Old Oct 20, 2004, 10:46 AM
Up&Away is online now
Find More Posts by Up&Away
The original Flying Pigs Sqd.
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
Mega 1615/4 wiring
I just received my new Mega BL setup to replace my sp400. Which color wire do I attach where to the motor? Is there a particular sequence?
Thanks.
Up&Away is online now Find More Posts by Up&Away
Old Oct 20, 2004, 12:50 PM
777 is offline
777
Find More Posts by 777
777
Bought at a price.
Winfield, Kansas, United States
Joined Jul 2002
What ESC are you using?
Does this motor have the wires coming from it or simply tabs onto which you solder the esc wires? I have one of each.
Assuming that you're using a Phoenix 25 or 35 & using this on your Unicorn (In a pusher configuration as I am), they are;
black - towards left wing
white - middle
red - towards right wing
The good news is, is that if the motor does happen to run in the incorrect direction, simply reversing any two wires will cause it to turn in the opposite direction.
Brad
777 is offline Find More Posts by 777
Old Oct 20, 2004, 01:07 PM
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
Phoenix 35
Three tabs
Yup. Still renovating though...
Thanks! Going to the LHS tomorrow to get some more MPX male & female plugs.
Old Oct 20, 2004, 03:26 PM
777 is offline
777
777
Bought at a price.
Joined Jul 2002
Oh, of course, the left/middle/right directions that I gave are assuming that you are placing the motor so that the tabs are towards the bottom of the wing & the Mega label on top.
That would make a difference, wouldn't it?
We've always wanted to go to Israel. I understand that there is some strife going on in some areas. Are there areas that should be avoided by tourists?
Brad
Old Oct 20, 2004, 03:37 PM
MTwallet is offline
Find More Posts by MTwallet
Gotta have more cowbell!!
MTwallet's Avatar
Clawson, MI USA
Joined Sep 2002
777,
You forgot to ask... Is DD or in a GB? Is it pusher or tractor.
Up&away,
Just hook it up and see which way it goes, if it turns the wrong way (you're not gonna hurt the motor) then switch any 2 (TWO) leads and it will turn the opposite way. For ease I usually put the white wire in the middle too like 777 said then I just swap the two outer wires (red and black).
MTwallet is offline Find More Posts by MTwallet
Old Oct 20, 2004, 04:02 PM
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
You shouldn't believe everything you see/hear in the media. Yes there are areas to be avoided, just like there are areas in LA, or Detroit, or New York, or ....(fill in the name of any large area anywhere in the world...) You wouldn't cross a busy intersection with your eyes closed would you? Actually, statisticly, the chance of being involved in a traffic accident anywhere in the world, is bigger then the chance of being involved in a terrorist attack in Israel.
Come on over, there is plenty to see/do. To sweeten the deal, I'll let you fly my renovated Unicorn (! )
Anyway, this is what Bishop Products wrote me:
There is no polarity on brushless motors so simply hook up the wires and test the motors rotation. If it rotates the wrong direction simply reverse any two wires and it will rotate the correct direction now.
Old Oct 20, 2004, 04:20 PM
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
Originally Posted by MTwallet
777,
It's a Unicorn = a pusher
Old Oct 20, 2004, 07:16 PM
777 is offline
777
777
Bought at a price.
Joined Jul 2002
Up&Away,
I may just take you up on that! Heck, I'd even pack in my 'Corn if I can find a way & we can try one another's plane!
About the rotation part, it's good to see that I had that right when I said
MTwallet,
Since Up&Away and I frequent the Unicorn threads, we had actually covered that.
Old Oct 20, 2004, 07:29 PM
MTwallet is offline
MTwallet's Avatar
Clawson, MI USA
Joined Sep 2002
O, I didn't know you knew each other. I get around here but haven't looked at very many Unicorn threads.( not that is not a good plane I just have too many wings already)
And I didn't notice the pusher config part before. sorry
Old Oct 20, 2004, 10:40 PM
777 is offline
777
777
Bought at a price.
Joined Jul 2002
As much as a guy from Israel and a guy from Kansas can know each other
Old Oct 21, 2004, 01:52 AM
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
We didn't go to school together. Let's leave it at that... :-)
MEGA 1615/4 and Mini-fan 480 - what plane? Speed E Freak Electric Ducted Fan Jet Talk 3 Jul 17, 2003 04:17 PM
Ripmax Alliance with MEGA 1615/4? Speed E Freak Sport Planes 6 May 14, 2003 01:44 PM
WTB: Mega 1615/4 sanctioner Aircraft - Electric - Airplanes (FS/W) 0 Dec 10, 2002 11:56 PM
mega 1615/4 jeti 30amp esc Q-HUNTER Aircraft - Electric - Airplanes (FS/W) 8 Nov 11, 2002 05:56 PM
Mega 1615/4 performance / prop size Speed E Freak Power Systems 16 Sep 30, 2002 04:04 PM
