now Find More Posts by turbonut
Old May 26, 2014, 07:30 AM
meerkat13's Avatar
Joined Jan 2013
Thanks for the great info and links.
I think you will find that it had elevators on a movable stabilizer. I want to go with a flying stabilizer as it going to easier to setup. I found this and it goes into detail on how the stabilizer functions on the full size hunter - LINK
Question how to install an elevator bell crank in tail of glider xrx1113 Balsa Builders 10 Dec 21, 2013 10:07 PM
News RC Rotors and Aerial Media. An AV Company On the Move. Sleepyc Multirotor Talk 8 Dec 04, 2013 05:01 PM
Help! Flutter on all moving elevator Bad scientist Hand Launch 6 Apr 24, 2011 04:47 AM
Help! Pivot Point on All flying Tail billscottuk Thermal 5 Mar 16, 2009 05:09 PM
Wanted Blaster 2 All Moving Tail (Elevator) pbien Aircraft - Sailplanes (FS/W) 0 Jan 25, 2009 06:30 PM
