Old Aug 20, 2012, 07:34 AM
davidmc36 is offline
Find More Posts by davidmc36
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Mini-HowTo
Injecting Glue
If you need to inject some Gorilla glue into a small gap or crack you gotta get some of these. Screw them on to a syringe, pull out the stopper, squirt some G-Glue into the syringe, then hold it with the tip up and push the stopper up into it until all the air is pushed out. (just like the doctors do in cheesy drama shows)
You need to put quite a bit of pressure on the syringe with the smaller tips to push the fairly thick G-Glue.
Also try some of these for harder to reach areas.
When you are done and the syringe is empty, pull it apart and wipe out the glue. Also squirt air through the tip to remove as much glue as you can. Disassemble everything and wipe the glue out. Then when it is sets, it pops right out so you can use them again if you need to conserve. The G-Glue doesn't stick the syringe or tip.
davidmc36 is offline Find More Posts by davidmc36
Old Sep 07, 2012, 05:23 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Bend the tip
And on the longer tips you can bend them a bit to get those really hard to reach areas.
Old Sep 07, 2012, 07:38 AM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Cranbourne East
Joined Apr 2004
What gauge did you find best for urethane glues ? good to know .
olmod is offline Find More Posts by olmod
Old Sep 07, 2012, 09:07 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
I mostly use 18ga. Good comprimise between small enough to fit gaps and big enough the glue is not too hard to come out. A couple sizes smaller will work decent too for small gaps, you just need to push a little harder or just push normal and hold it for a little while for the glue to ooze out.
Old Sep 07, 2012, 09:14 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
You can flatten the needle at the tip a bit to fit into smaller gaps without giving up overall cross-section.
Old Sep 09, 2012, 06:32 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Experiment
I tried a little experiment.
Even after several days all I had to do was poke a tiny hard spot from inside the end of the needle.
Old Oct 07, 2012, 11:39 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
If you want something similar to Gorilla Glue, I went to the small hardware store near me and they did not have GG, but they had some LePage's Ultimate. Same type only it is a bit thinner so will inject easier and it does not foam as bad. Tried a couple test pieces and it seems to hold fine.
Old Oct 07, 2012, 11:40 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
But after about three weeks the needle was hard all the way. The stuff in the syringe was still fine.
Old Oct 07, 2012, 02:23 PM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Little boo-boo there. It's Elmer's.
Question Glue glue glue... sticky, but which one? Hatoka Foamies (Scratchbuilt) 16 Jun 06, 2012 12:16 PM
Sold Used YS DZ160 direct injection engine 5478Jimmy Aircraft - Fuel - Engines and Accessories (FS/W) 2 Apr 14, 2012 01:58 PM
Discussion Transgender woman arrested after injecting Fix-A-Flat into patientís rear end Chophop Life, The Universe, and Politics 12 Mar 08, 2012 04:45 PM
Discussion Injection molded camera mount Joe Bennett Aerial Photography 3 Feb 23, 2012 09:43 AM
