Old May 19, 2007, 12:48 PM
massimo is offline
Find More Posts by massimo
massimo's Avatar
Joined Nov 2001
council for me:i want to buy this video system...is ok ???
hi to all dear friends ,
please i want to buy the complete video system from rangevideo:
2.4GHz portable receiver
2.4GHz 14dBi Patch receiver antenna
KX151 color CCD camera
2.4GHz 1000mW audio/video transmitter
but many persons prefer the 900mhz ...reason?
I would want to know if some friend has tried the Rvision high resolution goggles... for you these google are a good product also for me that I have minepersonal view google .
thank you and sorry for my bad bad monster english!!!
massimo is offline Find More Posts by massimo
Old May 19, 2007, 01:37 PM
Crash9 is offline
Find More Posts by Crash9
FPV Pilot
Crash9's Avatar
United States, MT, Missoula
Joined Mar 2006
Hi massimo, The 900 has a little better range and penatration around objects . The 2.4ghz is still good also, but with more radios coming out transmitting on 2.4ghz it's better to use the 900mhz to cut down on possible interferance if you plan on/or have a 2.4ghz radio if not then your fine with the gear you listed . Enjoy
www.FPVvideo.com
Crash9 is offline Find More Posts by Crash9
Old May 20, 2007, 07:37 AM
massimo is offline
massimo's Avatar
Joined Nov 2001
Hi to all ,
thank you Crash for reply,
no friends has tried Rvision high resolution goggles???
thank you in advance for reply
Old May 22, 2007, 07:49 AM
massimo is offline
massimo's Avatar
Joined Nov 2001
council
hi to all ,
an other great doubt (
TX 500mW-5V with KX131 cam or TX 1000mW-12V with 520 TVL 12v cam???
/first system/
rangevideo:
KX151 color CCD camera for 12V or KX131-5V
2.4GHz 500mW-5V audio/video transmitter or 1000mW-12V
/second system/
FutureHobbies:
1x RE-1000 (PAL)
HIGH RESOLUTION HEADSET (FH-545BK)
council???
for mine first flight I wanted to put the system video within mine robbe easy go with motor hacker brushless in order to fly with a greater weight...but in the future i want put the system in quadrirotor with OSD-GPS system (progr. multi way point etc)...
Thank you for all your reply
Regards
Old May 22, 2007, 02:18 PM
Crash9 is offline
FPV Pilot
Crash9's Avatar
Joined Mar 2006
Both places will serve you well. 500mw is plenty of power unless you are flying very far away from yourself. I would try and stay with all the same voltages 5 or 12. (www.hobbywireless.com is the new kid on the block you may want to check them out also)
Yippee! Looking for a replacement Dragonfly? Buy This one Utterflight Micro Helis 5 Jun 05, 2005 10:33 AM
Why I want to buy this USD0.50 Slipper? alan_gbk Micro Helis 17 May 18, 2005 12:08 AM
opinions on this video system for downlinking? Newberry Aerial Photography 5 Jan 11, 2005 11:36 PM
Want to trade Wireless Video System for Heli Kit kdill2160 Aircraft - Electric - Airplanes (FS/W) 0 Mar 17, 2003 10:21 PM
