Old Jan 21, 2013, 05:42 PM
helipilot23 is offline
Find More Posts by helipilot23
Unregistered User
helipilot23's Avatar
Joined Oct 2012
need help.setting up.
So I can get the swashplate to move up and down with the throttle but the cyclics are reversed. I need help.
Btw I'm using a dx7s a ar6100e and a esky hbk4/3
helipilot23 is offline Find More Posts by helipilot23
Old Jan 21, 2013, 06:00 PM
WOS is offline
WOS
Find More Posts by WOS
WOS
United States, IN, Michigan City
Joined Nov 2003
Sounds like you have a few of the servos plugged into the wrong slot on the rx. try moving the servo plugs around and play with the servo reversing
WOS is offline Find More Posts by WOS
Old Jan 21, 2013, 06:14 PM
old4570 is offline
Find More Posts by old4570
Australia, VIC
Joined Dec 2011
Yeah , either moving in the wrong direction - or plugged into the wrong port in the Rx ...
Aaaah , dont you love setting up cyclic the very first time ?
old4570 is offline Find More Posts by old4570
Old Jan 21, 2013, 06:15 PM
WOS is offline
WOS
WOS
Joined Nov 2003
If the swash is moving in the right direction for the pitch than you def. have a servo or two or three in the wrong port. Start swapping ports and playing with your reversing. As old one says.....CYCLICS ARE FUN!
Old Jan 22, 2013, 03:37 PM
Unregistered User
Joined Oct 2012
Haha lol... Thanks. I ll try that.
Old Jan 22, 2013, 03:40 PM
Unregistered User
Joined Oct 2012
I mean. The servos move as if it was a trex 450 pro swashplate with 2 servos in the front. But this swashplate has two servos in the back..
Old Jan 22, 2013, 04:10 PM
ASTREA1 is offline
Find More Posts by ASTREA1
A&P in training
ASTREA1's Avatar
United States, CA, Vacaville
Joined Dec 2008
You may have to mess with the Swash mix(- or +) in the TX in order to get the desired results..You'll get it eventually. I remember setting up the cyclic on my TH9x for the first time..Took about an hour to get everything where it needed to be.
ASTREA1 is offline Find More Posts by ASTREA1
Old Jan 23, 2013, 12:52 AM
zen@lanset.com is offline
Find More Posts by zen@lanset.com
unlicensed helicopter nut
zen@lanset.com's Avatar
Berkeley, California
Joined Jan 2007
It depends on the radio you are using, but the 120 swash plate that E_sky uses is generally set up with aileron as the front left servo, pitch the right front, and elevator the rear servo. Aileron and pitch can go the other way too, but this is the schema. It is almost always necessary to reverse a servo or two to get the cyclic movements right plus collective pitch in the right directions. But if you know which channels of your radio control aileron, pitch, and elevator the rest will fall into place.
zen@lanset.com is offline Find More Posts by zen@lanset.com
Old Jan 23, 2013, 02:40 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
You first need to check that you've selected the correct swash mode in your trannie menu. My Futaba has 120 degree with rear elevator, 120 degree with front elevator, 90 degree, and a few others to select from.
abenn is offline Find More Posts by abenn
Old Jan 23, 2013, 10:05 AM
Joined Jan 2007
Good point. That is where it starts.
Old Jan 23, 2013, 12:03 PM
skyeblu is offline
Find More Posts by skyeblu
banging head on wall
skyeblu's Avatar
Joined Feb 2010
Have you tried reversing all three servo directions from where they are now ( norm / rev ) and then reversing the swash mix from a minus to a positive or the other way round . Thats if your controls work for aileron and elevator but are reversed. Just a thought I think I remember I had to do that a few times with different builds crs you know
skyeblu is offline Find More Posts by skyeblu
Old Jan 23, 2013, 01:44 PM
Unregistered User
Joined Oct 2012
I dont know where te swash mix is... (noob comment)
Old Jan 23, 2013, 02:12 PM
ASTREA1 is offline
A&P in training
ASTREA1's Avatar
Joined Dec 2008
It is somewhere in the settings..Maybe this will help a bit.
DX7 programming part 2 (12 min 43 sec)
Old Jan 23, 2013, 02:38 PM
Unregistered User
Joined Oct 2012
I found it. Under "swashplate" on my dx7s. The swashplate works now. Also, Do you know some noob settings? I can fly basic 3d on my nano cpx so i need a basic setup.
thanks
Old Jan 23, 2013, 02:45 PM
skyeblu is offline
skyeblu's Avatar
Joined Feb 2010
In the video above at about 3:45 it starts to explain the swash mix and changing from plus to positive just the pitch mix!. Also at this point the numbers also adjust total swash travel on a trex450 its about 60% as a start equal both sides. For your bird watch for binding at the top and bottom of pitch range and adjust numbers for no binding. Good video explains the setup pretty clearly.
Discussion Need a Bad A$$ Engine set up for Ultra Stck 40 Dale 813 Engines 22 Jan 30, 2013 01:39 PM
Help! Need to know the set up for a Hydro Plane Foamie. SHoffman1971 Power Systems 13 Jan 15, 2013 07:25 PM
Discussion Need Advise on what C rating for this system set up! chopper52 Electric Ducted Fan Jet Talk 1 Jan 12, 2013 01:09 PM
Discussion Need help setting up Devo 10 w gimbal and f450! floete Multirotor Talk 4 Jan 07, 2013 03:27 PM
Help! Need help setting up Walkera V120D02S... LucidSoul Micro Helis 6 Jan 04, 2013 10:46 AM
