Old Mar 08, 2013, 06:37 AM
lcc014 is offline
Find More Posts by lcc014
AMA Member # 458448
lcc014's Avatar
United States, MA, ALLSTON
Joined May 2011
Originally Posted by FyreSG View Post
My translation of the changes for ZYX-S:
1. Supports dual satellite receiver or dual S-BUS receiver (requires separate addon module ZYX20)
2. Supports governer (I think) (requires separate addon module ZYX20)
3. (Same as ZYX change #1)
4. (Same as ZYX change #2)
5. Adjust S-BUS receiver ordering of signal, changes to Futaba default ordering (if using S-BUS receiver, please reconfigure the ordering of the channels)
Very good translation
lcc014 is offline Find More Posts by lcc014
Old Mar 08, 2013, 06:39 AM
FyreSG is offline
Find More Posts by FyreSG
新加坡的飞儿
FyreSG's Avatar
Singapore, Singapore
Joined Apr 2012
Thanks. Is change #2 correct? I don't really know what's a governor and I'm guessing the Chinese words describing "fixing speed" is talking about the governor.
FyreSG is offline Find More Posts by FyreSG
Old Mar 08, 2013, 07:24 AM
FyreSG is offline
新加坡的飞儿
FyreSG's Avatar
Joined Apr 2012
The official v4.0 firmware binary is different from the v4.0 that Tarot sent me. I flashed it and... the violent servos came back! So, I'm back to the customized v4.0 now.
Old Mar 08, 2013, 07:38 AM
lcc014 is offline
AMA Member # 458448
lcc014's Avatar
Joined May 2011
Governor is to fix a head speed by either ESC or gyro (zyx) such that we just need to control the pitch of the heli. Throttle curves will be set to flat. I use it in my 250 with ESC governor mode.
Old Mar 08, 2013, 07:41 AM
FyreSG is offline
新加坡的飞儿
FyreSG's Avatar
Joined Apr 2012
Cyclic range
I tried the following settings and all gave me +/- 10 degrees of cyclic range on the bench, when I give full cyclic stick movements.
1. Aileron & Elevator Travel 70, D/R Rate 100%, Agility 45
2. Aileron & Elevator Travel 70, D/R Rate 100%, Agility 15
3. Aileron & Elevator Travel 70, D/R Rate 60%, Agility 45
4. Aileron & Elevator Travel 70, D/R Rate 60%, Agility 15
Observation: on the bench, D/R at 100% vs 60%; and Agility 45 vs 15, does not affect cyclic range.
Old Mar 08, 2013, 08:33 AM
lcc014 is offline
AMA Member # 458448
lcc014's Avatar
Joined May 2011
zyx 4.0 firmware
I just run zyx 4.0 setup software and found that it does support governor mode in Advanced Menu.
However, there is no entry to specific the desire head speed. It just has Governor gain, P, I, D gains and Calibrate RPM box. Governor is off by default. Does this mean zyx-s governor mode only support 1 head speed ?
Also, in the setup menu, I did not see any port in zyx-s for the connection to external rpm sensor. How does zyx-s track the head speed ?
My bad, I miss read the fact that we need a new extension module called zyx20 to support governor in zyx-s. However, I could not find this zyx20 in 0577mx.com - official Tarot website.
Ching-Ho Cheng
Old Mar 08, 2013, 08:50 AM
MikeHRC is online now
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Unfortunately it goes back to what we were saying before - FBL works differently to FB.
When you move the cyclic stick you are now telling the FBL unit to give a certain rate of turn, not a specific angle of swash - the FBL unit usually give lots of angle for a short period of time to get the rate of rotation requested. This is one of the reasons why FBL can be much more agile then FB, and why they need better servos.
The way in which it behaves on the bench is very different to how it behaves in the air - you have to forget some of the Flybar based ideas unfortunately
MikeHRC is online now Find More Posts by MikeHRC
Old Mar 08, 2013, 08:54 AM
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
My bad, I miss read the fact that we need a new adapter cable called zyx20 to support governor in zyx-s. However, I could not find this zyx20 adapter cable in 0577mx.com - official Tarot website.
Ching-Ho Cheng
Ching-Ho,
I have a Robird G31 with an internal governor - with that unit you run a set-up process for the G31 to learn your motor gearing etc. and then you set up your curves to give you a headpseed based upon what the G31 learnt in governor set-up. For example if the unit sees a maximum headspeed of 4000 in set-up mode, you can then set up flat "curves" of 75%, 80%, and 85% to give approx HS of 3,000, 3,200 and 3,400 HS.
I'm not sure if that is how the ZYX-S does it but that would be my guess
Cheers,
Mike.
Old Mar 08, 2013, 09:00 AM
lcc014 is offline
AMA Member # 458448
lcc014's Avatar
Joined May 2011
Originally Posted by MikeHRC View Post
Ching-Ho,
Cheers,
Mike.
Mike,
Thanks for the explanation. Up to now, I just use my CC ESC to setup governor speeds. The way Robird G31 works is new to me.
Ching-Ho Cheng
Old Mar 08, 2013, 09:09 AM
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Mike,
Ching-Ho Cheng
Yeah I have a CC on a couple of helis and it is quite different (setting the target HS via Castelink). The way that the G31 does it is the same as YGE and (I believe) Kontronic, a little bit more messing about but fine so long as you have a tach (or a smart-phone ).
Cheers,
Mike.
Old Mar 08, 2013, 09:12 AM
lcc014 is offline
AMA Member # 458448
lcc014's Avatar
Joined May 2011
Cheers,
Mike.
I have a tach So I can learn this new governor setup.
Ching-Ho Cheng
Old Mar 08, 2013, 09:24 AM
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
You're still "special"
Old Mar 08, 2013, 10:17 AM
sgbfly is offline
Find More Posts by sgbfly
Nottinghamshire, UK
Joined Dec 2009
It looks like the V4 software is officially released now - it even has instructions and release notes. Apparently the changes are ..
1. the stick response speed of the main rotor, add a burst coefficient of the main rotor, improve the performance of hard flight
2. Improve the stability of pirouette and hover flight
Get it here http://www.0577mx.com/news_view.asp?clsid=15&id=273
This is good news. I've updated the fw in a 450 & I'm looking forward to a test flight.
I'll probably only get chance for a hover in the back yard this weekend but by the middle of next week I'll know if anything bad happens in FFF
Simon
ps. Thanks for the swash movement vids guys.
sgbfly is offline Find More Posts by sgbfly
Old Mar 08, 2013, 10:22 AM
DJO is online now
DJO
Find More Posts by DJO
DJO
Custom FPV Setups
DJO's Avatar
United States
Joined Oct 2011
Sweet! I'll have to download it and see what kind of difference it makes
Dan
DJO is online now Find More Posts by DJO
Old Mar 08, 2013, 10:33 AM
DJO is online now
DJO
DJO
Custom FPV Setups
DJO's Avatar
United States
Joined Oct 2011
...now I can't get my ZYX-S to connect to the FBL Programmer, it was working fine when I first got it. Now, nothing at all, it simply won't connect!
Discussion New ALZRC 3GYS Flybarless System beenflying Mini Helis 644 Dec 07, 2012 04:44 AM
Found Tarot 450 or like, long flybarless feather shafts TubeBarHeli Aircraft - Electric - Helis (FS/W) 2 Jul 25, 2011 01:13 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 04:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 06:09 PM
Discussion Tarot Flybarless avengedkevinfold Electric Heli Talk 1 May 04, 2011 04:46 AM
