Old Mar 24, 2009, 04:23 PM
davidtb is offline
Find More Posts by davidtb
Joined Mar 2009
I need help, please, for new plane
hello my name is David from Spain ( I am sorry for my inglish )
I will build a twin-engine plane. ( bimotor )
I need to know how to connect the two motors at once.
I need 2 ESC??
I need 2 receivers??
Please help me
I hope your reply
Thanks for read this post
davidtb is offline Find More Posts by davidtb
Old Mar 24, 2009, 04:32 PM
bazuka is offline
Find More Posts by bazuka
Pro Bro #2277
bazuka's Avatar
Longmont, CO.
Joined Feb 2006
davidtb,
If you are going brushed then you will need only one ESC, as long as it can handle the amp load of the motors.
If you are going brushless you will need two ESC.
Only one receiver required since you can use a "Y" connector, see attached picture from a GWS manual.
bazuka is offline Find More Posts by bazuka
Old Mar 24, 2009, 04:46 PM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Great reply and help Bazuka! GWS Manual picture great way to show how to. Just make sure you do enough research brushed or brushless as to matching amp rating between motors, ESC's, and battery.
Good luck, twins are my all time favorite followed by biplanes.
Freddie B.
Freddie B is offline Find More Posts by Freddie B
Old Mar 24, 2009, 04:48 PM
davidtb is offline
Joined Mar 2009
Thanks very much for the reply
ok I use brushless motors
I understand I need 2 ESC, and use only one conector for the two ESC
is correct ?
Old Mar 24, 2009, 06:43 PM
Xpress.. is online now
Find More Posts by Xpress..
Hitec RCD CSR
Xpress..'s Avatar
United States, CA, Alpine
Joined Oct 2007
Yes. You need to use a non reversing Y-connector. Also, do not forget to disable the BEC on one of the ESC's or you could fry the reciever! (the BEC is what powers your radio system on an electric aircraft). You can pull out the red wire on one ESC, and tape it back with electrical tape to disable it.
Xpress.. is online now Find More Posts by Xpress..
Old Mar 24, 2009, 07:03 PM
davidtb is offline
Joined Mar 2009
ok thanks very much
Old Mar 25, 2009, 04:38 PM
Doug Sipprell is offline
Find More Posts by Doug Sipprell
Elfi Flyer
Doug Sipprell's Avatar
Rock Hill, SC
Joined Oct 2002
Thanks for this info. Could you clarify what you mean by a non-reversing Y-connector? I have used Y-connectors on dual aileron applications (one servo per aileron), but have never tried a dual brushless motor set-up before, something I need to learn for a pending project.
Thanks.
RD
Doug Sipprell is offline Find More Posts by Doug Sipprell
Latest blog entry: Big Red Cadillac
Old Mar 26, 2009, 01:10 AM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Most 'Y' harness connectors are non-reversing, in other words all leads of the same color (+/-/signal) are tied together. A reversing 'Y' as stated reverses the leads so the servos will move in the same direction as needed in dual elevator servos or flaps where you do not want to flip the servo around (or in ailerons we put the horns both facing in, or facing out).
Simply the 'Y' harness is for the servo lead ends from the ESC so they can both get signal from the throttle channel of your receiver. The BEC function sends power to the receiver so you do not need a seperate flight pack to power the radio function. The reason to disconnect a 'red' lead to one ESC is so two BEC functions are not both sending power to the system.
Not to get too confusing, some ESC's like Castle Brand CAN have both red leads connected causing both BEC functions to remain active, actually increasing the amps to the receiver with no harm (2x 3 amp BEC actually puts out 1 1/2 the rated amps, or approx 4.5 amps). I do not know if other brands work the same, and probably would take the standard advice and remove one red lead! Bect way is to lift the plastic tang in the connector with a #11 blade and pull the lead out, tape it, and it remains to be put back in later if you need the device for anotherr project. Often the suggestion is to cut one lead, but I can't cut anything if it is going to destroy it's intended function for later!
If your twin project is large enough to handle the extra weight, the best way is to disconnect both red leads to the 2 ESC's (you will still use the 'Y' harness to get signal from the RX) and use either a seperate flight pack, or the new regulated BEC devices. The reasons for this are many, including the some rare instance where a glitch may show up in the system that defies explination. Further a ESC with BEC is only good up to 3 cell Lipo, or 10 cell NiMh/NiCd. The higher voltages are too much for these tiny devices to handle. Now we would have a system where you could go to larger cell count (as long as the ESC is rated for higher volts), using less amps, and acheiving longer flight times or smaller battery size.
The subject could encompass a book I'm sure, but in reality it is done every day quite simply. Enlarge the GWS drawing in post #2 above, study it carefully and I think it will all make sense. The GWS picture just doesn't show the 'Y' connector clearly (3 wires) but the concept is right on. Just remember that 1 red connector rule, 3 Lipo or less, and you should be OK.
Old Mar 26, 2009, 10:23 AM
Elfi Flyer
Rock Hill, SC
Joined Oct 2002
Freddie:
Many, many thanks for your tutorial. It all makes very good sense. I am favoring the idea of a separate battery pack or one of the UBC devices for the twin project. This is all very much in the distance at this point, but the information you have provided is most valuable. I am considering the use of a 2-cell Lipo for the separate battery pack, provided I can find a way to knock the voltage down to around 6V to accommodate the servos.
I was surprised to find an ESC that was capable of handling 2 - 6 Lipos. It's a Venom V-Series 60 amp unit, used on my biplane, powered by an E-flite 32 brushless outrunner, on a 4-cell 4000 mAh MaxAmps Lipo pack. I thought I would need a UBC of some sort in order to get the volts needed to spin the EF-32 properly, 11x7 prop, pulling the 4.5 lb AUW of the plane. Then I read the instructions for the Venom ESC and was surprised at the specs. The system works fine!
Thanks again for your info. Feel free to "teach" anytime you want!
RD
Old Aug 06, 2009, 07:41 AM
jamodu75 is offline
Find More Posts by jamodu75
Joined Jul 2009
Hello
grettings from venezuela, if somebody can helpme, i need plans of any twin motors (bimotor), i want to built one these.
Thank
my email: jamodu75@gmail.com
jamodu75 is offline Find More Posts by jamodu75
Discussion Need power system for new plane. roosevelt Power Systems 22 Apr 24, 2007 09:12 PM
Help! Need help finding a new plane! newkid 3D Flying 4 Sep 13, 2006 05:48 PM
need help looking for new foam tires Workharder On-road Cars 0 Jan 30, 2005 09:48 PM
Question HELP Suggestions for new plane please stuartm Electric Plane Talk 4 Jun 28, 2004 10:34 AM
Need help looking for new charger... ScYcS Batteries and Chargers 8 Feb 06, 2004 09:00 AM
