Old Jan 03, 2003, 09:42 AM
Khlash is offline
Find More Posts by Khlash
Joined Nov 2002
charging question
Im new to electrics. I recently purchased a GWS fast charger to charge my 7.2v 600mAh battery for my Slow Stick. The rate of charge can be adjusted from .25-6 amps. Is it okay for me to charge my batteries at 2-3 amps? Or is this too fast? I also have some 4.8v batterries I use for my glow plane, same question for them. Thanks in advance
Khlash is offline Find More Posts by Khlash
Old Jan 03, 2003, 01:58 PM
Gary M uk is offline
Find More Posts by Gary M uk
Joined Apr 2002
Hi Khlash
If they are Nicads and R rated ( r for rapid) eg 500AR, charge at 1 Amp. Do not go over just to play safe.
Gary
Gary M uk is offline Find More Posts by Gary M uk
Old Jan 03, 2003, 02:14 PM
Khlash is offline
Joined Nov 2002
follow up
What is the reason I shouldnt go over 1 amp?
Old Jan 03, 2003, 02:22 PM
Joined Apr 2002
The faster you charge cells the hotter they will get. You can go over 1 Amp on small packs but it's a bad habit to get in to. The cell will/can over heat, vent and then destroy it self or have its life reduced.
I charge all my 4 cell Rx packs on automatic and it seldom goes over 1 amp, unless they are realy flat.
Just stick to 1 Amp and play safe for the mean time.
Gary
Battery rapid charging question ARE Electric Plane Talk 5 Feb 02, 2009 04:50 AM
TX Charging Question dommi Power Systems 8 Nov 04, 2001 11:52 AM
Charging question saddler Parkflyers 5 Oct 13, 2001 01:56 PM
trickle charging question Tree_Climber Power Systems 4 Sep 28, 2001 08:33 PM
Probably a dumb battery charging question... Dennis Fenrick Power Systems 4 Jun 20, 2001 05:53 PM
