Old Nov 01, 2010, 01:16 PM
guyg is offline
Find More Posts by guyg
Israel, Ness Ziona
Joined Sep 2004
Just before the test flight- GAUI 33XS Config problems
HI
In 12 houres- Test flight
All motors are config
As i can see on VERY LOW POWER.. motors are not slow turn
Suddenly power with no stick move turns HIGH!
No low power on motors and not all on ground are turning on same power-
with all radio sticks On nutral.
What should be the config to AIRTRONICS RD6000 i fly with
not as for CH no ...More into AILE ELEV THRO RUDD NORM\ REV
As in the Quad book.
Checked all connections motors turn directi As i have done all esc
brake - ON
Battery type- lipo
cutoff mode- Reduce power
cutoff threshold - Medum
Startup mode Normal
Timing- Medium
Could be i should have left it as it came from Gaui ( all ESC)?
I do fly CROSS shape ( sw on Gyro) - config on the Gyro
Bypass on - gain at 90 deg and Sw at cru
Can someone that fly this bird can help please
TX
Guy
guyg is offline Find More Posts by guyg
Old Nov 01, 2010, 01:40 PM
guyg is offline
Israel, Ness Ziona
Joined Sep 2004
Dose anyone know the correct ESC settings for the motors?
GUY
Old Nov 01, 2010, 03:54 PM
guyg is offline
Israel, Ness Ziona
Joined Sep 2004
OK OK..No Panic
I drove to OFER my friend.
There we have found out that:
I am using a 3S lipo and the voltage is too powerful as minimum power the bird takes off.
As i DO NOT HAVE 2S lipo
We took 3S bat and made it 2S..
Then in half way motor power up - The bird only STARTS to hover..
All works OK and at morning time here- Test flight
BUT... weight of the bird is with bat- 600 gram
As is GAUI document wrote
From 550 grams - you can use 3S bat...??? interesting..
As for the moment i have ONE 1 Bat 2S only
I will update about the test flight with ground pics
TX
Guy
Old Nov 01, 2010, 08:11 PM
randall1959 is offline
Find More Posts by randall1959
Joined Feb 2004
They fly just fine on 3s
You have to set your epa to 80 percent. I fly mine on 3000 ma 3s all the time.
randall1959 is offline Find More Posts by randall1959
Reply With Quote  (Disabled)
Discussion Thrush Commanders & Cropdusters- Just before Holiday- AP guyg Aerial Photography 4 Sep 22, 2010 04:33 PM
Discussion AP- Test before Sunsets guyg Aerial Photography 0 Sep 22, 2010 10:36 AM
Discussion New A/P Platform..Paraplane..Changes Before LAST Test flight update guyg Aerial Photography 17 Sep 13, 2009 09:36 AM
Discussion Any tips before the test flight of the Mini Slinger? divebudd Flying Wings 5 Dec 01, 2006 01:59 PM
My Before First Flight Hover Test. fly4fun 3D Flying 19 Feb 09, 2005 12:39 PM
