Old Dec 15, 2012, 07:26 PM
redbearddebspike is offline
Find More Posts by redbearddebspike
Red Beard
United States, PA
Joined Jun 2007
fun cub centre of gravity is way off
the book says 80mm back should be the centre of gravity. even if i put my battery almost all the way back it is still way to front heavy. has anyone else had this problem?? what should i do??
redbearddebspike is offline Find More Posts by redbearddebspike
Old Dec 15, 2012, 10:42 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
Are you using the recommended battery and motor?
I've had to carve out some foam to move the batt.
I've had to add some weight to the tip of the tail or nose, to get the C/G.
I've moved the esc, servos, rx and what ever I could.
It may be best to weight the tail, test fly it and see if it really is that far off.
A nose heavy plane is more controllable than a tail heavy one.
Butch777 is offline Find More Posts by Butch777
Old Dec 15, 2012, 10:52 PM
Red Beard
United States, PA
Joined Jun 2007
I'm using the recommended battery and the plane came rtf from multiplex. I guess I'll add weight to the tail
Old Dec 16, 2012, 01:11 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
CG is also a matter of personal preference. Some FunCub pilots prefer the CG at 65-70mm. So how far off are you really?
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Dec 16, 2012, 08:02 AM
ltc is offline
ltc
Find More Posts by ltc
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
When you say "way too front heavy", exactly where the is CG?
Did you do anything else different compared to stock? Larger servos, paint, landing gear, spinner...anything that might affect balance?
ltc is offline Find More Posts by ltc
Old Dec 16, 2012, 01:10 PM
stevespana is online now
Find More Posts by stevespana
Huesca, Spain
Joined Aug 2009
The FC is very tolerant when it comes to the CofG.
As Jurgen said, it's often a matter of personal preference which is also related to how you want to fly the model.
When I built my FC I stuffed a 2200mah lipo as far back as it would go. My CofG worked out at 73mm from the LE of the wing which was within the range that many others were recommending.
I have flown the FC from day one with this setting and haven't felt the need to change it. In fact I've found that at this setting the model will fly inverted with no elevator required to mainmtain level flight.
Steve.
stevespana is online now Find More Posts by stevespana
Discussion Centre of Gravity westray Electric Plane Talk 40 Sep 21, 2012 03:59 PM
Discussion Top Gun Park Flite Stratus - centre of gravity keef30 Beginner Training Area (Aircraft-Electric) 3 Aug 10, 2012 02:21 AM
Help! Crack Pitts Centre of Gravity wolfmanjack 3D Foamies 3 Jul 30, 2012 04:41 PM
Centre Of Gravity Calculator Link irun4fundotca Non R/C Items (FS/W) 9 May 30, 2012 10:29 AM
Discussion Centre of gravity nanastick Beginner Training Area (Aircraft-Electric) 21 Apr 23, 2012 05:28 PM
