Old Oct 02, 2013, 03:59 PM
Wayner is offline
Find More Posts by Wayner
Victoria, B.C. Canada
Joined Jan 2001
Blade400-throttle problem-any thoughts??
I'm new to this level of RC heli and just bought a' flown once' blade400. Have set up new Futaba 7c radio with newbie curves...
throttle curve 0-75%
pitch curve 65-85%
blades are balanced, swash is level, pitch is 3-7 degrees...
everything seems right,have power up to half stick, but then it wont go any higher. It just seems to level off at that half stick point.
I've tried different motors, esc's, radios...still no joy. The heli gets to a point where it seems to want to lift off the ground, but just wont do it. It sounds like the rpm doesn't increase over half throttle. The weird part is that with the blades off,I can hear a rpm increase after half throttle, but not with the blades on.
Am totally baffed, as are my friends. Any thoughts about what might be the problem. any help is greatly appreciated.
wayner
Wayner is offline Find More Posts by Wayner
Old Oct 02, 2013, 05:25 PM
holtneil is offline
Find More Posts by holtneil
holtneil's Avatar
United Kingdom, England, Slough
Joined Dec 2012
hi what happens if the throttle curve goes up to 100 you can still run a low pitch but you need head speed a lot use 0-50-80-90-100 throttle get the head speed right then adjust pitch to how you like to fly there is also a lot of flyers that use idle up to fly so that will be running 90-100 most of the time hope that helps
holtneil is offline Find More Posts by holtneil
Old Oct 02, 2013, 05:26 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
TAKE THE BLADES OFF!
Then, reverse the throttle channel. Futaba does it wrong, so you have to reverse that channel on most systems when using Futaba. But seriously, take the blades off before you do that!
jasmine2501 is offline Find More Posts by jasmine2501
Old Oct 02, 2013, 06:02 PM
Wayner is offline
Joined Jan 2001
I moved the throttle curve to 0-50-80-90-100 %, but it didnt help the problem. I then tried to reverse the channel 3 and two of the motor leads, but then it wouldn't spin at all...thanks for the thoughts, but still baffled....
wayner
Old Oct 02, 2013, 06:30 PM
Rocket Programmer
Joined Jul 2007
Why in the hell would you be reversing motor leads? That has nothing to do with the radio signal. Don't change two things at once.
Old Oct 02, 2013, 08:39 PM
Wayner is offline
Joined Jan 2001
Hey jasmine2501...I didn't change two things at once. First, I tried reversing the channel on the tx. Wouldn't spin at all. So then I thought I try switching motor wires. Still no spin...wayne
Old Oct 02, 2013, 10:23 PM
mdugas is offline
Find More Posts by mdugas
Joined Aug 2003
almost sounds like pitch is reversed, there are no swash mix settings listed .
see 3-7 listed as p range ,p initally in wrong direction is common when going blade to futaba .did you buy new lipos for this ?
mdugas is offline Find More Posts by mdugas
Old Oct 03, 2013, 11:11 AM
Rocket Programmer
Joined Jul 2007
Almost sounds like a broken ESC maybe. Switching the wires shouldn't have any effect, the motor should always run. The direction of the radio channel has nothing to do with that.
Old Oct 03, 2013, 11:31 AM
Wayner is offline
Joined Jan 2001
The pitch is in the right direction. The helicopter is trying to lift, it almost gets off the ground. It just doesn't seem to have that little bit more RPM. The swash is set at 50% for al, rdr and pitch.
The esc that is in the heli right now just came out of a working heli. I've also tried 3 other esc to no avail.
thanks for all the ideas....
wayne
Old Oct 03, 2013, 02:33 PM
skyeblu is offline
Find More Posts by skyeblu
banging head on wall
skyeblu's Avatar
Joined Feb 2010
one thought have you calibrated the esc and throttle range. throttle at high stick plug in heli and then lower throttle stick. just something to try .
skyeblu is offline Find More Posts by skyeblu
Old Oct 03, 2013, 11:16 PM
ASTREA1 is offline
Find More Posts by ASTREA1
A&P in training
ASTREA1's Avatar
United States, CA, Vacaville
Joined Dec 2008
I was thinking the same thing. This happened with my new Blade 500. I set the throttle curve to 0,25,50,75,80, and adjusted the throttle curve which made the ESC think that 80% was full throttle and threw everything out of wack. You said you tried various ESC's but you can set it linear and give it a shot.
ASTREA1 is offline Find More Posts by ASTREA1
Old Oct 03, 2013, 11:23 PM
mdugas is offline
Joined Aug 2003
a qiuck video ,show close up of roterhead before spool up would help. if you can grab the
main gears and hold them still and still turn roter head by hand then theres the problem
sheared main gear bolt another common problem .roter head cant get to rpm
so roter head on spool up ,doesnot fly up and off heli
Old Oct 05, 2013, 02:10 PM
holtneil is offline
holtneil's Avatar
Joined Dec 2012
this may be silly but if you are running 3-7 deg pitch at what throttle setting if that's at low pitch will be to high at 3/4 and you wont get head speed and you said revs come up if no blades on , try this pull two wires off the motor so she cant spin up then go in to pitch on trans and go in to idle up mode the move throttle up to mid stick display on trans will show when your at mid stick now set swash plate to 0 deg now when that's done check the swash is level now when you throttle up and down you should have a good pitch range , now go back to normal mode and look at pitch what you need is about -2/-3 degs of pitch with no throttle this is so in the wind you can get heli down if its more than this go in to trans and change pitch curve so you get this -1/-2 will be good in normal mode for a beginner. now give the heli a spin up see if she flys if not you can change throttle curve to give more revs lower on the stick or change pitch to give more lift if you use pitch and your below 50/50 on the stick, as you throttle down heli will drop faster than you may like so you will need to play with it , one last thing don't the blade come with a book that gives you setting for trans I know its for a spekrum but will give you guide lines to work to sorry long message I hope it help let us know please kind regards neil in uk
Old Oct 07, 2013, 12:36 PM
Wayner is offline
Joined Jan 2001
Well ladies and gentlemen, I think we found the problems. There was a binding/bearing issue in the tail and the main gear bearing housing was cracked, allowing some touching of the gear to the chassis. All these together caused a big drag and loss in RPM. We replaced the tail rotor assembly and put in a new main gear and she spins up fine now.
I do want to thank you all for the help and suggestions you provided.
Wayne
Old Oct 09, 2013, 10:01 AM
holtneil is offline
holtneil's Avatar
Joined Dec 2012
well done Wayne glad you got it sorted happy flying mate
Discussion 9XR Problem, Throttle acting as a switch? FULL throttle, ZERO throttle? 85miles Radios 0 Apr 30, 2013 02:20 PM
Discussion KK2 Jumpy Throttle, Won't Hover Well, Thoughts? supercoe Multirotor Talk 19 Apr 20, 2013 06:02 PM
Discussion Curing Polyurethane Glue aka Gorilla Glue - any thoughts? macinr Slope 16 Jan 15, 2013 01:07 PM
Discussion I need some help or any thoughts on my small problem kelloggair Scratchbuilt Indoor and Micro Models 2 Jan 11, 2010 08:36 PM
Problem with Slo-V------any thoughts ??? Cal Parkflyers 37 Feb 14, 2005 09:01 PM
