Old Jan 14, 2009, 08:37 PM
M.Putnam is offline
Find More Posts by M.Putnam
Shade Tree Aviation #2
M.Putnam's Avatar
United States, NC, Rutherfordton
Joined Jan 2002
Tiburon Bipe v2 Indoor Version
It has been a few years since I introduced the original Tiburon Bipe. Recently I began thinking about revisiting the design and incorporating some changes to bring the design up to date in turns of it's performance and construction style. This version is intended for indoor flying specifically.
The original Tiburon Bipe was constructed from 6mm Depron with a 30" wingspan. Like many of the foamies of the time, it was designed around an inrunner brushless motor on a gearbox. The version that was (and i assume still is) kitted by 3D Foamy used a carbon tube and "G-force" doublers on the wings for rigidity. This seamed like a feather in it's day, but is a bit overkill by today's standards.
The 6mm Tiburon was followed by a 24" wingspan - mini version built from 3mm & 2mm Depron. It flew well on 2s battery with an Axi 2204/54. It was really my first indoor airplane - and I flew a bunch of them.
So, here are the major adaptations on the V.2. This version is constructed from all 3mm Depron and has a 33" wingspan. Rigidity comes from 1mm carbon rods bracing the wings and stabilizer. Foam longerons run the length of the fuse preventing twist. The tail moment has been lengthened from the original design to improve precision "F3P" flying ability. The wings are not staggered as in the original. I found that on the original, upright harriers were a piece of cake while inverted was a bit more difficult. The distance between the wings has also been increased. The wing struts have been converted to rather substantial "Side Force Generators". Wing, Stab, and Rudder shapes have been tweaked along with slight fuse alterations. Design will include airbrakes between the wings to aid in constant speed through downline manuvers. The design retains the unique look it is known for while bringing it up to date for today's flying style.
I will keep you posted as I begin construction and flight testing. Here is a look at what I have so far...
M.Putnam is offline Find More Posts by M.Putnam
Old Jan 14, 2009, 09:06 PM
Jimmy JFlyer is offline
Find More Posts by Jimmy JFlyer
For us He died, in me He lives
Jimmy JFlyer's Avatar
United States, MI, Saint Clair Shores
Joined Dec 2008
Looking forward developements on this one. Looks to be the start of a sweet bipe. Don't keep us waiting for too long!
Jimmy
Jimmy JFlyer is offline Find More Posts by Jimmy JFlyer
Old Jan 14, 2009, 09:32 PM
M.Putnam is offline
M.Putnam's Avatar
Joined Jan 2002
Jimmy,
Hopefully construction can begin soon. I have submitted laser cut files for a quote. Shouldn't be long before they can send me some parts! I am just too busy to handcut all those lightening holes!
Matt
Old Jan 14, 2009, 09:53 PM
DRITCH is offline
Find More Posts by DRITCH
DRITCH's Avatar
ST.LOUIS
Joined Aug 2006
So did you design the TIB too? I flew the poo outta one this summer. Fly buddy giggled everytime he saw the tail twist. I did have to modify it a bit for lighter power system, FFF, etc...Pull/pull and all the goodies. Loved how it would blender to the ground then shoot straight up forever. I learned most of the good 3d moves on that one. The only bad trait was wing rock at slow and low.
Any chance of a redo?
I actually have the original tib bipe plans rolled up. I gave up trying to align them correctly. Probably printer settings?
Dan
P.S. This new one already looks like a good candidate for an outdoor version. The span's perfect. Just have to see what ya come up with.
Mind if I build one off this drawing?
DRITCH is offline Find More Posts by DRITCH
Old Jan 15, 2009, 08:08 AM
M.Putnam is offline
M.Putnam's Avatar
Joined Jan 2002
Dan,
Yes, I designed the Tiburon monoplane as well. It did suffer from a bit of tail twist, especially with the massive torque of the motor's I ran on it.
Feel free to build away...The pdf. drawing is 25% scale.
Matt
Old Jan 15, 2009, 08:53 PM
DRITCH is offline
DRITCH's Avatar
ST.LOUIS
Joined Aug 2006
Matt,
Thanks, I might scale it to 28 or so and give it a go.
Old Jan 16, 2009, 09:04 AM
M.Putnam is offline
M.Putnam's Avatar
Joined Jan 2002
Let me know how it turns out...
