Old Aug 22, 2014, 11:44 AM
Killerofplanes is offline
Find More Posts by Killerofplanes
United States, GA, Twin City
Joined Oct 2013
Need .40 Sized ARF for Short Grass Field
What is a good .40-sized ARF for a short grass field? I have a Tweety .40, but it comes in too hot to get it whoa'ed up before I run out of runway.
Killerofplanes is offline Find More Posts by Killerofplanes
Old Aug 24, 2014, 02:45 PM
bigoof is offline
Find More Posts by bigoof
Destroyer of Balsa
bigoof's Avatar
United States, FL, Port Orange
Joined Aug 2012
Are you running nitro or elec. I just maidened mine today running the suggested G32 Gforce motor and the 12x6 pro and i thought it was a dog. Very stable but by no means a speed demon.
bigoof is offline Find More Posts by bigoof
Old Aug 24, 2014, 03:12 PM
Cherokee Flyer is offline
Find More Posts by Cherokee Flyer
Cherokee Flyer's Avatar
United States, KS, Rose Hill
Joined Sep 2007
Get one of the "ugly stick" type airplanes and set it up with flaprons, they are a hoot! The Great Planes 40 size is a good flyer.
You might want to look at a flater pitch prop too, that will slow down the approach speed of what you are flying.
L.
Cherokee Flyer is offline Find More Posts by Cherokee Flyer
Old Aug 24, 2014, 06:34 PM
Joined Oct 2013
I'm running a .46 ASP Nitro. The problem is magnified because there are trees at either end you have to drop down over.
Old Aug 24, 2014, 06:40 PM
Joined Oct 2013
L.
I've been looking at them (Ugly Sticks), I'll try the flatter prop first. Thanks for the tip. I'll try the flaprons, too.
Old Aug 24, 2014, 09:09 PM
Joined Sep 2007
Remember flaprons can go both ways, so they can operate as spoilers too. Try that at least two mistakes high! It works. If you are using a computer radio, set the elevator up with the spoilers to control your rate of decent. Also set the timer in the flap section so they are slowed down, I usually use 4 seconds that makes them gentler on the airframe.
Enjoy
L.
Question what kinda luck u guys havin with retracts and short grass field on 70mm edf gregka Electric Ducted Fan Jet Talk 3 Feb 13, 2012 11:12 PM
Discussion JET size for short grass? Vibe Ration Foamy EDFs 6 Mar 28, 2010 08:01 AM
Discussion Need plane for park that can ROG on short grass bluemeane Parkflyers 5 Jul 15, 2009 06:57 PM
Discussion PETE** Need plane for park that can ROG on short grass bluemeane Banana Hobby 2 Jul 09, 2009 04:01 PM
