Old Oct 17, 2014, 05:42 AM
Paul-RC is offline
Find More Posts by Paul-RC
Let me Fly please :^)
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Build Log
HK Durafly Skymule mod
I recently got the HK Durafly skymule and decided to really modify it into a look alike Twin Otter.
The size was perfect for spare parts I had so I'm going for it.
I use a Flyzone Beaver spare wing and cut out the trailling edge to have the Flaps and ailerons .
I ordered Catalina PBY cowls from http://parkflyerplastics.com/cart/in...roducts_id=634
They are a perfect fit and look good.
I also ordered the Skymule plastic nose cone http://parkflyerplastics.com/cart/in...roducts_id=700
Also using MAS 10 x 7 x 3 props with rubber spinners that I had from other models.
I will also use the Lights from the Flyzone Beaver and others for strobe beacons.
Since I will have it on floats I will use the E-Flite 32.4 inch floats.
http://www.e-fliterc.com/Products/De...ProdID=EFLA550
So for now the mod is going well.
I will paint it to look similar to this Canadian Twin Otter
Paul-RC is offline Find More Posts by Paul-RC
Old Oct 17, 2014, 05:44 AM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Progress pictures
Here are some pictures of the progress.
Old Oct 25, 2014, 03:18 PM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Float test fit
Ok got my Apprentice 32.4 inch foam floats and test fitted on my Skymule Otter mod.
Its perfect in size and I like the looks already
Old Oct 29, 2014, 07:24 AM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Float work continues.
I took a set of the Flyzone Beaver floats and cut out the base for the struts and blended them in the new floats.
I also added a 6 ich long plywood reinforcement plate to prevent the float from braking in half.
Old Oct 29, 2014, 03:46 PM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Started on the tail section making all controls internal.
Old Oct 30, 2014, 07:14 AM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Tail controls are done and working very well.
I use the nose gear servo that is metal gear for the rudder and installed a HS82MG servo for the elevator.
I also ordered turbo prop nacelles from parkflyerplastic in case I decide to convert into a turbo prop twin.
http://parkflyerplastics.com/cart/in...roducts_id=445
Old Oct 30, 2014, 06:12 PM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Float progress coming around good.
I did use the Flyzone Beavers Struts but in different positions and had to cut a couple to adjust the hight.
Old Oct 31, 2014, 09:45 AM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Some more work today on the floats and tail subfins.
Looks like I might do it as a turbo prop even if it looks good on radial.
Old Nov 03, 2014, 08:34 AM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
LED light system install
Did my first step in my light system installation.
Tail Leds (0 min 11 sec)
Old Nov 06, 2014, 02:40 PM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Turboprop nacelles
Well I got my turboprop nacelles and did a test fit but not shure I really like the looks with them on.
They look a bit oversize for it.
I will have to really think this one out.
Old Nov 07, 2014, 09:11 AM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Ok Flaps are installed and functional and also the light system is rooted except for my belly beacon.
Skymule mod Lights Flaps (1 min 13 sec)
Old Nov 11, 2014, 04:01 PM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Here showing the servos for the flaps and for the ailerons.
Again here all controls are internal like it was on the flyzone Beaver
Old Nov 11, 2014, 07:38 PM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Wing-fences
Here are some shots of my wing fences made of plastic.
Just a groove in the top of the wing and inserted the fences, they will be secured with silicone adhesive once the plane is painted.
Old Nov 11, 2014, 08:14 PM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Flaps and aileron droop
I finally got my Flaps and Ailerons working on my Skymule Mod
Showing here my Skymule 3 position Flaps and aileron droop setup.
I use 2 switches
Position #1 Take-off flaps with aileron droop
Position #2 Flap 2 ailerons up
Switch #2 Full Flaps and ailerons still up.
Now from there I can select position #1 take-off flap on switch #1 and aileron go in a droop mode with the full flaps.
Skymule mod Flaps (1 min 0 sec)
Old Nov 12, 2014, 04:35 PM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Turboprop nacelles
I decided to go with a turboprop style nacelle so more mods to come
I use the cowling of the turboprop nacelle from parkflyers plastic and use the Skymule stock foam nacelles and I'm reshaping them using some insulating pink foam .
The spinner on the pictures is a 1 1/2 inch GWS 3 blade rubber push-on spinner.
I also ordered some dubros and I will see which style I will choose.
New Product Durafly 1500mm 'SkyMule' taz101 Foamies (Kits) 2810 Feb 06, 2016 10:23 AM
News Durafly Skymule Matt Gunn FPV Talk 16 Oct 24, 2015 09:36 AM
New Product The New Durafly SkyMule Twin! Justwingit Electric Plane Talk 142 Apr 20, 2014 01:04 PM
