Old Jan 24, 2011, 10:28 AM
seaspb is offline
Find More Posts by seaspb
building season is here.
seaspb's Avatar
United States, OR, Silverton
Joined Nov 2008
f3f reflex use
During the drop in (first leg or two) I use reflex then switch to neutral. Should I keep in reflex or start with neutral and keep it there. We race coastal and inland sites. I think switching camber is far more critical at the inland slopes.
Thanks in advance.
Sam
seaspb is offline Find More Posts by seaspb
Old Jan 24, 2011, 11:08 AM
Brandon is offline
Find More Posts by Brandon
Brandon's Avatar
Riverside, California, United States
Joined Feb 2004
Hey Sam,
"keep in reflex"
B
Brandon is offline Find More Posts by Brandon
Old Jan 24, 2011, 12:47 PM
ceres-syd is offline
Find More Posts by ceres-syd
Joined Jan 2010
reflex will depend on your wing section.
some b models have very slight under camber, so a 32nd of an inch or so will suffice, but that depends on the model and wing section.
j
ceres-syd is offline Find More Posts by ceres-syd
Old Jan 24, 2011, 03:23 PM
Phil.Taylor is offline
Find More Posts by Phil.Taylor
Phil.T-tailer
Phil.Taylor's Avatar
Devon, UK
Joined Jun 2003
j
+1
some go faster with reflex, some dont, and some are slower
if yours goes faster with reflex, then suggest keep it in for the whole flight (but not the turns!)
Phil.
Phil.Taylor is offline Find More Posts by Phil.Taylor
Old Jan 24, 2011, 03:48 PM
roydor is online now
Find More Posts by roydor
In F3J size does matter!
roydor's Avatar
Israel
Joined Nov 2006
Optimal camber setting is a function of the lift coefficient (Cl) your airfoil is producing.
Diving in, your Cl is very low so reflex is required to reduce the drag.
On the straight, Cl is low so reflex is still a very good idea.
In the turns, the Cl is high, so no reflex or even a small amount of positive camber will be required to reduce the drag. The optimal amount depends on your flying style and how hard you pull on the stick.
If you "bank and yank" to produce a very high Cl you will need quite a bit of positive camber.
If you prefer a wide turn with a relatively small amount of elevator, a small amount of camber, if any, will be required.
A good idea is to set up a constant amount of reflex right from the start of the dive and to keep it on all the time.
Use "Snap flap" to set the right amount of camber that suites your flying style and try to find something you’re comfortable with.
roydor is online now Find More Posts by roydor
Old Jan 24, 2011, 03:49 PM
roydor's Avatar
Israel
Joined Nov 2006
Old Jan 24, 2011, 07:13 PM
seaspb is offline
seaspb's Avatar
Joined Nov 2008
I've snap flap mixed in.
Flying style, well I'm still developing that. I better keep a log of how I set my plane up and how I like it. to keep the guess work out of it. I've done this with my thermal flying, don't know why I hadn't thought of doing the same with f3f. Thanks for the info.
Sam
Old Jan 24, 2011, 07:22 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
For that Extreme, you probably want a little reflex when you are racing.
You might set up a flight phase with 1mm, and another with 2mm, and see what you like best.
You have to add snap flap though, if you run reflex, the same amount of reflex you add.
G/L,
Target
target is offline Find More Posts by target
Old Jan 25, 2011, 06:20 AM
Joined Jan 2010
The reflex that I had on my extreme was approx the width of the trailing edge plus a fraction.
I did a very low 36 with it.
