Old Dec 13, 2012, 03:56 PM
METATRON12 is offline
Find More Posts by METATRON12
United Kingdom, England, Thurstonfield
Joined Feb 2012
Question
binding multiple receivers
I have one rc plane and I am using a Hitec optic 5 tx and a hitec minima 6 receiver. My question is can I use a 2nd minima receiver in a 2nd plane but then use the single optic 5 tx to fly both planes (not simultaneously of course). In other words can I bind 2 receivers to one transmitter. I would not mind if I had to re-bind the receivers each time I swapped planes or will the optic 5 memorise both receivers or is it the receivers which memorise the tx id.
Confused!! Any help would be much appreciated
METATRON12 is offline Find More Posts by METATRON12
Old Dec 13, 2012, 04:51 PM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
yes you can, you can bind as many receivers as you like to one Tx. the only problem you will have is that your Tx doesnt have individual model memories so things like servo reversing, trims, control; throws etc. cant be adjusted and saved for each individual model as they can be with a computer Tx with model memories.
You need to be real careful that you don't fly with controls reversed or wildly out of trim.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Dec 14, 2012, 02:48 AM
Joined Feb 2012
Thanks a lot that tells me all I need to know, I understand what you say about checking trims
servos etc when swapping planes.
Thanks again for the advice very much appreciated
Question Multiple transmitter binding? KYChopper Electric Heli Talk 7 Jun 19, 2014 02:51 AM
Discussion nooB question on one TX multiple planes and binding ToddB Radios 3 Oct 15, 2012 08:19 PM
Question Binding multiple Optima receivers to Spectra 2.4 maverick500 Hitec/Multiplex USA 3 Mar 04, 2012 12:29 PM
Discussion Binding Multiple receivers simultaneously to JR X9303 FlckSpnCrshBrn Radios 2 Mar 07, 2010 06:50 AM
Help! Binding multiple AR6100's to DX7 ?? cobra command Radios 4 Sep 05, 2007 08:40 PM
