Old May 07, 2014, 10:58 PM
Crasher248 is offline
Find More Posts by Crasher248
Crasher248's Avatar
Joined Aug 2013
Help!
A simple question
I am currently building a model (first time doing so) and have a small problem...
The brushless motor i am using for it wont work.
It just goes "tick tick tick" but doesn't spin.
I had the same problem with it about a week earlier but it stopped (until now).
Anyone know why this is happening?
Crasher248 is offline Find More Posts by Crasher248
Old May 07, 2014, 11:21 PM
cmdl is offline
Find More Posts by cmdl
Y=C+I+G
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
http://www.rcgroups.com/forums/showthread.php?t=1464822
cmdl is offline Find More Posts by cmdl
Old May 07, 2014, 11:47 PM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
First, if the motor doesn't spin when you try to power it up shut down the power right away.. do not keep trying and don't increase the power. If the motor doesn't spin very high amps will flow and will quickly burn out the motor and/or ESC. If you were giving it lots of throttle and repeatedly trying to get it spinning then you might want to give the motor and ESC a 'sniff' and see if there is burned smell, if so it's most likely toast.
The most likely cause of the original problem (especially if the problem is intermittent) is a poor connection in one of the three wires between ESC and motor. This could be due to a bad solder joint, contaminated or loose bullet connector, or sometimes a wire broken internally.
Sometimes you just get an ESC that wont work with a particular motor, or simply a faulty ESC, but as it used to work these things are less likely.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old May 08, 2014, 01:03 AM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
The brushless motor i am using for it wont work. It just goes "tick tick tick" but doesn't spin.
It might help if we knew what equipment you are using. (motor, ESC, battery, airplane, etc). Links to your equipment are always welcome.
When you say you had the same problem a week ago do you mean that it worked for a while after the first occurrence of the problem?
Is your battery fully charged?
Have you checked the connections between the motor and ESC? A bad connection of a single lead from the ESC to the motor could cause the problem.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old May 08, 2014, 04:14 PM
Crasher248's Avatar
Joined Aug 2013
Glen
well i ripped the parts (servos, ESC, motor, ect.) out of my very first model.
I am not too sure about what kind they are because the model i got em from was just some cheapo Spitfire that was bought from Art Tech (i think) and the motor has no specs printed on it either .
And yes it did happen before this but stopped for awhile.
One plug already came off but i soldered it back so i will check the others to make sure they are not bad too.
Thanks for all the help!
Old May 08, 2014, 04:23 PM
Crasher248's Avatar
Joined Aug 2013
Oops!
That's too bad... I did just about what you said not too.
I wish i knew that earlier. I didn't smell any burnt smell though. hopefully the ESC isn't fried...
I will check the connections now and strip the heat shrinking tubing off.
thank you for the support
Old May 08, 2014, 05:15 PM
gnofliwr is offline
Find More Posts by gnofliwr
aka: A.Roger Wilfong
gnofliwr's Avatar
Novi, Michigan, United States
Joined Jan 2001
If you have a multi-meter (Volt, Ohm, ...) you can do a gross check of the motor connections. You should read the same resistance (a couple of Ohms at the most) between all three pairs of leads. If one is high, that's where to look for a bad connection or broken wire. If you have a drill press, you can use it to spin the motor and read the AC voltage from the windings - they should all be about equal.
If you don't have a multi-meter, you can get an adequate one for less than $25 bucks, on line of at Radio Shack. A multi-meter and a Whatt meter ($25-50) are essential tools that should be in every electric flyers tool box.
- Roger
gnofliwr is offline Find More Posts by gnofliwr
Old May 08, 2014, 06:46 PM
Crasher248's Avatar
Joined Aug 2013
Fixed
One of the three plugs must have had a bad connection, or all cause when i striped the heatshrink from the wire they just fell off.
Very bad design in my opinion.
The plug and the wire weren't even soldered together just held together by the heatshrink.
Would the symptoms of only two of the three wires making a connection be not spinning and doing the "tick tick tick" sound? or would it do nothing at all?
Old May 08, 2014, 06:54 PM
Kimber is offline
Find More Posts by Kimber
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
You have found the problem, you need to solder them on. Be careful not to over
heat the wires going to the motor. A cloths pin will work for a heat sink to block
the heat from the motor.
Remember the first rule of soldering, CLEAN every thing..
Kimber is offline Find More Posts by Kimber
Old May 08, 2014, 07:23 PM
Crasher248's Avatar
Joined Aug 2013
OK thanks!
Old May 08, 2014, 08:00 PM
gnofliwr is offline
gnofliwr's Avatar
Joined Jan 2001
Also, if the leads are simply the winding wires with spaghetti on them, the wires may have varnish on them. If they don't tin easily, carefully scrape the last 1/4" of each wire with some fine sandpaper (I usually use a small piece of 400 folded over) to remove the varnish.
- Roger
Old May 08, 2014, 10:12 PM
Crasher248's Avatar
Joined Aug 2013
- Roger
I read in cmdl's link that he posted above (first post) that you can use aspirin to remove the varnish too. Is that true?
You can use the aspirin trick to take the varnish off. Press the wire down on an aspirin tablet and place a hot soldering iron tip on the wire. It will smoke and stink real bad but the varnish will be removed.
Either way it works i guess.
Thank you!
Old May 09, 2014, 10:49 AM
E-Challenged is online now
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
I would not use Aspirin, the coating on motor winding wires is a tough varnish. Remove it by scraping with an X-Acto but don't cut into the flimsy wire. Use a dab of rosin paste flux on scraped wire. Use 60/40 tin/lead solder for electronics. tin the wire with a clean soldering iron tip and solder. Put a dab of flux in the bullet connector. Install heat shrink tubing away from soldering heat. Place bullet connector in a hole drilled into a block of wood. Apply heat to the bullet connector with clean soldering iron tip and fill the pot with solder, immediately plunge the tinned wire into molten solder in the pot, remove heat, hold wire steady with pliers or tweezer while solder solidifies. Inspect for smooth solder flow at junction of wire and solder pot on connector. You can remove flux residue with alcohol. Good soldering requires practice, watching solder solidify. Done right it should take no more than one (1) second to avoid damaging motor, etc from soldering heat.
E-Challenged is online now Find More Posts by E-Challenged
Old May 09, 2014, 01:07 PM
gnofliwr is offline
gnofliwr's Avatar
Joined Jan 2001
Never heard of the Aspirin trick in 50+ years of electronics (although my master plumber father-in-law did teach me the "bread" trick to keep water droplets from flashing to steam and blowing the solder out of joints while you're soldering them). Given that Aspirin is "acetyl salicylic acid", it should work as a mild acid flux, but I doubt it will remove the varnish any better than just using the iron to burn it off - that's going to be a pretty uncontrolled process.
When ever I can, I shy away from using a knife to scrape the varnish off of magnet wire. There is a good chance that you'll nick the wire and make a resulting mechanical stress point, but others have good luck so your mileage may vary. Other than that, +1 on everything E-Challenged said.
- Roger
Discussion Hobby King refuses to anawer my simple question kev9974 HobbyKing 3 Dec 01, 2013 07:03 AM
Question A SIMPLE Turnigy/Eurgle question :) T_om Radios 13 Nov 12, 2013 01:04 PM
Question (Simple) question about wire gauge? sebbemann Electric Power Cars 2 Nov 06, 2013 08:21 PM
Discussion A few simple questions... Maandeesh Radios 4 Oct 22, 2013 02:25 PM
Discussion Simple question for knowledgeable battery people wkj Batteries and Chargers 14 Sep 28, 2013 02:11 PM
