Old Oct 20, 2014, 04:42 PM
softshell29 is offline
Find More Posts by softshell29
softshell29's Avatar
Joined Apr 2008
Reiher flaps flight test--REIHER BOMBER
Today I successfully flight tested 45 degree midwing landing flaps on my Reiher Bomber.
I'm not aware of a more specific Reiher thread so I'll post results and build tips here. That way the next person with a gull wing flap challenge won't have to spend so many hours searching the internet and find so little.
A bomber doesn't have spoilers and I'm used to flaps on my other warbirds and jets. I read even many sailplane purists prefer flaps to spoilers (see internet debate). So for almost 10 years I've had a plane which needs much more approach and runway to land than a normal AMA club. Things were great for a while until our club was kicked out of the full scale airport we shared due to glow engine noise.
I often thought about flaps but was told they would be fatal on a gull wing plane like the Reiher.- at least when in the mid-wing position (as opposed to the inboard dihedral position) A national authority put it in chilling words I'll never forget:
" You will immediately go into a death spiral from which there can be no recovery"
softshell29 is offline Find More Posts by softshell29
Old Oct 20, 2014, 04:52 PM
Joined Apr 2008
Gull wing flaps
Gull Wing Planes can't use outboard flaps without "a death spiral from which there can be no recovery" ?
Not true.
Today I experienced steady, stable, controlled descent with increased altitude loss rate--just as you want with flaps or spoilers. My 19 1/2 foot twin engine bomber can now be operated from a normal flying field, greatly increasing its utility and enjoyment.
I think those who have experienced the death spiral may have had no down elevator mixed in with the flaps, resulting in balooning up and tip stalling. I used 6 degrees of automatic down elevator for my low flaps (15degrees) and 8 degrees for my full flaps (45 degrees)
Old Oct 20, 2014, 05:16 PM
Joined Apr 2008
Let reiher flap mod...REIHER BOMBER...Hanna Reitsch
The Reiher Bomber is a fantasy scale project. The Germans wanted to reach New York and have at least a shot at making it back to occupied France. German pilots balked at outright suicide missions.Before aerial refueling, this indicated a bomber which could fly a large part of each mission with zero fuel consumption. So they took the most advanced sailplane of the day, blew it up 300% for a crew of 6 and added 2 of the new turboprops. Search the internet and you'll find almost nothing on the Reiher Bomber Project...... except pictures of Hitler's favorite pilot , Hanna Reitsch, testing Reihers. Why would a rocket pilot waste time on gliders?
She wasn't wasting time.
So the Reiher Bomber has exactly the planform of a Reiher sailplane. Flaps should work identically on Reiher sailplanes. Mine is a modification of the LET Reiher. Here's what I did to modify the inboard ailerons into flaps with great sweep, power and rigidity:
1. Re hinged the inboard ailerons at the bottom, and doubled the servo power.
2. Stripped off the cloth covering and replaced it with 1/64 ply--both sides.
3. Broadened the control horn power distribution across multiple ribs using carbon rods and lite ply rib doublers.
4.Closed all gaps--top and bottom --with flex strips used on full scale sailplanes.
Old Oct 25, 2014, 12:14 PM
Joined Apr 2008
Gull wing flaps--Reiher Bomber video
These videos demonstrate use of 45 degree flaps for landing and zero flaps for takeoff--all in 8 mph crosswind. You can also see parachute return of the wheels after takeoff.
Despite some similar sounds on takeoff, this Reiher Bomber model has no sound system imitating the turbines on the Full Scale Reiher Bomber. This is a very old model. I used some of the earliest brushless motors--made in Germany. They are only Speed 600 size so had to modify them to power a 19 1/2 foot Bomber. This is how they actually sound, recorded by a cellphone camera. try it at full volume.
Take off (0 min 19 sec)
Landing (0 min 28 sec)
Old Apr 09, 2015, 06:18 PM
BStaley is offline
Find More Posts by BStaley
BStaley's Avatar
Casselberry, FL
Joined Mar 2007
More progress....
I made some progress with the parts and got to the painting stage when things slowed down because of the weather. We had a dreary, gray, windy, wet kind of winter not conducive to painting outside. I'm really not complaining because we didn't have to deal with 10' of snow! But Spring is here and all is well. I got the last white color coat done on the fuse today. After it dries I'll put the red band on the fin/rudder. All other parts are painted w/color and clear. I got my decals done by Callie Graphics and she did a great job. The canopy has been covered also. So after the painting it will be a matter of putting it all together and seeing how everything looks,and then some pics and flying!
BStaley is offline Find More Posts by BStaley
Old Apr 10, 2015, 04:27 PM
raed5 is offline
Find More Posts by raed5
raed5's Avatar
Orlando "Buzzards" FL
Joined May 2002
Nice work Bill! Would love to see it at the flying field!
Raed
raed5 is offline Find More Posts by raed5
Old Apr 14, 2015, 04:00 AM
BStaley is offline
BStaley's Avatar
Casselberry, FL
Joined Mar 2007
Got some more done. The ailerons are on, servos are in and hooked up along with the spoiler servo. I painted the red band on the fin/rudder. The elevator is hinged to the stab and servo is on. I need to clear coat the fuse and after that hook up the pull-pull for the rudder and get the tow release servo in. Then it time to put it together, get the decals on, balance and fly. Yea! I think I see the light at the end of the tunnel.
Old May 11, 2015, 05:43 PM
BStaley is offline
BStaley's Avatar
Casselberry, FL
Joined Mar 2007
Done!!!
Well I'm finally done . It took 2 1/2 yrs. It was quite a bit more of a challenge than I expected. I got the graphics from Callie Graphics-she did a great job. I was surprised how much lead it took to balance it-5 lbs!!! The model has a short nose and all the wood added up to a lot of weight in the tail. But it has a lot of wing area. We flew it Saturday. It actually floats and thermals well.
Bill
Old May 11, 2015, 07:39 PM
raed5 is offline
raed5's Avatar
Joined May 2002
Very nice Bill
Raed
Old May 12, 2015, 06:09 AM
ARUP is offline
Find More Posts by ARUP
Joined Mar 2010
Very nice! I'm a big vintage scale sailplane fan.
ARUP is offline Find More Posts by ARUP
Old May 16, 2015, 08:39 PM
Joined Apr 2008
Wow. You gotta be proud of that. Looks like an all composite fiberglass ship.
Major building skill.
Old May 17, 2015, 07:51 AM
mtbrider is offline
Find More Posts by mtbrider
Ay up it's warped
mtbrider's Avatar
Derbyshire UK
Joined Feb 2003
That looks stunning, well worth the build.
mtbrider is offline Find More Posts by mtbrider
Sourcing for a 1/6 DFS Reiher Short Kit? dougchambers Scale Sailplanes 19 Feb 10, 2003 09:28 PM
