Old Apr 08, 2013, 03:06 PM
Goody63 is offline
Find More Posts by Goody63
How close are those trees?
Goody63's Avatar
Perth, Western Australia
Joined Apr 2008
Originally Posted by DeeCee 57 View Post
agree with capt soap here... used mine a couple of times, but it's been more hit & miss than anything else.
I think my biggest problem is to get a constant RPM on the fan. Been using the remote with the power index on the lever, not precise enough... what are u guys using to set a constant RPM between the runs?
Thanx
I have my best results using a spare receiver and my transmitter. Dont forget to use a reduced number of cells lipo (ie 3 cells or less for a 4 cell motor). Helps with keeping a nice low rpm.
Goody63 is offline Find More Posts by Goody63
Old Apr 09, 2013, 03:07 AM
DeeCee 57 is offline
Find More Posts by DeeCee 57
Life's short - Enjoy!
DeeCee 57's Avatar
Zurich, Switzerland
Joined Nov 2009
Thanx Demon & Goody
Goody, it's what I did too, but just could not repeat the RPM from run to run. Using the index mark on my transmitter throttle lever produced different RPMs from run to tun. Not talking about huge differences here, but I would like to be able to reproduce runs at a same RPM.
How does one measure RPMs on a EDF?
Just acquired a Multiplex MULTImate to be used for some programming, guess I could use that for the task as well?
DeeCee 57 is offline Find More Posts by DeeCee 57
Old Apr 09, 2013, 03:47 AM
anlucas is online now
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
I use a 2S lipo and I can get consistent low rpm with a servo tester confirmed by ear. This means usually 1 or 2 steps above 0 throttle.
anlucas is online now Find More Posts by anlucas
Old Apr 10, 2013, 10:33 AM
Alan Hahn is offline
Find More Posts by Alan Hahn
Chicago 'burbs
Joined May 2006
Thanx Demon & Goody
The easiest way to measure rpms is with a logging ESC, like a CC ICE ESC. Although I haven't used it, it has a live mode (using the USB cable to the ESC) that will get the rpm to your PC screen.
Also if you setup a governor (like "Set RPM" in Heli mode) you can always hit that same rpm, as long as it is actually achievable given the motor Kv, pack voltage, and load of course.
Alan Hahn is offline Find More Posts by Alan Hahn
Old Apr 10, 2013, 11:15 AM
DeeCee 57's Avatar
Zurich, Switzerland
Joined Nov 2009
Anlucas, thanx but this is what I was doing, I must didn't get constant results, probably loosing some hearing with age
Alan, that seems a very good idea and I will sure try it as well (gotta reinstall Windôze on my Mac first...). I'm using Castle ESCs for the expensive models anyway
Old May 05, 2014, 12:35 AM
T-CAT is offline
Find More Posts by T-CAT
T-CAT's Avatar
Joined Aug 2008
Anyone that still have one of these balancers in perfect working order and condition that wants to sell it? I'm looking for one and I missed out on the opportunity to buy Dons.
T-CAT is offline Find More Posts by T-CAT
Old Jun 15, 2014, 11:32 AM
Bob Blackburn is offline
Find More Posts by Bob Blackburn
Bob Blackburn's Avatar
UK, Greater Manchester, Manchester
Joined Jul 2004
Just a note to let people know the MK3 version is out and available to order now.
Bob Blackburn is offline Find More Posts by Bob Blackburn
Old Jun 15, 2014, 12:41 PM
anlucas's Avatar
Joined May 2011
Bob,
Looks nice. I like the new holder which should allow for easier mounting of the fans.
Apart from the visible differences, are there any other differences internally?
Old Jun 15, 2014, 01:01 PM
Joined Jul 2004
Originally Posted by anlucas View Post
Bob,
Anlucas,
No radical changes.
Sensitivity is the same.
There is now a usb socket on the front so aftermarket usb lamps can be fitted
The battery holder is now cradled and can be unclipped to replace batteries (less fiddly battery replacement)
The boxes and beams will be available for experimenters if they wish.
I am working on how to kit but skill level required is still too high i think.
