Old Dec 11, 2012, 10:43 PM
Robert Pulse is online now
Find More Posts by Robert Pulse
Robert Pulse's Avatar
Davenport, Iowa
Joined Apr 2007
JJC Electronics
Anybody ever use a JJC Electronics Prop Rudder Mixer? How well does it work?
Bob
Never mind I searched the thread and found what I wanted to know
Going in my shelly foss for testing
Robert Pulse is online now Find More Posts by Robert Pulse
Old Dec 12, 2012, 09:08 PM
Davenport, Iowa
Joined Apr 2007
Jjc
I am assuming That I need to disable one of the power wires from one of the speed controls before I run this thing. It doesn't say in the instructions. Anybody
Bob
Old Dec 13, 2012, 05:25 AM
mfr02 is online now
Find More Posts by mfr02
Blackpool, Lancs
Joined Feb 2006
I never got a close look at one, but, and this is just opinion, if you can look at the PCB, if the +ve pins from the ESC connections are commoned, it would probably be good practice to disconnect what is the spare feed from the BEC not powering the system. If you can't see the PCB track side, testing with a resistance meter should show if they are linked or not.
It was possibly designed with the use of a separate RX pack in mind, so BEC equipped ESCs might not have been considered when the instructions were being written. Again, just a guess.
mfr02 is online now Find More Posts by mfr02
Old Dec 14, 2012, 05:27 AM
fatboy999 is offline
Find More Posts by fatboy999
fatboy999's Avatar
Canada, ON, Tillsonburg
Joined Feb 2005
Jjc
I thought JJC was out of business, or am I wrong? I can't find their website.
fatboy999 is offline Find More Posts by fatboy999
Old Dec 14, 2012, 08:12 AM
Davenport, Iowa
Joined Apr 2007
Jjc
Yes Out from what I have found.
I got this one from a club member NIP
Bob
Old Dec 14, 2012, 10:12 AM
Clancy Arnold is offline
Find More Posts by Clancy Arnold
I am 5' 8" the Taube is 7' 4"
Clancy Arnold's Avatar
USA, IN, Indianapolis
Bob
For safety disable one of the ESC center pins before you apply power so that the two BEC do not fight each other and damage both ESCs!.
Clancy
Clancy Arnold is offline Find More Posts by Clancy Arnold
Old Dec 14, 2012, 11:24 AM
frankg is online now
Find More Posts by frankg
Joined Dec 2004
As a rule of thumb, I would disable both BECís in the speed controls and use a separate receiver battery supply or a single BEC, running off the main power batteries, with a higher amp output to the receiver. This way you will not have to worry about not having enough power to run the receiver, servos, and what ever accessories you want to put on board.
frankg is online now Find More Posts by frankg
Old Dec 14, 2012, 01:01 PM
Davenport, Iowa
Joined Apr 2007
This is more than likely the best way to do this. I did talk to harbor models (who used to sell the JJC MKII and he said yes you have to disconnect one of the bec wires on one of the speed controls) But thanks everyone for their help
Bob
Discussion JJC Electronic (JJC sound units) soren Scale Boats 6 Jun 27, 2008 04:25 PM
Help! JJC Electronics soren DIY Electronics 5 Nov 13, 2007 11:27 AM
Discussion JJC Electronics users --------> Kmot Dock Talk 45 Apr 28, 2007 10:50 AM
Cool JJC Electronics Demo Kmot Dock Talk 13 Nov 03, 2006 06:05 PM
Question For those of you who have purchased a JJC Electronics Sounds Amazing module: Kmot Dock Talk 28 Aug 21, 2006 11:02 PM
