Old May 25, 2003, 03:04 AM
GordySoar@aol.com
GordySoar@aol.com
Guest
n/a Posts
[RCSE] NO Xtals needed for your Next Reciever..or shift worries
Yep,
And its available today!
Polk Hobbies offers the Seeker 8 RX.
Slightly bigger than the hitec slim 8, but you simply put whatever TX brand
(FM) and channel next to the RX, push a button on the RX and ...done.
It doesn't care if its Pos shift, neg shift or which channel. The unit holds
that in it forever, plugged in or unplug sitting in your drawer.
When you need it to match some other channel or TX, you just do the same
thing and it is now locked on that. It also offers a pre program function if
signal is lost due to interferrence.
You push the button and follow the instructions for setting up, up to four
pre set positions for your surfaces.
So you could program in landing flaps or what ever. Loose signal and zip
they plane goes to that setting.
Tested by the number one universally recognized authority for such stuff as
being as good or better than any RX available today.
Check out <A HREF="http://polkshobby.com/">Polks Hobby...Seeker RX</A>.
You don't get all that without paying for it, but if you have a need for
changing channels on the flying site to avoid congestion, this is the easy way to
go!
Gordy
(I got some :-)
Louisville today
Bob Pope
Bob Pope
Guest
n/a Posts
Re: [RCSE] NO Xtals needed for your Next Reciever..or shift worries
GordySoar@aol.com wrote:
> Yep,
> brand (FM) and channel next to the RX, push a button on the RX and
> ...done.
> unit holds that in it forever, plugged in or unplug sitting in your
> drawer.
> same thing and it is now locked on that. It also offers a pre program
> function if signal is lost due to interferrence.
> four pre set positions for your surfaces.
> zip they plane goes to that setting.
> stuff as being as good or better than any RX available today.
> Check out Polks Hobby...Seeker RX <http://polkshobby.com/>.
> for changing channels on the flying site to avoid congestion, this is
> the easy way to go!
> Gordy
> (I got some :-)
> Louisville today
that include ground freg's too?
Bob
RCSE-List facilities provided by Model Airplane News. Send "subscribe" and "unsubscribe" requests to soaring-request@airage.com. Please note that subscribe and unsubscribe messages must be sent in text only format with MIME turned off.
Stephen Syrotiak
Stephen Syrotiak
Guest
n/a Posts
It sounds good...
Lets have an in-flight report using this on a >crowded< flightline.
Dave Seay
Dave Seay
Guest
n/a Posts
While we're at this, how about some comments on the Tracker II Tx Polk
offers.
Dave
Tom Broeski
Tom Broeski
Guest
n/a Posts
I Have them for $65 each (that's less than the Superslim)
Tom
T&G http://adesigner.com
32 Mount View Dr
Afton, VA 22920
phone 540 943-3356
fax 540 943-4178
----- Original Message -----
To: Soaring@airage.com
Sent: Friday, May 23, 2003 3:57 PM
Subject: [RCSE] NO Xtals needed for your Next Reciever..or shift worries
Yep,
brand (FM) and channel next to the RX, push a button on the RX and ...done.
holds that in it forever, plugged in or unplug sitting in your drawer.
Check out Polks Hobby...Seeker RX.
way to go!
Gordy
(I got some :-)
Louisville today
Tom Broeski
Tom Broeski
Guest
n/a Posts
72, 75, 35, 40 MHz
32 Mount View Dr
Afton, VA 22920
phone 540 943-3356
fax 540 943-4178
From: "Dennis and Marion Hipperson" <dennis@hipperson.net>
To: "Tom Broeski" <tjb@adesigner.com>
Sent: Saturday, May 24, 2003 4:22 AM
Subject: Re: [RCSE] NO Xtals needed for your Next Reciever..or shift worries
> Tom,
> Do I assume then that these will work on 36mhz as well.
> Regards
> Dennis Hipperson
> From: "Tom Broeski" <tjb@adesigner.com>
> To: <GordySoar@aol.com>
> Cc: "soaring" <soaring@airage.com>
> Sent: Saturday, May 24, 2003 3:15 AM
worries
> > Tom
> > 32 Mount View Dr
> > Afton, VA 22920
> > phone 540 943-3356
> > fax 540 943-4178
> > From: GordySoar@aol.com
worries
> > Yep,
> ...done.
unit
same
function
> four
> zip
stuff
for
easy
> > way to go!
> > Gordy
> > (I got some :-)
> > Louisville today
that
> MIME turned off.
Sold 9g Servos - Get Some for Your Next Project GorillaBob Aircraft - General - Radio Equipment (FS/W) 24 Jul 28, 2005 04:47 PM
Suggestions needed for low cost airbrush or any other low cost painting alternatives TGK Foamies (Kits) 2 Mar 13, 2005 09:41 AM
Stepper motor boards for your next CNC simingx DIY Electronics 4 Jun 02, 2004 10:26 AM
Yippee! Authentic Camo & Color for your next plane flyingmonkey Slope 2 Dec 23, 2003 08:17 AM