Old Jan 25, 2011, 08:47 AM
ced_toulouse is offline
Find More Posts by ced_toulouse
France, Midi-Pyrénées, Toulouse
Joined Sep 2007
and Cx
Diving in, you don't care about Cl, you want the smallest Cx, so you set the camber for it to drag the least: it can be with or without Reflex depending on the airfoil, there is no general rule.
on the straight, you want to drag the least with enough lift: it can be with or without Reflex depending on the airfoil, there is no general rule.
no, it doesn't, if it does, your glider is centered to far back, and snap flap can't be properly tuned. when you tune your snap-flap, it has to be on "every" elevator travel: it usually ends up with a curve between flap and elevator.
the global idea is to keep Cx low in every point of the trajectory, to do so, you have to work on camber, but there is no general rule: experiment is the way to go.
all the more, reflex can also produce instability on some cases (stability on others...)
have fun!!
Cedric,
ced_toulouse is offline Find More Posts by ced_toulouse
Old Jan 26, 2011, 09:24 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Ced,
Be nice now....
I agree that the strategy for best performance is likely very different between F3J and F3F, but, I myself am on a campaign to be well liked here (I need to actively persue that!).
Please be respectful of others.
If my post is misplaced, and I'm reading in something that isn't there, my apologies, and please, please, disregard.
Kind Regards,
Target
Old Jan 26, 2011, 11:29 AM
Joined Sep 2007
Originally Posted by target View Post
Ced,
Be nice now....
Kind Regards,
Target
sorry if it sounds nasty, that wasn't my point
"general rules" scares me, because if applied, they often lead to wrong tuning, and the pilot doesn't understand why its glider doesn't work.
it is a bit like:
"- how much snap flap to use?
- 4mm!
- me too
- so it bumps out the turns!
- no, it's like I've put the handbrake on..."
everybody will have noticed that the 2 guys didn't talk about the elevator deflection related to the flap...
one thing is sure about camber:
- when you set more camber, the Cxmin usually goes up in Cl
- when you set less camber, the Cxmin usually goes down in Cl
so about Reflex, if in straight, you fly under the Cl of Cxmin, you have to put reflex (old RG14 for exemple).
if you fly at the Cl of Cxmin, you keep the airfoil.
if you fly above the Cl of Cxmin, you have to put flaps; usually in turns (load increases), but also if you are too heavy.
Cedric,
Old Jan 26, 2011, 05:10 PM
Doc Holiday48 is online now
Find More Posts by Doc Holiday48
I'm your huckleberry
Doc Holiday48's Avatar
USA, CA, Gardena
Joined Jun 2004
experimentation has always worked best for me with regards to reflex and camber. My old Acacia and Sting seemed to love reflex, especially in strong lift conditions. My Ceres on the other hand did not seem to benefit at all from reflex. Airfoil seems to me to be a big factor. I always had snap flap activated when using reflex, so pulling turns were not affected by the reflex. I don't know a lot about the science so I will stop here. JMO!!
Bob
Doc Holiday48 is online now Find More Posts by Doc Holiday48
Old Jan 27, 2011, 02:33 AM
Zimodile is offline
Find More Posts by Zimodile
Leicestershire
Joined Sep 2006
I always found it hard to notice the difference. But that's probably me. BUT the one thing I noticed with all models is that in very turbulent conditions, the reflex always seemed to damp the model a little bit and calm it down through the straight. Anyone else found this? And why (Ced? Happy New Year btw mate!)
Z
Zimodile is offline Find More Posts by Zimodile
Old Jan 27, 2011, 06:43 AM
Joined Jan 2010
Standard ceres run no reflex.
Ceres lift and Cyril I run around 1/16th of an inch.
Discussion F3F/MoM/slope... Rudder, do you "really" use it? THUREN Multi Task F3X 24 Sep 28, 2007 01:09 AM
Question Airfoil camber/reflex info and use mdennis Thermal 3 May 26, 2006 12:00 PM
Discussion Can I use Reflex Dongle on anything else? muscleflex Simulators 1 May 26, 2006 11:07 AM
Question Can i use the Simulators(Reflex) in my evo12? coldsteel Hitec/Multiplex USA 1 Apr 25, 2005 01:17 PM
most basic TX for use with Reflex XTR? trickyrik Simulators 6 Feb 23, 2005 10:37 AM
