Old Mar 23, 2014, 09:55 PM
highpines is offline
Find More Posts by highpines
Joined Oct 2009
Motor smoked...I messed up
Hey , it's been awhile.........getting back to flying....glad to be back....hello....I smoked a cheap...BM2408-21....and using a "Thunderbird-18.....2 cell was fine but tried 3 cell bat and there came smoke from motor...think was motor or ESC?..........was on PT17GWS Stearman.....man was depressed................wadayathink?....I think was motor?......Thanks.......Guess I messed up on ESC and motor............Thanks for taking time to check out post...........
Dale
highpines is offline Find More Posts by highpines
Old Mar 23, 2014, 11:42 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Neither motor or ESC...prop.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Mar 24, 2014, 03:48 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
+1
The amount of amps any particular motor draws depends almost entirely on supply voltage and prop size. If you increase the volts (battery cell-count) you must normally reduce the prop size to ensure that the amps stay within the motor's and ESC's limits.
If you check out the motor's spec http://www.raidentech.com/bmoubrmowfim.html you'll see that they suggest 9x4 prop with 2S or 8x4 prop with 3S. Since different brands and styles of prop perform differently, you should check the actual amp draw with a wattmeter when you change props, to ensure that you're not exceeding the motor's or ESC's amps spec.
abenn is offline Find More Posts by abenn
Old Mar 24, 2014, 04:44 AM
Joined Oct 2009
Thanks guy's
Like said been away for a couple years....how easy to forget.....right? ....Thanks for the help on props. guess used to huge prop on S/S and 3 cell.......I was just excited to get her up....had one before I like low and slow. I have a Superfly and a Beaver GWS and my S/S....but wanted to get this Stearman in the air....fun plane....Here in snow jjust getting ready to fly...after all melts in Utah.......
I have 3 more motors, tons of props.....prolly ask more questions if you don't mind......
Thanks;;;;;D
Old Mar 24, 2014, 09:57 AM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Tell us the motor you plan to use, link us to the online store, post kV of motor and battery cell count you will use and we can help you with prop size or tell you to use another motor...
Rick
rampman is offline Find More Posts by rampman
Old Mar 24, 2014, 07:59 PM
Joined Oct 2009
Thank you
It's an eflite 480......say's 910Kv and to use a 10-7 to 12-6 prop.......I'm afraid of course like last time to smoke her out....No need to go crazy.....I like low and slow ...Here's the specs...I can get close i'm sure....Hope ESC is OK but can rob from other planes.....just hope this 2 s will put her in the air......thanks again for all your help....ohhhh say's wants 20-30 ESC.....is that a prob?...mine are 18amp
Got more props that I know what to do with shouldn't be a prob....and 3 cells, small and big but now they scare me.......can't afford.....just want to fly right?
here's link
http://www.ebay.com/itm/E-flite-Park...item43b4a47e21
Thans again!!!
Old Mar 25, 2014, 03:34 AM
abenn is offline
Joined Jul 2004
Got more props that I know what to do with shouldn't be a prob....and 3 cells, small and big but now they scare me.......can't afford.....just want to fly right? ...
Note that the spec says it's good for 7.2v to 12v batteries (effectively 2S or 3S), so the larger prop they suggest is for the 2S battery, and the smaller one is for 3S. If you use the larger one with 3S you'll smoke another motor
The spec also says the motor is good for 20A. Normally I would put a prop on that makes it draw 20A (why waste power if it's available) and get an ESC that's good for 25A or more. But if, say, 15A is going to give you enough power (so as not to overload your 18A ESC) you could put a smaller prop on to keep the amps below 15A. Once you've chosen the battery voltage, the amps depend only on the prop size, so that's where you need a wattmeter so you can see what's happening when you experiment with different props.
Old Mar 27, 2014, 02:29 PM
Joined Oct 2009
Thank you all so much...yep 2 s and smaller prop..never a prob...heck the 3 s and using 10.7 is what smoked motor. I have wat meter in tool box somewhere will check....I think I'm starting to remember how it all works......right now just waiting for snow to fade away......just getting ready to fly again......Like said have Superfly Gws Beaver and a slow stick with 3s and vertical no prob....fun planes..
..thanks again
Old Mar 28, 2014, 10:00 PM
Joined Oct 2009
Thanks again........Job interviewing and trying to get these planes ready.....kind of a pain.....I'll keep you updated if o.k....
Question Will ca debonder mess up paint ? fly2bob Painting and Finishing Tips 7 Feb 12, 2014 08:32 PM
Off Site Wow Webpage Messed up ?? VampeD4 Aircraft - Fuel - Engines and Accessories (FS/W) 4 Jan 27, 2014 05:25 PM
Help! Newbie Questions....I think I messed up! Xringer Power Systems 5 Nov 20, 2013 09:59 PM
Help! Super CP: Pitch curve messed up after crash superpoodle Micro Helis 6 Nov 10, 2013 10:34 PM
Help! Holly smokes its messed up ozzypaws 3D Electric Heli Flying 3 Dec 04, 2009 11:29 PM
