Old Dec 25, 2012, 12:21 AM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
Build Log
50% dick's dream
so far i got a fuse. shooting for 17 inch WS. r415 and hk5320 servos.
plans from this site:
http://my.pclink.com/~dfritzke/
dont have no pics right now, but will get some up soon.
edit: pics up! yes, im a japanese tissue whore.
this is shaping up as a twin pusher, 44m motors. WS is 17 inches. thrust is 17 grams each motor, so in the 30 gram thrust area. also my target (wish?) AUW.
r415 and hk5320 servo.
got the fuse almost done. ill run the controls later, push pull cables.
nemoskull is offline Find More Posts by nemoskull
Old Dec 25, 2012, 09:58 AM
BigIron357 is online now
Find More Posts by BigIron357
25+ years of RC flying
BigIron357's Avatar
United States, FL
Joined Aug 2012
Wow! You really jumped into action! Lookin' goooooood...
BigIron357 is online now Find More Posts by BigIron357
Old Dec 25, 2012, 04:39 PM
nemoskull's Avatar
Joined Sep 2009
thanks. i still dont know how much it weights! insomnia is not fun, but i do build a lot at night
sealed the fuse tissue with hairspray. will have to redo the vertical stab, warped.
Old Dec 25, 2012, 05:18 PM
BigIron357's Avatar
United States, FL
Joined Aug 2012
Have you tried heating the vertical stab with a hairdryer, twisting it to the correct shape and holding it there till it cools? Works most of the time.
Old Dec 25, 2012, 07:56 PM
nemoskull's Avatar
Joined Sep 2009
fuse, part II
the rudder tissue delaminated, so i glued it again and soaked it with water and clamped it again.
got the horizontal stab mounted and glued, sprayed the stab with hairspray (from now on, 'sealant')
picture of my donor plane. (too fast, too much torque, no fun to fly.)
might be adding alierons (probly will).
Old Dec 26, 2012, 10:44 AM
BigIron357's Avatar
United States, FL
Joined Aug 2012
Ailerons will be cool. Are you plan on using dihedral?
How about some flaps too? Something like so...
Old Dec 26, 2012, 05:22 PM
nemoskull's Avatar
Joined Sep 2009
hmmm, got to think about that one. i can run flaps, but that means i only can fly one plane...
i just dont know!
edit: dehidral, yes. some, enough to fly its self in calm days. i use ailerons to fight the wind.
Old Dec 27, 2012, 11:29 PM
nemoskull's Avatar
Joined Sep 2009
got one wing half done. decided on the ar6400. still might go single motor. push pull cables. id love CF push rod to save weight, but dont have it right now.
screwed up on the wing and ended up 'inventing' some parts of it. i really should have elimnated half the ribs, anyways. scaling down by half, means weight goes down to 1/4, so you usualy end up stronger scalwise than the origonal.
Old Dec 28, 2012, 11:23 AM
BigIron357's Avatar
United States, FL
Joined Aug 2012
I hadn't realized that you were considering making it a twin. That would definitely be interesting to see.
Looking forward to seeing your radio installation as well!
Old Dec 28, 2012, 04:47 PM
nemoskull's Avatar
Joined Sep 2009
twin mostly because i have no single motor big enough. the disscusion me and my wife had was performance ever looks. that means twin 44mm 2(inch) motors facing backwards... still dont like that. id rather have twin 2.5 inch props facing forward. but then id get 28 gram thrust, vs 36 for the twin 44mm pushers.
still might just order a brand new p51 motor.
edit: im not investing too much time or effort into this one. ive never had a balsa plane fly longer than a few seconds, so im kinda hedging my bets here with the emotional investment.
edit2: 12 grams so far. one naked wing, rx,servo,esc, tail feathers, half convered fuse.
Old Dec 29, 2012, 12:00 PM
nemoskull's Avatar
Joined Sep 2009
oops, got my wing finished and realized i ommited R6. poop.
well, ill finish thw wing anyways. i need to get something in the air soon, or ill go crazy!
both wings came our straight. we shall see how they come out after covering.
Old Dec 29, 2012, 08:20 PM
nemoskull's Avatar
Joined Sep 2009
ailerons. yes, uneven T.E., what can i say, its a sloppy build
but everything seems straight.
im going to use thread hinges.
Old Dec 29, 2012, 08:59 PM
BigIron357's Avatar
United States, FL
Joined Aug 2012
Looking good! Those ailerons are gonna be way cool on that little plane.
Old Dec 31, 2012, 06:02 AM
RC Trainer plane is offline
Find More Posts by RC Trainer plane
Balsa builder and balsa basher
RC Trainer plane's Avatar
Joined Apr 2012
nemoskull im loving this build. Subscribed !
RC Trainer plane is offline Find More Posts by RC Trainer plane
Old Jan 04, 2013, 07:49 AM
BigIron357's Avatar
United States, FL
Joined Aug 2012
Hey nemoskull, how will you be powering your ailerons?
Build Log Ultra micro Dick’s Dream BigIron357 Scratchbuilt Indoor and Micro Models 42 Sep 11, 2013 07:56 PM
Sold Dick's Dream Rubbernecker Aircraft - Fuel - Airplanes (FS/W) 5 Feb 28, 2012 09:12 PM
For Sale Dick's Dream Rubbernecker Aircraft - Electric - Airplanes (FS/W) 12 Feb 28, 2012 04:21 PM
Sold Ace Dick`s Dream collectors kit NIB skylane42 Aircraft - Fuel - Airplanes (FS/W) 1 Jan 02, 2006 07:06 PM
Gallery Ace Dick`s Dream skylane42 1/2A Planes 0 Jan 02, 2006 09:35 AM