Old Jan 16, 2009, 09:20 AM
Joined Dec 2008
Hey Matt,
If ya don't mind, I'm going to print it out too & try it as the 24" mini.
I really can't afford really good brushless motor's atm but will probably get a cheapy for now from Hobby City. Any particular motor you would recommend going that route for the time being?
I currently have the 1300 kv 20g blue wonder that pushes 400g's. That will be going on the Blu Baby highwinger of Tony's.
That little brute of a motor is so silly cheap. (yes I know you get what you pay for )
What do you think?
Jimmy
Old Jan 16, 2009, 03:29 PM
M.Putnam is offline
M.Putnam's Avatar
Joined Jan 2002
If you are going to scale it down to 24" you are definately going 2s and I would suggest something along the lines of the Axi 2203/46 or the Hacker A10 series. www.gobrushless.com has a couple of motors you might want to look at as well. My guess is that you are looking at around 5-6.5 ozs rtf at that size.
Matt
Old Jan 16, 2009, 03:39 PM
Joined Dec 2008
Matt, thanks for the link.
I looked at that link. I swear I am not going to get anything done hear at work
In particular the 5 & 10 g 2k+kv motors found under the Micro Motors RTR. Think 1 of those would be sufficient?
Being a newb is such a pain!
What would you recommend for servo's?
ah heck, why dont I cut to the chase and skip the next 5 questions & just ask...
what set up would you put on this if you were building this plane at 24" and had to be frugal about it?
Jimmy
Old Jan 16, 2009, 08:21 PM
M.Putnam is offline
M.Putnam's Avatar
Joined Jan 2002
Cheap @ reliable - go with the Eflite 250 outrunner with an 8amp esc.
2 cell 350 mAh Li-po
servos - I like the Futaba 3114 (I have had great results with them).
Just my suggestions, many others would work well also.
Matt
Old Jan 16, 2009, 09:05 PM
Joined Dec 2008
Matt,
I checked out E-Flite's website. Still too high in terms of price for my budget. That 250 outrunner starts at $45.00. When I said cheap, I meant cheap, as in some off shoot from Hobby City maybe. One of the Blue Wonders?
Being a newb is a pain in the butt, being a poor newb (with high aspirations no less) is way worse!!!
Any suggestion?
Jimmy
Old Jan 16, 2009, 09:57 PM
M.Putnam is offline
M.Putnam's Avatar
Joined Jan 2002
Jimmy,
Look for a motor weight of 14 grams with a kv of around 1700-2000.
Matt
Old Jan 16, 2009, 10:06 PM
IFLYOS is offline
Find More Posts by IFLYOS
14s 180mah should be enough...
IFLYOS's Avatar
United States, NC, Pfafftown
Joined Feb 2001
http://www.bphobbies.com/view.asp?id...7&pid=B2171399
Thats the motor you need...chaep, reliable, and good price!!
It's over 14 grams, but for the money, you cannot beat it. I have a couple of them as well as a few Park 250's...and both have their place....
If you build light, you might be able to make up the difference in weight...
Tim
AG4RZ
IFLYOS is offline Find More Posts by IFLYOS
Latest blog entry: Intro..a few years to late!
Old Jan 16, 2009, 10:31 PM
Joined Dec 2008
Tim,
I looked at your motor & it looks pretty sweet. Can you do me a favor & compare it to ths guy?
http://www.hobbycity.com/hobbycity/s...idProduct=2069
This is the motor I currently have. It's actual weight, according to the scale I have, is 20 g's. Brand new, $8.00.
Brushless Outrunner Motor.
Kv - 1300rpm/v
Max Load: 7.5A
No Load Current: 0.7A
Suggested Lipo: 3 cell 11.1v
Thrust: 400g+
Suggested Prop: 8x3.8
Weight: 20g
Jimmy
Tiburon Bipe Build portcityflyer 3D Flying 126 Jan 13, 2009 05:43 AM
Tx setup for Tiburon bipe? lanlong 3D Flying 1 Sep 27, 2004 09:56 AM
HOT 3D Foamy Tiburon BIPE Video! Levi Jordan 3D Flying 3 Sep 24, 2004 05:26 PM
Tiburon Bipe kits are here! kobra3d 3D Flying 0 Sep 14, 2004 04:17 PM
Tiburon Bipe GW 3D Flying 17 Aug 30, 2004 11:42 PM
