Old Mar 11, 2012, 11:05 AM
V6Goose is offline
Find More Posts by V6Goose
Joined Jun 2007
Zener diode question
Hi and thanks for looking.
I have installed two LiFe (6.6v, 2100mAh) batteries in my 33% Edge, each with it's own switch and feed to a Futaba R6014HS Rx.
I have modified the switches to include a LED (on the output side) to show me that each pack is online.
Because Futaba Rx's use a bus for power to all channels, when I switch one battery pack on, both LED's light because of the 6v being supplied from the Rx.
I understand installing a Zener diode (5W, 6.8v) will resolve the problem but my question is on how to install it.
Do I simply put it inline on the +ve feed to the Rx (between switch and Rx)?
Many thanks
Goose
V6Goose is offline Find More Posts by V6Goose
Old Mar 11, 2012, 12:36 PM
ramboman is offline
Find More Posts by ramboman
Waterloo, Belgium
Joined Dec 2004
Many thanks
Goose
No zener diode, a schottky diode between switch and Rx, twice.
Led just after switch.
ramboman is offline Find More Posts by ramboman
Old Mar 11, 2012, 01:50 PM
V6Goose is offline
Joined Jun 2007
Thanks Ramboman...
Old Mar 12, 2012, 02:30 PM
dmccormick001 is offline
Find More Posts by dmccormick001
Dave the Rave
dmccormick001's Avatar
Joined Jun 2007
One other thing, make sure the current rating of the diodes you use is large enough to handle the current load. I notice your plane is a big one, a 33% Edge, so consider what all your servos might draw in a situation where you're moving them all at once, like an extreme 3D maneuver, you'll want the diode(s) to be able to handle the total current load. If they fail, it will be like turning the switches off, not a good thing at all.
dmccormick001 is offline Find More Posts by dmccormick001
Old Mar 13, 2012, 01:14 AM
Airlady is offline
Find More Posts by Airlady
Airlady
Airlady's Avatar
United States, TX
Joined Jan 2012
Very True
Airlady is offline Find More Posts by Airlady
Old Mar 13, 2012, 01:28 AM
Miami Mike is offline
Find More Posts by Miami Mike
Pompano Hill Flyers
Miami Mike's Avatar
Miami Lakes, Florida, USA
Joined Mar 2003
Not really.
When diodes fail from overcurrent they become permanent short circuits, conducting in either direction with virtually no voltage drop. If this happens, the worst consequence will be that "Goose" will have the same situation he has now - both LEDs will light when either switch is on.
The current level needed to actually burn a diode in half and create an open circuit is much higher than the level that causes it to short circuit.
Miami Mike is offline Find More Posts by Miami Mike
Old Mar 13, 2012, 01:34 AM
Airlady is offline
Airlady
Airlady's Avatar
United States, TX
Joined Jan 2012
Maybe
But ive had diodes just crap out maybe due to manufacturing Brand - a assy line run flaw etc.... even repaired quite a few computer motherboards ( wont name ) because of this problem
Old Mar 13, 2012, 01:40 AM
Pompano Hill Flyers
Miami Mike's Avatar
Joined Mar 2003
I'm not so sure that diodes are the best idea anyway. It depends upon what sort of problem "Goose" is trying to detect. If he just wants to check the LEDs to make sure he remembered to turn both switches on, it might be better to use double-pole switches with the LED circuits wired to one side and the plane's electrical system wired to the other side.
Old Mar 13, 2012, 02:02 AM
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Just what is the problem ?
Jim.Thompson is online now Find More Posts by Jim.Thompson
Old Mar 13, 2012, 09:03 AM
bladeskiller is offline
Find More Posts by bladeskiller
Athens
Joined Aug 2008
There is no need for zener diode. To isolate the two batteries (and so the two leds) you can use two MBR 745 high current schottky diodes, as shown in the attached diagramm. The same thing like power supplying RX and servos of a twin using the BECs of both speed controls.
bladeskiller is offline Find More Posts by bladeskiller
Old Mar 13, 2012, 11:14 AM
AndyOne is offline
Find More Posts by AndyOne
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
Don't forget the resistors needed in series with the LEDs to limit the current.
A.
AndyOne is offline Find More Posts by AndyOne
Old Mar 13, 2012, 12:05 PM
Pompano Hill Flyers
Miami Mike's Avatar
Joined Mar 2003
Exactly.
You can't identify the best solution to a problem until you know what the problem is.
Old Mar 13, 2012, 12:55 PM
Athens
Joined Aug 2008
A.
HOOPS!!! Yes you are right. I forgot the resistors in series to each led.
For 6.6 volts max 6.8 (under load not during charging) of a LiFePO battery a 220-330 ohm resistor in series to each of the leds will be fine.
I have just added the resistors to the diargamm.
Old Mar 14, 2012, 01:27 PM
Dave the Rave
Joined Jun 2007
Originally Posted by Miami Mike View Post
Exactly.
He told us what the problem is in the original post. He's trying to use two batteries and two switches (for redundancy), he's added an LED to each switch, but when he plugs either battery into the receiver, both LEDs light up. Of course that's because the power leads in a Futaba receiver are on a common buss. He wants to isolate each battery/switch/LED from the other.
The circuit bladeskiller posted works fine, with the added advantage that you can connect it all up with a servo wye plugged into a single channel on the receiver, no need to use up a spare channel for the other battery/switch.
Old Mar 14, 2012, 04:05 PM
Pompano Hill Flyers
Miami Mike's Avatar
Joined Mar 2003
No, not that problem. That may be what Jimbello meant, but I'm asking what the problem is that he's trying to detect. What sort of failure is he trying to identify and prevent with this LED circuit? See my post #8.
Discussion zener diode vs resistor for led's? TommyB DIY Electronics 15 Apr 14, 2007 02:25 PM
Discussion Zener diode as rudimentary Li-Ion protection? meteor DIY Electronics 4 Mar 09, 2006 09:32 PM
Question Camera Battery elimator circuit / Free on line Zener Diode selector...very neat? Snow Bird PA-FL Aerial Photography 4 Jul 19, 2004 09:25 AM
Zener Diode to Drop 3xQ830 li-Ion Voltage for Tiger Moth AndrewsJr Power Systems 2 Feb 24, 2002 10:04 PM
Diode orientation question Red Baron 47 Power Systems 10 Jul 06, 2001 12:16 AM
