Old Feb 01, 2016, 01:25 PM
zanthor is offline
Find More Posts by zanthor
Dirt Dobbins
United States, IA, Des Moines
Joined Dec 2014
Broken Bixler, how to repair motor mount?
So I slapped the ground pretty hard today and broke my bixlers motor mount... of course the fuse is glued together, and being new to this hobby I have no idea how to fix this... any advice would be appreciated.
I do have a 3d printer and would love to give the motor more clearance for a bigger prop while I'm doing the repair... just not sure how to gain access!
zanthor is offline Find More Posts by zanthor
Latest blog entry: Diverse Diversity
Old Feb 01, 2016, 02:02 PM
cmdl is offline
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
Ask here: http://www.rcgroups.com/forums/showthread.php?t=1448440
cmdl is offline Find More Posts by cmdl
Old Feb 01, 2016, 10:46 PM
Glacier Girl is offline
Find More Posts by Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
Oh heck that's easy. Take an Xacto knife, or razor snap knife, or even a razor blade and cut the top off the pylon. Slice it 90 degrees from the original slices that made up the halves of it.
Pop the top off and then you can work the plastic mount out.
When you go to reinstall it, I used good old GOOP to hold the plastic mount, and for sticking the top back on. Makes it a lot easier if you have to do it again, to slice through the glue joints. I've done it on mine when changing out motors.
Actually I built my own risers for the motors, so I could run bigger props. I took a wood dowel rod and sized it to fit inside the original plastic mount. Flipped the plastic mount 180 degrees so it would accept the rod. Rod sits flush with the back of the pylon. Then made the riser out of a piece of 1/8" aluminum bent to get the motor angle through the CG (very important).
Four small screws hold the aluminum to the dowel, and a hole drilled through both the aluminum and dowel allows you to run the motor wires through.
Glacier Girl is offline Find More Posts by Glacier Girl
Discussion Broken motor mount on MM C-180. How do I repair? pac ace Parkflyers 3 Nov 21, 2006 04:52 PM
HOw to Repair broken GWS Stick MOtor Mounts aplphabandaid Parkflyers 2 Jul 28, 2004 08:32 PM
Best way to repair a broken balsa wood motor mount??? rcwyant Parkflyers 13 Jul 30, 2003 10:13 AM
Best way to repair broken GWS motor mount? lensrc Foamies (Kits) 3 Aug 31, 2002 01:14 AM
