Old May 22, 2013, 10:29 AM
arrowshooter is offline
Find More Posts by arrowshooter
United States, CA, Modesto
Joined Aug 2012
Question
Platinum Pro ESC Settings
I just picked up a Hobbywing Platinum Pro 40A esc to run with a Hobbymate 3800VK motor in a 450 and I am wondering where I should set the Timing and PWM Frequency? The timing has 8 options from 0 degrees to 26.25 degrees and the PWM can be set at 12KHz or 8KHz. I am only a circle flyer, no tricks, but I do like fast. Thanks in advance for your help.
arrowshooter is offline Find More Posts by arrowshooter
Old May 22, 2013, 02:31 PM
P.I.Engineer is offline
Find More Posts by P.I.Engineer
P.I.Engineer's Avatar
United States, CA, Redondo Beach
Joined Mar 2005
12khz and 18.75 for timing, usually works the best
P.I.Engineer is offline Find More Posts by P.I.Engineer
Old May 22, 2013, 02:56 PM
Joined Aug 2012
Thank you.
Discussion Question on Hobbywing Platinum Pro ESC JamesBC Multirotor Electronics 33 Oct 11, 2014 12:55 PM
Discussion Platinum Pro ESC Settings arrowshooter Mini Helis 0 May 21, 2013 01:22 PM
Sold Hobbywing Platinum Pro 40A ESC $30 Shipped Dizzante Aircraft - Electric - Power Systems (FS/W) 1 Apr 30, 2013 10:28 PM
Wanted Hobbywing Platinum 60a ESC & LCD Pro Program Box Capt. Thomas Aircraft - Electric - Power Systems (FS/W) 0 Apr 12, 2013 07:03 AM
Sold HobbyWing Platinum PRO 150A-OPTO ESC w/ 5A BEC - $80 shipped nuttcaze Aircraft - Electric - Power Systems (FS/W) 1 Jan 09, 2013 03:18 PM
