Closed Thread
Old Nov 30, 2012, 09:20 AM
fly to the moon :)
aeroseb's Avatar
Canada, QC, Terrebonne
Joined Apr 2009
Whoops!
Any idea about what caused this crash ?
crashshort (0 min 11 sec)
The lipo (nanotech 5000mah 3s 20c) was still good (11.7v) after the crash.
I dont know why but it happened 200m from launching point. Also i dont understand why the failsafe mode didn't do his job cause all was well set. (on the naza and on the frsky rx) I broke many parts and i'm afraid to fly again now....
Any similar crash anybody? What would explain this power suddenly power failure?
Solar disturbance ? Lipo issue ? frsky diy module tx (or rx) defect? Conflict between vtx bevrc 500mw 5.8ghz and naza or rx ?
Thank you
aeroseb is offline Find More Posts by aeroseb
Old Nov 30, 2012, 09:22 AM
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
It just turned off itself in mid-air?
WiseDuck is online now Find More Posts by WiseDuck
Old Nov 30, 2012, 09:29 AM
deno6031's Avatar
Turkey, Izmir
Joined Oct 2011
What is your complete setup?(motor, esc etc.)
deno6031 is online now Find More Posts by deno6031
Old Nov 30, 2012, 12:44 PM
United Kingdom, England, Cambridge
Joined Aug 2012
Battery terminal soldering?
Jmm_jammy is offline Find More Posts by Jmm_jammy
Old Nov 30, 2012, 02:46 PM
Anything can be made to fly
echo75's Avatar
Denmark, Capital Region of Denmark, Brondby
Joined Jun 2011
Sounds like a power cut to all motors at once, either your battery connector got loose or one of your solders gave.
echo75 is offline Find More Posts by echo75
Old Nov 30, 2012, 02:48 PM
DashieBrad's Avatar
Joined Nov 2012
Painful to watch
What kind of system was it? What was the damage?
DashieBrad is offline Find More Posts by DashieBrad
Old Nov 30, 2012, 02:52 PM
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Sounds like a brown out... How are you supplying power to the receiver?
jasmine2501 is offline Find More Posts by jasmine2501
Old Nov 30, 2012, 04:16 PM
danger_mouse's Avatar
Australia, QLD, Gatton
Joined Jan 2007
When you got to the crash scene, was the battery still connected? If so any life from the electronics?
Is your Frsky system of the telemetry type? Did the module beep at all?
Did you check your battery/powerboard connectors by wiggling them for intermittent connection?
danger_mouse is offline Find More Posts by danger_mouse
Old Nov 30, 2012, 05:26 PM
Rocket Programmer
Joined Jul 2007
You can hear it coming back on in the video, that's why it sounds like a brown out to me.
Old Nov 30, 2012, 05:39 PM
I'm New
unfaix's Avatar
United States, TX, Arlington
Joined Mar 2012
@jasmine could it be just the propellers spinning backwards agains the wind?
man that does suck though.
unfaix is online now Find More Posts by unfaix
Old Nov 30, 2012, 06:05 PM
Joined Jan 2007
That is what it sounds like to me, the props freewheeling backwards during the drop.
And yes, it really does suck. Post crash diagnosis can be difficult.
Old Nov 30, 2012, 06:14 PM
Denver, CO
Joined Dec 2005
Was that a Naza with GPS. If it had GPS, I would check the failsafe function. Might need to measure the signals the receiver is actually putting out. A servo plugged in could do it, if you don't have an oscilloscope.
Did act like a range issue.
Roto Rob is online now Find More Posts by Roto Rob
Old Nov 30, 2012, 07:09 PM
Mortimer's Avatar
Joined Apr 2010
How far from you was your copter when this happened ?
Mortimer is online now Find More Posts by Mortimer
Latest blog entry: 5V Power Supply
Old Dec 01, 2012, 08:50 AM
fly to the moon :)
aeroseb's Avatar
Joined Apr 2009
hello and thank you guys for the replies. Sorry, i dont have replies notification on my email. (dont know why).
Ok, so first of all, the set-up is bumblebee quad, stock motor 930kv and stock prop with 4x rctimer w/simonk 20a esc. I have to say that's no prop failure, nor esc issue. Got naza+gps, frsky diy module in the tx futaba t7cap and v8r7sp rx.
For the FPV, i got the turnigy cam HK 700L and bevrc vtx 500mw 5.8ghz with rc305 vrx. Lipo for quad was Turnigy nano-tech 5000mah 3S 25~50C + lipo for vtx bevrc is Turnigy nano-tech 850mah 3S 25c.
I crashed arround 200-300m away from takeoff....very surprising. It falled on a arm so mounting motor is broken in 3 pieces. Esc is knock-off with the impact, the battery with the impact was unplugged because it's support broke. All the prop are ok.
On my opinion, i couldn't say it's range issue about the distance. For the solders, maybe, but i'd be surprised... What i observed is the area is a track used for some truckers of sand quarry and i know they use CB or some RF com. device that's why i had in the past some top radio failure in the 2.4ghz while flying with my easy star with the vtx in 2.4ghz. And now, it's not anymore my vtx problem (i,m in 5.8ghz) but the 2.4ghz band with the tx frsky that seems to be the problem.
Starting for this explanation, a question comes in mind : I had the failsafe in naza well configured (i even made tes in the past while cuttoff the tx and the quad retrun to home). Why the quad didn't go into fail safe mode? I have to say i disabled the naza lipo protection for many reasons. But if the lipo was dead, it is supposed to stop suddenly all power like this? Dont think so.... The lipo after the crash said 11.7v.
Old Dec 01, 2012, 09:44 AM
fly to the moon :)
aeroseb's Avatar
Joined Apr 2009
Got a question : Does any device exist that indicates frequencies used in a range from 1mhz to 8ghz, to show if some other devices use the same band frequency than me ? That could be avoid any crash due to RF conflict...
Closed Thread
Discussion What could be cause of this crash? makind Beginner Training Area (Aircraft-Electric) 53 Jan 02, 2013 11:28 AM
Discussion Any ideas on what this problem is.... steveap1 Beginner Training Area (Heli-Electric) 16 Jul 19, 2012 01:52 PM
Discussion Any ideas what this is? uncledale Sailplane Talk 11 May 27, 2012 06:42 AM
Question Any ideas as to what caused this? lyonsks Beginner Training Area (Aircraft-Electric) 10 Nov 13, 2006 06:29 PM
Any Idea what caused this? sarge Parkflyers 6 Dec 20, 2003 04:44 PM
