Old Apr 22, 2013, 05:01 AM
Watdazit is offline
Find More Posts by Watdazit
A geriatric flier
Watdazit's Avatar
Australia, NSW, Braidwood
Joined Nov 2008
Question
10cc gas engine
I am comfortable with EP but want to try a gasser. This is a general question but it based around the Hangar 9 Meridian.The Hangar 9 Meridian which has an about 1800mm wingspan was supposedly designed around the Evo 10cc gas engine When I look around at other manufacturers recommendations for this size of plane they generally recommend 30cc. Am I missing something?
Watdazit is offline Find More Posts by Watdazit
Old Apr 22, 2013, 06:09 AM
gene6029 is offline
Find More Posts by gene6029
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
I think you said it in your original post, the Meridian was designed around the 10cc motor. That said, the construction, overall weight/wing loading is just right for that size motor/plane combination. It works because we have a bunch of new guys flying them at our field & nobody is complaining about anything. I wouldnt size a motor to a plane solely based on wing span. I have several 78"ws models with .049 size motors for example, that 10cc would tear them to shreads....Gene
gene6029 is offline Find More Posts by gene6029
Old Apr 22, 2013, 06:11 AM
earlwb is online now
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
The Hangar 9 Meridan works fine with the Evo 10cc gas engine on it. Quite a few people have already done just that with it too. It has a 69 inch wingspan (175cm). The plane would work fine with a .45 through .60 size glow engine and or a Power 46 electric too. But a 30cc engine is way too big and heavy for it, Usually the 30cc engines are used on planes like the 81inch (210cm) wing span Hangar 9 P47 for example. But larger planes like the H9 1/2 scale PA-18 with its 106 inch wingspan (269cm) are typically flown using a 30cc gas engine. Now then there are some 75 inch wingspan (190cm) which are 3D aerobatic planes designed for hovering that use 30cc gas engines. But the Meridian is not designed to do that though, nor is it designed to use a huge and heavy 30cc gas engine either.
earlwb is online now Find More Posts by earlwb
Old Apr 22, 2013, 10:51 AM
600Bob is online now
Find More Posts by 600Bob
United States, OR, Canby
Joined Aug 2011
[QUOTE=Watdazit;24791942]I am comfortable with EP but want to try a gasser. This is a general question but it based around the Hangar 9 Meridian.The Hangar 9 Meridian which has an about 1800mm wingspan was supposedly designed around the Evo 10cc gas engine When I look around at other manufacturers recommendations for this size of plane they generally recommend 30cc. Am I missing something?[/QUOTE]
There was a Meridian at the LHS, no way would I put a 30CC gas engine on a plane that size. I have a slightly larger and heavier plane with a 17cc engine that has plenty of power and a 14 lb. 77" WS biplane with a 26cc and it is over powered.
600Bob is online now Find More Posts by 600Bob
Old Apr 22, 2013, 12:19 PM
Watdazit is offline
A geriatric flier
Watdazit's Avatar
Joined Nov 2008
Thanks guys. I suppose it all comes down to checking the power output of the engine and not the size.
Old Apr 22, 2013, 05:31 PM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I think it is more about what the airplane was designed to use for a engine. The planes designed for a big heavy 30cc gas engine are larger in size and a little more robust in construction to handle the bigger engine. Now there might be a overlap in wingspan lengths, but if you put the two plane designs side by side you would quickly see the differences between them.
Sold Evolution 10cc Gas Engine New In Box with muffler shooboy Aircraft - Fuel - Engines and Accessories (FS/W) 2 Apr 30, 2013 08:44 PM
Sold EVOLUTION 10GX (10cc) GAS ENGINE NIB-NEVER USED $205 SHIPPED Wingwrecker Aircraft - Fuel - Engines and Accessories (FS/W) 7 Apr 25, 2013 08:44 AM
Sold Evolution 10GX, 10cc Gas Engine, NIB BillBigelow Aircraft - Fuel - Engines and Accessories (FS/W) 1 Apr 04, 2013 07:08 AM
Discussion twist 40 with new Evolution 10cc gas engine GarryB 3D / Fun Fly Fuel Planes 14 Mar 13, 2013 09:07 PM
Found Evolution 10cc gas engine jhaymes2006 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Mar 01, 2013 08:44 AM
