Old Nov 01, 2009, 06:41 PM
INCARUS is offline
Find More Posts by INCARUS
gilbert AZ
Joined Oct 2007
Question
whats the diff with hoffman motor?
whats the difference with these motors besides the kv difference. They both weigh the same,use the same fan and generate the same watts (1800). the only difference I see is that one uses 3s-4s and the other is 3s-5s. I'm kinda new to the who edf stuff but if I can get 1800w out of the same motor on 3s, why would I use 5s to get the same results...all I gain in weight, not power/thrust...I'm sure I'm missing something.
STORM70HW Powered EDF
The power of the "Wild Beast"
in the World?s First Integrated EDF Outrunner Fan!
Specifications
Dynamically balanced 70mm EDF w/5mm shaft
Kv 4880, R(ohms) 0.007
Weight 228grams
Max amps 125 amps
up to 1800 watts
up to 4.3 lbs of thrust
Speed range 54,000 rpm, 3 to 4 cell lipo
Recommendations:
Batteries 25-40c, 3300mah - 4000mah lipo
ESC: Castle Creations 80amp for 3s or Castle Creations 125amp for 4s
Advance Programming setup for esc:
Motor Start=Medium
Throttle Response=Medium
Timing=Low Advance
PWM=13kz
Current Limiting=Normal
Brake Disabled
STORM 70 Powered EDF
The World's First Integrated EDF Outrunner Fan!
Specifications:
- Dynamically balanced 70mm EDF w/5mm shaft
- Kv 4130
- R(ohms) 0.0085
- Weight 228grams
- Max amps 125amps
- up to 1800 watts
- up to 4.3 lbs of thrust
- Speed range 54,000 rpm
- 3 to 5 cell lipo.
Recommendations:
- Batteries 25-40c, 3300mah + lipo
- ESC: Castle Creations 80amp for 4s or Castle Creations 125amp for 5s.
Motor Start = Medium
Throttle Response = Medium
Timing = Low Advance
PWM = 13kz
Current Limiting = Normal
INCARUS is offline Find More Posts by INCARUS
Old Nov 01, 2009, 06:48 PM
Bajora is online now
Find More Posts by Bajora
KK6MQJ
Bajora's Avatar
Joined Sep 2004
Different Kv = different battery. I believe one is for 4S and one is for 5S as you mentioned. And with lipos, higher cell counts mean lower currents, for as the volts go up the current goes down. I have a couple of RCLander EDFs .. one is a 4S power system which uses a 3850 4S...the other is a 6S power system but it uses a pair of 2500 3S in series to make the same power as the 4S setup does. I forget the two current draws but the 6S should be lower due to the higher voltage.
Other more knowledgable folks will also probably offer some words of wisdom here too.
Bajora is online now Find More Posts by Bajora
Discussion Hoffman Magnetics MME-20 Micro Mite Outrunner Motor Niknjen Indoor Pattern/F3P 1 Oct 26, 2009 09:54 AM
Discussion Belt or shaft & gear diff or Ball diff musaed Car Talk 0 Oct 15, 2009 01:24 AM
Video Hobby Lobby's JPower AMX EDF with a Hoffman Magnetics Mightey Mite 60mm Motor Bajora Electric Plane Talk 2 Jan 06, 2009 06:48 PM
whats the diff with the flash5 old and new flash5x rumplestilskin Radios 2 Dec 02, 2004 02:19 PM
Filip 2ME vs Filip 600, whats the diff.? RandyK1 Electric Sailplanes 9 Oct 29, 2002 10:12 AM
