Old Jan 24, 2013, 05:52 AM
Witterings is offline
Find More Posts by Witterings
Beware Of The Shills !!!
Chichester Sussex
Joined Aug 2007
Help With Motor Mount / Stand Offs
I've a Art Tech Mustang that I'm trying to make / use a different motor mount for but am struggling to find the right thing / size that will work.
The motor is a turnigy 35-30, I got one of these motor mounts
http://www.giantshark.co.uk/motor-mo...-p-404918.html
But it's too wide as the space I have is little more than about 40mm
I have 2 mounts that come with the motor and was going to try and get some stand offs like these but ideally approx 38mm long
http://www.hobbyking.com/hobbyking/s..._4pc_30mm.html
and put them in between to make a mount similar to te otehr but smaller but I can't seem to find anywhere that has them in stock, does anyone have any idea who in the UK may stock them ???
The alternative is I try and use something like this mount instead
http://www.sussex-model-centre.co.uk...xd.asp?id=1192
How would I go about fixing that to the actual plane I'm lost for how I'd do it, I've made a plate out of ply that I can just screw the other flat mounts to but can't see how to get one of these to attach??
Any help much appreciated!!
Witterings is offline Find More Posts by Witterings
Old Jan 24, 2013, 10:01 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
These are 40.5mm wide and 39mm long: http://www.hobbyking.com/hobbyking/s...dProduct=19007
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Jan 24, 2013, 10:38 AM
Chichester Sussex
Joined Aug 2007
I had seen those but they were out of stock otherwise definitely would have ordered them !!
Thanks for the suggestion though !!!
Old Jan 24, 2013, 01:49 PM
dedStik is offline
Find More Posts by dedStik
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
I bought aluminum tube and built my own standoffs for a glow to electric conversion I did last year. They work great and were very easy to cut. Most LHS or DIY stores should have aluminum tubing.
May give you an idea how it looks.
dedStik is offline Find More Posts by dedStik
Old Jan 24, 2013, 02:13 PM
Lardog is offline
Find More Posts by Lardog
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
No need to overthink this. Go to the hardware store and buy some nylon stand offs of the appropriate length. Fine tune by adding washers.
Lardog is offline Find More Posts by Lardog
Old Jan 24, 2013, 02:15 PM
HeeBeeGeeBee is offline
Find More Posts by HeeBeeGeeBee
Lysdexic I'm
HeeBeeGeeBee's Avatar
Spring, TX
Joined Oct 2010
There also adjustable mpotor mounts like the ones Heads Up RC carries...
http://www.headsuprc.com/servlet/the...unt/Categories
Best of luck,
HBGB
HeeBeeGeeBee is offline Find More Posts by HeeBeeGeeBee
Old Jan 26, 2013, 10:00 AM
gwinhh is offline
Find More Posts by gwinhh
Beaumont tx
Take a piece of 1/4" sq balsa. Chamfer one edge (cut off the corner ata 45 degree angle). Cut to approximate length and glue 4 together with the chamfered edge in the middle. Run a drill of appropriate length for the bolts you will use down the hole in the middle (use slow speed or your fingers). Line with aluminum tubing (optional). Cut to proper length, and use as stand-offs. If desired, box the standoffs with thin ply or balsa.
No need to go buy standoffs.
howell
gwinhh is offline Find More Posts by gwinhh
Old Jan 26, 2013, 10:27 AM
Electrofish is offline
Find More Posts by Electrofish
United States, FL, Stuart
Joined Apr 2012
Maybe this works
Electrofish is offline Find More Posts by Electrofish
Old Jan 26, 2013, 11:07 AM
bullseye000 is offline
Find More Posts by bullseye000
bullseye000's Avatar
Aurora Municipal, Illinois, United States
Joined Jul 2002
I ordered several sets of spacers from the folks at Aluminum Spacers. I tried the nylon ones from the hardware store but had some stress cracks form on one of the tube walls and lost my confidence in them. The aluminum ones were cheap and they shipped asap. I bought a set of 3/4'' standoffs and bought a longer set in case I needed to cut my own to fit.
bullseye000 is offline Find More Posts by bullseye000
Old Jan 26, 2013, 11:49 AM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Originally Posted by Electrofish View Post
Maybe this works
Nice work.. but unless you have everything absolutely balanced don't you risk vibration... I'd add a ply box around those stand-off bolts (effectively providing an anterior firewall for the X-mount), to dampen resonance.
Old Jan 26, 2013, 01:51 PM
zeezee is offline
Find More Posts by zeezee
Yea, I fly dusty planes..
zeezee's Avatar
United States, LA, Angie
Joined Apr 2009
This is what I did to electrify a Big Stik. Double mount to save existing nose gear setup and use existing blind nuts behind firewall. Dave
zeezee is offline Find More Posts by zeezee
Old Jan 26, 2013, 09:11 PM
blvdbuzzard is offline
Find More Posts by blvdbuzzard
The high desert of Southern California
Joined Jul 2002
Mine are made from 10-32 threaded rod, hex nuts, fender washers, blind nuts and PEK tubing from Lowes.
Buzz.
blvdbuzzard is offline Find More Posts by blvdbuzzard
Old Jan 26, 2013, 11:07 PM
zeezee is offline
zeezee's Avatar
Joined Apr 2009
Buzz, nice deal but a little long for just 4 bolts for me. Either a mid plate, thus shorter spacers on an aluminum tube box mount to eliminate vibration. Zee
Old Jan 27, 2013, 02:41 AM
kbozarth is online now
Find More Posts by kbozarth
Joined Jun 2008
Nice looking plane.
Kurt
kbozarth is online now Find More Posts by kbozarth
Old Jan 27, 2013, 08:04 AM
Chichester Sussex
Joined Aug 2007
Thanks to all for the suggestions, Buzz yours looks like the one that'll work best with the set up / space I have, did you mean pex rather than pek tubing ??
Wanted Stand Off Motor Mounts 10mm joeyjojojjjjjj Aircraft - General - Miscellaneous (FS/W) 3 May 08, 2012 07:58 PM
Question Elecrtic Motor Mount Stand Offs Hossinarizona Electric Plane Talk 15 Aug 15, 2011 09:07 PM
Wanted Firewall motor mount or stand off kz4q66 Aircraft - Electric - Power Systems (FS/W) 3 Oct 01, 2010 04:44 AM
Discussion Large Motor Mounting "Stand off/Bulkhead" yumamike Power Systems 3 Nov 20, 2009 04:08 PM
For Sale E-flight Pwr 110 with mount & stand-offs include missle Aircraft - Electric - Power Systems (FS/W) 5 Aug 27, 2009 03:55 PM
