Old May 08, 2014, 10:48 AM
steelersfan is offline
Find More Posts by steelersfan
united states michigan
steelersfan's Avatar
United States, MI, South Haven
Joined Aug 2012
converting a glow plane to eletric
hi everyone, i have many nitro planes, never had an electric , im going to convert my carl goldberg eagle 2 with floats to electric (.40 size plane).
my questions are :
what size brushless motor do i need?
what esc do i run with it?
what size lipo battery should i use?
any info will be greatly appreciated , i do have rc crawlers with lipo batteries and do know how to handle them
steelersfan is offline Find More Posts by steelersfan
Old May 08, 2014, 11:06 AM
Xpress.. is offline
Find More Posts by Xpress..
Hitec RCD CSR
Xpress..'s Avatar
United States, CA, Alpine
Joined Oct 2007
First and foremost, what kind of performance would you like out of the airplane? You can setup a power system that is just adequate in flying the airplane or one that will scream into the air in a few feet and roll unlimited vertical.
Xpress.. is offline Find More Posts by Xpress..
Old May 08, 2014, 11:25 AM
Joined Aug 2012
im only looking for something equal to the performance of a .46 glow engine , nothing radical, although it might not hurt to have a little more umf than a .46 engine since it is a float plane
Old May 08, 2014, 11:47 AM
cmdl is offline
Find More Posts by cmdl
Y=C+I+G
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
motor: http://www.e-fliterc.com/Products/De...odID=EFLM4046A (also lists prop, ESC, cell count for batt)
stuff to read: http://www.e-fliterc.com/Articles/Ar...ArticleID=1563
cmdl is offline Find More Posts by cmdl
Old May 08, 2014, 11:49 AM
Joined Aug 2012
thanks for the link, much appreciated
Old May 08, 2014, 12:08 PM
HeeBeeGeeBee is offline
Find More Posts by HeeBeeGeeBee
Lysdexic I'm
HeeBeeGeeBee's Avatar
Spring, TX
Joined Oct 2010
Try these people for a great deal and charts will show you many specs depending on how much power you want (prop size/cell count). This is for the Power Up 46...
http://www.headsuphobby.com/Power-Up...otor-F-586.htm
I'm using this motor with a 80A ESC and a 12 x 8 prop. If you need less power, lower the prop size and/or cell count on you battery
HeeBeeGeeBee is offline Find More Posts by HeeBeeGeeBee
Old May 08, 2014, 12:17 PM
Joined Aug 2012
thanks !
Old May 09, 2014, 12:26 AM
Kimber is offline
Find More Posts by Kimber
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
You should end up with a mess that looks something like this??
http://www.rcgroups.com/forums/showt...highlight=eagl
32 Powerup Sport, 60a hu esc, 4s 5000 with a 4 cell rec pack.
Kimber is offline Find More Posts by Kimber
Old May 09, 2014, 05:05 AM
scirocco is online now
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
Motor size is related to the power you want. For a trainer, an electric conversion should be able to weigh about the same as the glow, so adding floats, assume about 6lb. If it was a landplane, anything over about70W/lb or 400W would be ample (I used to fly a similar size, weight and wing area LT-25 on anything from 300W up). But for a floatplane probably better to aim for about 100 W/lb or 600W.
You can deliver 600W and still get decent flight time from a biggish 3S pack, say at least 4000mAh, but IMO a better choice in this size class and power level will be 4S, and I'd still go around 4000mAh - that's good for for about 8 minutes in my 6.5lb 63" Supercub. If you're worried about weight, you can trade off some flight time by going down around 2700mAh.
600W suggests motors around the 200 gram mark will do OK, although motor size should also be influenced by balance of the model, especially replacing a glow engine with what can be much lighter electric motors. A tiny motor might do the job power wise, but if it's in a tail heavy model a heavier motor running understressed will do the job at lighter all up weight.
Prop size is a critical factor in motor choice. I've seen posts mentioning 11" props, so motors that can run an 11" prop on 4S at approx 600w are the target. At this point you could go play with a motor calculator, or ask a pretty specific question here to figure out what Kv would do the job you need , but as Kimber has suggested a specific motor in an Eagle why not check it out.
Looking at the motor Kimber mentioned, HURC has a table that shows that on 4S 11x5.5, or 11 x7 should do the job well. That motor is very similar to another I would recommend, the Turnigy G32-770. For more thrust (if necessary) you could consider 3 blade 10 or 11" props on that motor, or even 12" 2 blade if enough ground/water clearance.
A 60A ESC with a 3A built in switching BEC like the Turnigy Plush 60 will be about ideal.
scirocco is online now Find More Posts by scirocco
Old May 09, 2014, 09:46 AM
Joined Aug 2012
Thanks for the information I appreciate it everyone
Old May 09, 2014, 09:54 AM
E-Challenged is online now
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Glow to Electric Conversions forum:
http://www.rcgroups.com/glow-to-elec...nversions-247/
E-Challenged is online now Find More Posts by E-Challenged
Sold Moved to eletric planes rickj12 Aircraft - Fuel - Airplanes (FS/W) 2 Feb 23, 2014 11:01 AM
Discussion converting planes from e flight to glow the wiz Fuel Plane Talk 5 Jul 27, 2006 07:29 AM
Question Need help converting new plane from glow to electric. beemer Electric Plane Talk 20 Sep 19, 2005 10:09 AM
Converting electric plane to glow engine Caveman 1/2A Planes 13 Jul 02, 2004 06:26 AM
Question about converting a glow plane. Capslock Electric Plane Talk 1 Feb 14, 2002 11:09 PM
