Old Aug 12, 2012, 10:11 AM
mkcp40 is offline
Find More Posts by mkcp40
mkcp40's Avatar
United States, MD, Potomac
Joined Oct 2010
Spitfire Dilemma
I'm in a little bit of a dilemma here. I love my Parkzone Spitfire MkIX, but finding a field to fly it as is rather annoying. The local park's grass is far too long for the Spitfire to do a wheeled takeoff or landing. My school's grass is the same deal, but I occasionally take off and land from the track when there aren't people around (that's rare). The nearest field that has grass short enough for my PZ Spitfire is a 40 minute drive away, which is difficult to do often.
So the question is, should I go up in size or just downsize to a belly lander? I've seen the FMS mini Spitfire and the Art-Tech Spitfire, and I also recently bought plans for a 27inch balsa Spitfire. These would all offer small-space friendly Spitfires, but I'd prefer to do wheeled takeoffs and landings.
Is there a larger foam Spitfire out there that will handle your average soccer field/park grass without complaints? (Preferably with split flaps and retracts) I took a look at the 1400mm FMS Spitfire and I'm too much of a scale snob to buy one.
mkcp40 is offline Find More Posts by mkcp40
Old Aug 12, 2012, 12:18 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
How about wet grass, (or even dry grass. I fly my Sunderland off grass) -
eflightray is offline Find More Posts by eflightray
Old Aug 12, 2012, 12:24 PM
BrentP is offline
Find More Posts by BrentP
Closed Account
Joined Apr 2008
instead of buying another plane like a smaller belly lander why not just fly you spit as a hand launch / belly lander. Should be good to go just remove the LG.
BrentP is offline Find More Posts by BrentP
Old Aug 12, 2012, 12:33 PM
Redhood is offline
Find More Posts by Redhood
Redhood's Avatar
United States, MN, Odin
Joined Aug 2010
I had the same issues with my PZ P-47. I ended up getting a second one and I removed the landing gear and it's plastic mounts. Also I took out the rudder servo and tail wheel. It ended up shedding 200 grams. It hand launches great and belly lands fine. I think it would be the same for your Spitfire.
http://www.rcgroups.com/forums/showp...ostcount=10534
Redhood is offline Find More Posts by Redhood
Old Aug 12, 2012, 12:57 PM
mkcp40 is offline
mkcp40's Avatar
Joined Oct 2010
I can currently belly land my PZ Spit, I just don't like it as every couple landings something works loose on the underside.
I also prefer wheel landings. More scale.
Old Aug 12, 2012, 02:31 PM
GiusedtoBe is offline
Find More Posts by GiusedtoBe
GiusedtoBe's Avatar
Tennessee
Joined Apr 2009
The FMS Spit does have its share of scale flaws but its not too hard to modify it to a more scale appearance. Mine is in the rebuild que where I plane to add split flaps and give it proper dihedral. Beyond that the gear placement is the only egregious thing I can think of and i can live with that. TO/landings are easy on short grass fields.
Alan
GiusedtoBe is offline Find More Posts by GiusedtoBe
Discussion Dilemma-To Fly or Not in Stinson Reliant E-Challenged Scale Kit/Scratch Built 25 Aug 04, 2012 12:19 AM
Discussion FPV DVR- The Dilemma Lpbug FPV Talk 17 Jul 02, 2012 05:25 AM
Discussion Purchase dilemma 52Sabre Electric Warbirds 24 Jun 30, 2012 03:14 PM
Discussion Engine mount dilemma DYORD Engines 9 May 29, 2012 02:12 PM
Discussion Password Dilemma!!! MATIN Site Chat 22 Apr 06, 2012 01:59 AM
