Old Jun 14, 2013, 02:48 AM
billyboy is offline
Find More Posts by billyboy
los angeles,ca
Joined Jun 2001
Question
450 se v2 fbl conversion
hi, its been a couple of years since i flew my 450 se v2. i know there is a flybarless head and want to convert my 450se v2 to fbl. the fbl head i see on sale is mostly for the pro or sport. can i use that for my se v2. if so what else do i need to buy or setup. if there is a thread about the conversion that would be great. i would appreciate if you can post it. this is what i have currently on my 450 sev2. 3x hsmg65. futaba gy401. tail futaba 9257s. running on 3s 2200mah. thanks
bill
billyboy is offline Find More Posts by billyboy
Old Jun 14, 2013, 05:19 AM
rchobbyfly is offline
Find More Posts by rchobbyfly
Joined Jan 2012
Those fbl head in hobbyking and ehirobo works for SE V2. I am flying flybarless with SE V2. I have a few of Copterx SE V2 flybarless kits from ehirobo too. Use the SE V2 main shaft instead of the Pro one in your SE V2. Enjoy.
rchobbyfly is offline Find More Posts by rchobbyfly
Old Jun 14, 2013, 07:49 AM
ryane67 is offline
Find More Posts by ryane67
Can it fly? I'll try and see!
ryane67's Avatar
United States, MI, Orion Charter Township
Joined Mar 2013
you can get a tarot flybarless head + zyx controller. I've done that on my 450 sev2 with HS65mg cyclic and it flies like a dream.
ryane67 is offline Find More Posts by ryane67
Old Jun 15, 2013, 01:17 PM
whitehedr is offline
Find More Posts by whitehedr
Retired Old Guy
whitehedr's Avatar
United States, IL, New Lenox
Joined Jan 2012
I used the Align DFC head with the Robird G31 FBL controller. Servos are Align DS410m. This combo is flying VERY well for me.
You will need this main shaft for your Heli. The Pro shaft does not fit properly.
http://www.aligntrexstore.com/450DFC...XX_p_2110.html
You can find that shaft just about any where 450 parts are sold. The spacing for the lower Jesus bolt is wrong for the PRO shaft. The machined collar on the pro shaft to the Jesus bolt hole is just a little bit short and it keeps you from getting that bolt through the gear.
You can also use the RJX head with your existing main shaft. I have this head and G31 combo flying on two 450 SE V2 helis. One has Align DS415m servos and the other has Corona 929mg servos. These combos are also flying very well for me. I have a set of Tgy S306g HV servos that I am going to use on the machine with the Coronas. Not that there is anything wrong with them, but I want to try the 306 servos. The Coronas are working just fine.
ROG
whitehedr is offline Find More Posts by whitehedr
Old Jun 16, 2013, 12:45 AM
billyboy is offline
los angeles,ca
Joined Jun 2001
do i need a new gyro for fbl
Old Jun 16, 2013, 04:59 AM
TurboLeon is offline
Find More Posts by TurboLeon
Norway
Joined Jun 2011
Yes, you will need a 3 axis FBL gyro. Also, most heads for the 450 sport and Pro works fine on the V2, just need to use the V2 shafts (Sport DFC if DFC head). I have a V2 with 450 Pro flybarred head.
TurboLeon is offline Find More Posts by TurboLeon
Old Jun 18, 2013, 11:24 AM
billyboy is offline
los angeles,ca
Joined Jun 2001
just to confirm all i need is this
http://www.ebay.com/itm/New-450-Flyb...item2ec32ca137
and this
http://www.ebay.com/itm/Tarot-3-axis...item2ec143d42b
the gyro seems like a rx. is the gyro built in the receiver. thanks
bill
Old Jun 18, 2013, 07:59 PM
Switchy is offline
Find More Posts by Switchy
Zipties and Velcro
Switchy's Avatar
United States, NE, Omaha
Joined Mar 2013
Read close. That head doesnt come with the swash.
Switchy is offline Find More Posts by Switchy
Old Jun 19, 2013, 03:15 PM
fuggetaboutit is offline
Find More Posts by fuggetaboutit
United States, AL, Birmingham
Joined Jun 2012
billyboy, look at valuehobby.com. same head as you noted above and less than 30.00 and they are in the USA
fuggetaboutit is offline Find More Posts by fuggetaboutit
Old Jun 20, 2013, 07:14 PM
billyboy is offline
los angeles,ca
Joined Jun 2001
thanks, i will look into valuehobby.com
For Sale TREX 450 SE/SE V2 Parts. Double posted somehow... richord Aircraft - Electric - Helis (FS/W) 0 Jun 02, 2013 01:39 PM
Sold TREX 450 SE/SE V2 Parts. richord Aircraft - Electric - Helis (FS/W) 0 Jun 02, 2013 01:37 PM
Discussion ALZRC 450 PRO V2 3G vs Tarot 450 PRO V2 FBL hot wings Mini Helis 11 Apr 17, 2013 07:53 AM
Question Will a 450 pro flybarless head fit on my 450 SE V2? rcflyers Electric Heli Talk 9 Mar 06, 2013 03:09 AM
For Sale EXI 450 FBL (SE V2 clone) RTF!! PICS ADDED!!! Price reduced!! Sully16 Aircraft - Electric - Helis (FS/W) 3 Jul 24, 2012 12:42 AM
