Old Dec 05, 2014, 01:08 AM
randomdude is offline
Find More Posts by randomdude
Registered Random User
randomdude's Avatar
Joined Sep 2006
Idea
AirHogs Jetscream edf's on A.Hogs storm launcher? (this forum?)
First thing first, if there is a better suited forum for this, please ship me that way
yes, thats right, i'm STILL talking about SL's lol.
so, the thing i hate most about the SL is its Frickin annoying plastic props setup. one prop always ends up shooting off the shaft when its halfway across a lake or snapping a blade off when it lands upside down lol.
so i looked around in my A.hog pile, and i found a Jetscream (never enjoyed the flight characteristics, so it was thrown in the parts pile ) with edf's in perfect shape, so why not put the edf's on the SL? i would love not having exposed props on it...
randomdude is offline Find More Posts by randomdude
Old Dec 06, 2014, 02:22 AM
cmdl is online now
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
would the ducted fan units provide enough thrust to keep the SL in the air? that is probably the only issue you need to figure out. other than that, if the ducted fans draw less current than the SL props, then you're fine with the SL ESC (brick). if not, then you may have to use the Jetscream brick.
cmdl is online now Find More Posts by cmdl
Old Dec 06, 2014, 03:49 AM
randomdude's Avatar
Joined Sep 2006
ya, i was going to take the old motors out, and solder the edf's to the factory leads.
anyone know of a aftermarket edf that would be suited for this application? i would really like enough power to be able to hover it in place nose up! lol
Old Dec 06, 2014, 01:32 PM
cmdl is online now
cmdl's Avatar
Joined Jan 2012
if you want to be able to hover, non-EDF is the way to go. EDFs are overrated and misunderstood. with an EDF you will need to put in a higher cell count battery to get comparable thrust performance.
Old Dec 09, 2014, 06:05 AM
randomdude's Avatar
Joined Sep 2006
that makes sense. i've been out of the hobby a while, would you happen to be able to give recommendation on setup?
Old Dec 09, 2014, 01:13 PM
cmdl is online now
cmdl's Avatar
Joined Jan 2012
based on http://www.e-fliterc.com/ProdInfo/Fi...equirement.pdf and what you have written, i think you want at least 150 watts/lb. so, whatever prop+motor you choose, it will need to have the motor wattage/AUW >= 150. i don't have any information on what the AUW is for the SL, you would have that info. the AUW would of course have to include the weight of whatever motor and batt you choose (ESC and Rx weigh next to nothing relative to batt and motor). you will find a lot more expertise in http://www.rcgroups.com/power-systems-13/ able to recommend specific components. i strongly recommend you move your post there or make a new post there.
Discussion Air hogs storm launcher help needed StormLaucnher Micro Ready-to-Fly 6 Oct 07, 2014 07:04 AM
Question Jetscream and Storm Launcher same channel? What do I do about it? Cheap Flyer Micro Ready-to-Fly 4 Aug 16, 2010 11:39 AM
Sold AIRHOGS STORM LAUNCHER Twin Hydro punkindrublik Aircraft - Electric - Airplanes (FS/W) 1 Dec 04, 2006 01:39 PM
Discussion Airhogs Storm launcher Controller Ranger2692 Foamies (Kits) 2 Nov 11, 2006 08:52 AM
Discussion AirHogs Storm Launcher BD Flyer Electric Plane Talk 7 Sep 25, 2006 07:43 PM
