Old Nov 22, 2012, 05:10 AM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Question
Replacement duct exhaust
The repaired F16 I have ... when given the rear duct piece - noted it was angled ..
The angle matched the fuselage and so I fitted it. But I'm having concerns about the internal duct angles ...
The Duct aligns with the fuselage nicely BUT if I place a straight edge into the duct I get :
Placed along inside bottom of this tail pipe - the edge has an angle of about 5 degrees up from horizontal ... basically indicating that thrust line will push tail DOWN.
If I place straight edge along inside top of this tail pipe - the edge lies in line with fuselage ... indicating a straight thrust line ...
I'm looking for opinions / views on whether I should cut and angle the tail pipe slightly to obtain an averaged thrust line straight with fuselage ?
The model is the Lanxui 70mm F16.
Nigel
solentlife is online now Find More Posts by solentlife
Help! Need replacement exhaust cone for Magnum Pro 45! richman03 Engines 7 Jul 26, 2012 03:03 PM
Wattage PDF 400 exhaust duct diameter P_J_Glor Electric Ducted Fan Jet Talk 6 Dec 24, 2003 05:14 PM
Question Taper exhaust ducting to FSA?? meteor Electric Ducted Fan Jet Talk 1 Oct 15, 2003 10:58 PM
Drastically oval Exhaust Ducting wtghost Electric Ducted Fan Jet Talk 2 Jun 12, 2003 11:13 PM
Ducted fan restricted exhaust Mikey_Flies Power Systems 7 Jul 16, 2001 04:38 AM