Old Jun 15, 2014, 02:42 PM
cquian is online now
Find More Posts by cquian
USA, TX, The Colony
Joined Dec 2005
Great, just ordered one
cquian is online now Find More Posts by cquian
Old Oct 03, 2014, 10:24 PM
antslake is offline
Find More Posts by antslake
How high will it go?
antslake's Avatar
Greenwood Lake NY
Joined Oct 2003
Just ordered one, wish me luck!
antslake is offline Find More Posts by antslake
Latest blog entry: Plastic prop repair
Old Feb 03, 2015, 02:17 AM
dinuc is offline
Find More Posts by dinuc
Joined Nov 2014
Hi Bob,
Would this be adaptable for use with an outrunner motor and propeller ?
I would buy one immediately if it can be.
thanks
Andrew
dinuc is offline Find More Posts by dinuc
Old Feb 06, 2015, 12:45 PM
Joined Jul 2004
Yes it is possible to use to balance a motor and prop I have done so.
It will need a lightweight structure making to mount the whole lot on the beam with the prop high enough to rotate and an rpm that doesn't produce any appreciable thrust.
Practice with a solid disc of thin plywood or thick card initially then you can interpret what the balancer is showing you.
Balance the motor first then add the statically balanced prop.
Before balancing the two together.
Old May 01, 2015, 05:07 AM
Daniel F EDF is offline
Find More Posts by Daniel F EDF
Slovakia, Banská Bystrica Region, Banská Bystrica
Joined Feb 2015
Hi,
I plan to buy this balancer. Did ever compete instruction video materialized? I have read every single post in this thread but still have some confusion mainly in first steps-
1, making white mark-for orientation in future weight adding??
2, than the balancer will show the heaviest place on the spinner
3, now my biggest confusion-when I stop the fan-how do I locate the heaviest place-so I can ad weight to opposite side?
P.S.: Bob, thanks for bringing such a great, helpful and affordable device to our world... It is very frustrating to ask my rc friends to balance my edf's... They are busy and there is no service around that would help me with balancing even when I want to pay...
Daniel F EDF is offline Find More Posts by Daniel F EDF
Old May 08, 2015, 07:58 PM
antslake is offline
antslake's Avatar
Greenwood Lake NY
Joined Oct 2003
Originally Posted by Daniel F EDF View Post
Hi,
It is a bit confusing and the instructions can be better. The balancer has no way of knowing the position of the fan. So the way you use it goes like this:
1. First, try to get the fan running as smoothly as possible by rotating the blades on the shaft 90° at a time. Pick the one that is the smoothest and fine adjust until it is running as smooth as possible. Just do this by feel, no need for the balancer yet. Then add the nose cone, and do the same thing.
2. Now mount up your balancer using a cushion between the bracket and fan housing. Take the bracket off the balancer while doing this. Start with the knob fully counter clockwise. Make a mark on the nose cone that shows up in the strobe. Add a small amount of weight starting at the mark (12 o'clock) at 12,3,6,9 o'clock position and run it with the strobe on each time. You will see the line in the strobe. Remember that location. where that line is, and where the weight is, IS your heavy spot. The actual spot is where the weight is, you reference is where the line is. You add weight to the opposite side of the "heavy side". start with a pinch and play around with the weights until the strobe goes out. Start turning the knob clockwise and add or subtracting weight.
i.e. lets say I get the fan balanced as much as possible by rotating the blade and cone, then it is on the balancer. I run the extra weight and notice that the line is in the 12 o'clock position, but the extra weight I added is in the 9 o'clock position. That tells me, when the line appears at 12, the heavy side is at 9, so I need to add weight to 3 o'clock. So now I take off the extra weight, run it, and the line shows up at 3 o'clock. The heavy side is still at 9 o'clock, and I still need to add weight to the 3 o'clock position. So in this case I would add weight right where the line is.
P.S. I will balance your fan for $10 plus shipping, which is usually around $6.
MF 480 rotor balancing Olivier Electric Ducted Fan Jet Talk 2 Sep 13, 2010 01:00 PM
Sub-Rotor balancing on Corona Orion_V Electric Heli Talk 11 Jun 27, 2003 09:46 PM
Corona Sub Rotor Balancing ??? johnitahoe Electric Heli Talk 2 May 26, 2002 06:42 PM
Balance GWS EDF-50 Rotor GoEFlight Electric Ducted Fan Jet Talk 0 Apr 02, 2002 10:08 PM
Rotor Balancing WKoltis Electric Heli Talk 4 Nov 02, 2001 12:05 PM
