Old Jun 14, 2013, 10:50 PM
BrownEyedFool is offline
Find More Posts by BrownEyedFool
You're killin' me Smalls
BrownEyedFool's Avatar
United States, NJ, Hillsborough Township
Joined Sep 2011
Lighting some foamies, turning pile of parts into beauty
Ok, I've put up some posts here in the past and am now edging back into doing some light work.
Building two night flyers, one exists, one I am trying to bang out this week.
First plane is a super EZ, two pics of the existing plane are attached, one from when I was building it, one from a crash. Huge prop in slot paper airplane, the lights will be very simple, a stripe down each wing near the edge, LEDs facing into the Dollar Tree foam. One strip down the fuse near the bottom.
Second one is a firefly, 24" ws EPP delta, some pics with lighting on them here. Will be trying to build this week.
I have lots of LEDs from Bombay, several 3s Female JST-XH balance tap pigtails, plenty of small gauge wire, even a batch of brushed ESCs pic attached.
Both nightflyers will be on 3s 1300-1800 type lipos.
I know I can use a brushed esc to hook up lights to the gear channel, but the exact configuration is eluding me. Similar with the female balance tap pigtail, I know I can run off the balance taps on the lips, do I just run the wire from the LEDs to the two outside leads on the pigtail and ignore the inside leads?
BrownEyedFool is offline Find More Posts by BrownEyedFool
Old Jun 15, 2013, 12:08 PM
Barn-E-Stormer is offline
Find More Posts by Barn-E-Stormer
Dark Yet??
Barn-E-Stormer's Avatar
United States, VA, Narrows
Joined Dec 2009
If you are using 3S batteries they attach directly to LED strip. No other devices needed unless you want to dim or flash them.
A connector that attaches to the balance tap can give you an alternate place to acquire power without cutting into the ESC wiring. Use the two outside wires on 3S, always double check with a voltmeter.
Barn-E-Stormer is offline Find More Posts by Barn-E-Stormer
Discussion Could I turn this into a strobe light? mycanopyisready Micro Helis 2 May 19, 2013 09:02 PM
Sold PILE"O 500 Parts.Mostly Aftermarket Some align New Nice Motor ESC 48 wlipo 59 blueindian Aircraft - Electric - Helis (FS/W) 2 Apr 14, 2012 09:03 AM
Discussion Turn some parts into a scream machine. skyline223 Pylon Racing 5 Nov 24, 2009 09:35 PM
Build Log turning the ultrafly foamy into edf. drakonis Foamy EDFs 25 Aug 08, 2006 11:07 PM
Turn your Curtek Pictures and Video into a chance to win a free lighting system! mcu-electric Parkflyers 0 Jun 11, 2004 06:30 PM
