Old Apr 30, 2013, 04:09 PM
rcKhana28 is offline
Find More Posts by rcKhana28
Joined Apr 2013
Engine randomly stalling.
I have a savage 4.6 it runs great accelaterates fine, will wheeley on command but it recently started stalling for no reason the engine doesn't big down it will just stall and it does it about every two mins of run time, changed the plug, re tuned it and it still does it also when I hit the break it stalls right away, I checked the carb and there Is a good size gap when I break. So Im out of ideas, anyone know what's wrong and how to fix it?
rcKhana28 is offline Find More Posts by rcKhana28
Old Apr 30, 2013, 08:35 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Does it stall if you hit the brakes while the truck is stopped, or just if you hit the brakes while it's moving at a decent speed? Does it behave the same on a totally fully tank, or only after a few minutes of running?
wparsons is offline Find More Posts by wparsons
Old May 01, 2013, 10:39 AM
Joined Apr 2013
Acts same no matter for full tank is. And if I even touch the brake that kills it. I have a feeling it has to do with the throttle linkage closing the carb to much when I hit the brake. Think that could be it?
Old May 01, 2013, 08:22 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Yep, adjust the idle screw so that the carb can't close further than it is at idle currently.
Old May 01, 2013, 10:44 PM
Joined Apr 2013
Yeah i was guessing that. Thanks man
For Sale Lot of a bunch of random stuff (engine mounts, wheels, spinner etc) Paulsitive Non R/C Items (FS/W) 14 Mar 14, 2013 10:18 AM
Discussion random idea. micro turboprop engine. nemoskull Engines 9 Mar 15, 2012 09:57 PM
Help! Tricopter: Random short-timed motor stalls ArrowX Multirotor Talk 4 Aug 08, 2011 12:53 AM
Discussion engine cuts out randomly when using other controls swiftouch Electric Plane Talk 8 Jul 05, 2011 08:01 PM
HELP!!! Engine runs then stalls Muz Nitro and Glow Power Cars 4 Feb 24, 2005 02:48 AM
