Old Apr 03, 2013, 01:59 PM
rlfgary is offline
Find More Posts by rlfgary
rlfgary's Avatar
Red Lake Falls, MN
Joined Aug 2004
Question
Still wrapping rx's in foam on fuel planes?
I know most people no longer do this on electrics. What about fuel planes? Why? Why not?
rlfgary is offline Find More Posts by rlfgary
Old Apr 03, 2013, 02:04 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
With 2.4Ghz radio gear, I don't need to wrap the RX in foam to protect it. I simply use some velcro to stick the RX where I want. With a 3d plane using a velcro strip to also hold the RX in place from the Gee forces is good too. The 2.4ghz gear is much more vibration resistant as it doesn't have delicate large frequency crystals, transformers and non-surface mount components to break from the vibration levels. So velcro works great and still isolates the RX from vibration just fine.
I still foam pad the battery pack though.
earlwb is offline Find More Posts by earlwb
Latest blog entry: My new Gaui X5 Rc Helicopter
Old Apr 03, 2013, 02:23 PM
bogbeagle is online now
Find More Posts by bogbeagle
Joined Mar 2007
I glue the Rx to a foam pad ... then glue the pad to a small bit of liteply.
I screw the liteply to the airframe to securely locate the assembly.
This is neat and provides good access to the Rx terminals and any buttons.
bogbeagle is online now Find More Posts by bogbeagle
Old Apr 03, 2013, 02:46 PM
Rcflyyer1 is online now
Find More Posts by Rcflyyer1
Rcflyyer1's Avatar
United States, FL, Sarasota
Joined Dec 2010
I just use velcro to attach my receiver to the fuselage. Many others do it as well and I have never heard of a failure. The FM radios need the foam pads because (what earlwb said). Always make sure you have room to position your antennas in a 90 degree relationship with each other to get signal diversity and so there are no "gaps" in the signal.
Rcflyyer1 is online now Find More Posts by Rcflyyer1
Old Apr 03, 2013, 04:48 PM
dmrcflyr2 is offline
Find More Posts by dmrcflyr2
United States, FL, Largo
Joined Feb 2006
Funny, I was thinking about this lately too. In my Escapade I have a Tactic 4 ch rx and I just have it secured with velcro to the servo tray. Unsure if I just don't care or what. In the 90's EVERY rx i had in a plane was wrapped in foam and possibly in a bag. Now my SIG Somethin Extra has a bit of foam wrapped around it. Glow engines tend to create a bit more vibration, especially the 4-strokes and then it might be a good idea. Of course I also USED to soft mount my 4-stroke engines, but I no longer do that either... Maybe I am tempting fate...
dmrcflyr2 is offline Find More Posts by dmrcflyr2
Old Apr 03, 2013, 11:31 PM
Arceenut is offline
Find More Posts by Arceenut
Arceenut's Avatar
Canada, BC, Langley
Joined Nov 2007
Before yo glue the Velcro on to the receiver, lay a layer of packing tape on the bottom of the receiver. Glue the Velcro to the packing tape. Then if you ever want to return the radio to original condition, remove the tape. I've been doing this for ages with no failures of the tape (it stick like chocolate or similar substances, to a blanket).
Arceenut is offline Find More Posts by Arceenut
Old Apr 04, 2013, 11:32 AM
600Bob is offline
Find More Posts by 600Bob
United States, OR, Canby
Joined Aug 2011
I don't use foam in glow planes but do with gas.
600Bob is offline Find More Posts by 600Bob
Old Apr 04, 2013, 04:36 PM
gwinhh is offline
Find More Posts by gwinhh
Beaumont tx
vibration and fragile crystals make the foam necessary on gassies.
howelel
gwinhh is offline Find More Posts by gwinhh
Old Apr 04, 2013, 10:40 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot... 100 yrs to late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
always use foam on my fuel planes.. 2.4 or not. Makes no sense not to.... vibratoin will cause issues eventually to unprotected equipment and I spend quite a bit of time on my builds so it's no big deal to wrap in foam and zip tie it in th fuse.
Thermalin is offline Find More Posts by Thermalin
Old Apr 05, 2013, 12:26 AM
Arceenut is offline
Arceenut's Avatar
Canada, BC, Langley
Joined Nov 2007
Foam is a good heat insulator. With the small sizes of the new receivers with the smaller heat dissipation area and the use of higher voltage batteries, the receiver can get much hotter. Some radios had a heat issue earlier and the suggestion at the time was NOT to bury them in foam. The heat failure issue I believe has been addressed but why torture the receiver because it supposedly can take it?
Old Apr 05, 2013, 01:07 PM
Thermalin's Avatar
Joined Jan 2005
I just prefer it.. i don;t bury them or wrap them tight.. just a jacket as opposed to sticking it directly to a vibrating piece of wood for glow anyway... i just stick it on the electrics.. My glow volts is regulated at 5 so no issue there and I'm generally 4 channels with normal loads.. no 3d.. no large scale...
Old Apr 05, 2013, 02:25 PM
Chip01 is offline
Find More Posts by Chip01
United States, TX, Weatherford
Joined Dec 2006
I join the crowd, I too use Velcro to mount the receiver. I also use Hitech 2.4 Aurora system and have not had a failure in the last two and half years. Also use nothing but 6V batteries with lots of capacity.
There are no crystals in the 2.4 equipment to fail due to vibration. Much simpler set ups.
Chip01 is offline Find More Posts by Chip01
Sold Sig Kadet LT-40 still wrapped in plastic!!! Mike Fortune Aircraft - Fuel - Airplanes (FS/W) 1 Mar 18, 2013 06:39 PM
Sold Traxxas XO-1. NIB. Black. Plastic wrap still on it. Curt S Cars - Cars and Parts (FS/W) 3 Jan 14, 2013 10:35 PM
Sold NIP SPEKTRUM AR6200 RX still wrapped in plastic $65 shipped java8297 Aircraft - General - Radio Equipment (FS/W) 4 Apr 04, 2011 09:27 PM
Sold NIP SPEKTRUM AR6200 RX still wrapped in plastic $75 shipped java8297 Aircraft - General - Radio Equipment (FS/W) 0 Apr 03, 2011 10:41 PM
Discussion Does everyone wrap their RX in foam? outacntrl Electric Heli Talk 10 May 11, 2007 10:20 AM
