Old Oct 08, 2012, 08:51 PM
sansouci01 is offline
Find More Posts by sansouci01
United States, FL, Orlando
Joined Oct 2005
which esc
I'm changing at brushed motor set up in my boat to brushless. I have a 3 pole motor from a stryker rc plane that I want to use. I tried a 40 amp esc and it heated up and cooked. Which size esc should I use for this motor.
sansouci01 is offline Find More Posts by sansouci01
Old Oct 08, 2012, 09:15 PM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
Was this esc meant for brushless?
coriolan is online now Find More Posts by coriolan
Old Oct 08, 2012, 09:39 PM
fly2bob is offline
Find More Posts by fly2bob
fly2bob's Avatar
United States, CA, San Diego
Joined Nov 2005
No idea.....what (size) motor is it? What is it's amp rating? How much pwr is the system drawing. What (size) battery are you using? Did you change anything else besides the motor? Like the previous member post, did you change the esc too or use the same one? A little more info would be helpful.
fly2bob is offline Find More Posts by fly2bob
Old Oct 08, 2012, 11:17 PM
frankg is offline
Find More Posts by frankg
Joined Dec 2004
Sansouci 01- Does the speed control need reverse function. M.A.C.K. Products carries several speed controls for brushless motors, internal air cooled and water cooled, forward & reverse, and forward only in several amp draws.
http://www.mackproductsrc.com/Speed%20Controls.htm
frankg is offline Find More Posts by frankg
Old Oct 09, 2012, 07:23 AM
nick_75au is offline
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
What brushed motor are you trying to replace?
Is it this plane?
http://www.hobbyzone.com/rc_planes_p..._stryker_c.htm
What sort of boat is it? what size prop are you trying to use? Basically the prop is too big for the motor and/or the voltage is too high. If its the plane in the link then I think the Motor Kv is too high for most boat use.
Getting an answer to these questions will enable some more useful help
Cheers
Nick
nick_75au is offline Find More Posts by nick_75au
Discussion Which esc question AliB Multirotor Electronics 4 Sep 04, 2012 04:51 AM
Help! swedish torpedo boat T47 "which outrunner, esc and prop?" 1275gt Scale Boats 11 Jul 28, 2012 05:30 PM
Discussion which esc's will work please help. jabba1 Multirotor Electronics 6 Jul 27, 2012 05:01 AM
Discussion Which ESC and motor for a XAircraft hex? totality Multirotor Electronics 6 Jul 13, 2012 10:31 PM
Question Which ESC??? escipion Dock Talk 6 Mar 05, 2012 12:20 PM
