Old Apr 17, 2014, 04:58 AM
kuki83 is offline
Find More Posts by kuki83
kuki83's Avatar
Poland
Joined Nov 2010
New Product
A New Gimbal DSLR/BlackMagic/RED From Above
We have just finished our new 3 axis gimbal for larger cameras like Black Magic or RED.
Gimbal is designed for professional filming and photographing .
It has many innovative solutions.
Gimbal, among other, stands out its modularity.
Without problem you can mount a long lens and thanks to using standard frame tubes with a diameter of 15mm (15 mm Rod Support ) and spacing 60mm, you can mount the mechanism of focus and zoom.
In contrast to other gimbals available on the market , Gimbal DSLR / BlackMagic / RED From Above has two synchronized motors on the pitch axis . The advantage of this solution is easier mounting and balancing of the camera, because due to the symmetrical, bilateral placement of motors, gimbal weight is evenly distributed, not leaning on so any direction . When the gimbal has one motor, it overloads on the whole device, causing subsidence of one, heavier, side. The use of two motors on the pitch axis maximize the potential of the device. Two motors have similar power compared to one large, but they are lighter. It causes lower weight of the gimbal, which is important when we use it in a flying platforms . Thanks to precise synchronized motors on the pitch axis we can get maximum torque, which allows you to work even with large lenses.
The specially designed vertical arm has place to mount inside the gimbal controller. The arm construction removes heat away from the electronics to the aluminum arm .
Here are some photos of this gimbal:
Gimbal is based on the ALEXMOS 32 bit controller .
Technical specifications:
Weight - 1,6 kg
The materials - aluminum , carbon fiber
The maximum weight of the camera with accessories - 7
Advantages of the Gimbal DSLR / BlackMagic / RED From Above:
1. The high efficiency of the Pitch axis drive.
2. 12 - wire slipring on the Yaw axis.
3. Flexibility in the choice of the camera (GoPro to RED).
4. Possibility of the extension of the tubes allows to mount long lenses.
5. Cables secured in sheaths.
6. By designing a frame for BlackMagic and the RED, camera can be mounted to the upper and lower mounting assembly which improves the stability of the camera.
Here are first tests of this gimbal with Black Magic:
X8 + BMCC (3 min 49 sec)
Octo X8 + 3-axis gimbal 2 (2 min 17 sec)
Octo X8 + 3-axis gimbal (3 min 33 sec)
Tomorrow I'll put few more videos from Black Magic and maybe some more information about our new folding frame.
More news is on our Facebook profile https://www.facebook.com/FromAbovePl
kuki83 is offline Find More Posts by kuki83
Old Apr 18, 2014, 07:06 AM
kuki83 is offline
kuki83's Avatar
Poland
Joined Nov 2010
Today we made some videos with our 3axis gimbal and Black Magic Cinema Camera. You can watch it here:
Gimbal 3-axis - first video with BMCC (9 min 32 sec)
Cool thing about this gimbal is fact that if you use Black Magic it's very easy to pull out the SSD drive without dismantling the camera.
Next photos and videos soon.
Old Apr 23, 2014, 05:56 AM
kuki83 is offline
kuki83's Avatar
Poland
Joined Nov 2010
During the flight I couldn't find a convenient way to fly and simultaneously check the flight parameters.
To make the job easier I made handle for the Ipad.
With this handle, Ipad is attached to the apparatus, I can conveniently fly and I always have all the necessary information in sight.
Old Apr 23, 2014, 02:34 PM
kuki83 is offline
kuki83's Avatar
Poland
Joined Nov 2010
Today we made next video with our gimbal and Black Magic.
On the left is video from GoPro showing how gimbal works, on the right is video from BMCC. I think the stabilization is very satisfying. What do you think about it?
Gimbal 3-axis - with BMCC/GOPRO (3 min 55 sec)
Old Apr 24, 2014, 05:49 AM
alfi666 is offline
Find More Posts by alfi666
Joined Nov 2012
Very nice work. I love the X8 frame too!
Do you manufacture that one too?
Greetings from Slovakia
alfi666 is offline Find More Posts by alfi666
Old Apr 24, 2014, 06:03 AM
kuki83 is offline
kuki83's Avatar
Poland
Joined Nov 2010
alfi666, yes, the frame is our project and realization.
More information about this frame is on my blog: http://www.rcgroups.com/forums/showt...3#post28179102
Old Apr 29, 2014, 03:50 AM
kuki83 is offline
kuki83's Avatar
Poland
Joined Nov 2010
I present you another video made by Gimbal DSLR/BlackMagic/RED. We made it at 6 am, the weather was beautiful, I think the video shows well possibilities of the gimbal
Ropczyce 1 i 1/2 (3 min 43 sec)
Old May 02, 2014, 03:22 AM
kuki83 is offline
kuki83's Avatar
Poland
Joined Nov 2010
For our gimbal we make handgrib too. We were looking for a good battery for handheld gimbal and I think we found it.
This battery stands out from others that it has charge indicator.
It has the protection from excessive discharge, if it's discharge, the power is disconnected automatically.
It's very good solution.
Old May 06, 2014, 02:03 AM
kuki83 is offline
kuki83's Avatar
Poland
Joined Nov 2010
On the photo is gimbal DSLR/BlackMagic/RED with Teradek Clip transmitter, which has some modifications made by us. Thanks to this modifications range significantly increased.
More information about this modifications is in our separate thread.
Old May 09, 2014, 06:55 AM
kuki83 is offline
kuki83's Avatar
Poland
Joined Nov 2010
Recently we made mounting for SDI-HDMI converter for our gimbal. It's simple, light and well does the job.
Old May 10, 2014, 11:44 AM
kmd1984.1 is offline
Find More Posts by kmd1984.1
Joined Apr 2013
Looks great. Am I blond or is there no price listed for this gimbal?!
kmd1984.1 is offline Find More Posts by kmd1984.1
Reply With Quote  (Disabled)
Old May 12, 2014, 03:53 AM
kuki83 is offline
kuki83's Avatar
Poland
Joined Nov 2010
The price of this gimbal is 1500$, it's the price with 23% tax.
Old May 12, 2014, 06:14 AM
fltundra is offline
Find More Posts by fltundra
United States, FL, Key Largo
Joined Feb 2014
yikes!!
fltundra is offline Find More Posts by fltundra
Old May 13, 2014, 04:19 AM
kuki83 is offline
kuki83's Avatar
Poland
Joined Nov 2010
Yes, in Poland is a little high tax but if you aren't from UE or if you are in UE but you have UE tax number you buy without tax.
Today we made safety test of our platform.
We removed one prop and we flew without it. Sometimes it happens that one motor stops working and we have a problem because platform falls to the ground. Fortunately the X8 configuration worked well and we didn't damage neither gimbal nor Black Magic :-)
X8 Frame - test without one prop (1 min 34 sec)
Old May 16, 2014, 07:30 AM
kuki83 is offline
kuki83's Avatar
Poland
Joined Nov 2010
I present next video. We made it on cycling competition. It's only the sample, full video will be ready soon.
Used equipment: X8 octocopter + gimbal DSLR/BlackMagic/RED + Black Magic Cinema Camera
Gimbal 3-axis 03-05-2014 (2 min 32 sec)
For Sale 3 Axis Handheld Gimbal (RED/BMCC/DSLR). Prebuilt in the USA, brand new! KevinJoel Aircraft - Electric - Multirotor (FS/W) 1 Apr 15, 2014 03:56 PM
For Sale Carbon Fiber Gimbal, RED Epic, BlackMagic, 5D, F100, F700 $449 shipped. AlchemistAerials Aircraft - Electric - Multirotor (FS/W) 2 Nov 14, 2013 06:09 PM
For Sale 3 Axis Carbon Fiber Gimbal, RED Epic, BlackMagic, F100, F700 $400 firm. AlchemistAerials Aircraft - Electric - Multirotor (FS/W) 1 Oct 23, 2013 08:42 AM
For Sale Carbon Fiber Gimbal, RED Epic, BlackMagic, F100, F700 $400 firm. AlchemistAerials FPV Equipment (FS/W) 0 Oct 23, 2013 05:09 AM
For Sale New large carbon fiber gimbal. RED, BlackMagic, F700 etc $475 shipped. AlchemistAerials Aircraft - Electric - Multirotor (FS/W) 0 Oct 18, 2013 11:40 PM
