Old May 10, 2014, 01:12 PM
feefo is offline
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
Originally Posted by Wing-span View Post
JDMiller, where did you get your Hawk from?
I can't help you with the 4 flapped version, at least not in Europe to avoid possible import costs, but the 2 servo wing is available from here with free shipping to the UK http://shop.lindinger.at/product_inf...ducts_id=72487
and here (but out of stock) http://www.modellhobby.de/Models/Mod...=20973&p=20973
and the horribly coloured V2 here http://www.modellhobby.de/Models/Mod...=20973&p=20973 also with free shipping.
feefo is offline Find More Posts by feefo
Old May 21, 2014, 06:21 PM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Testing the Hawk F5B
Guess what...?? There's a new, lighter and smaller "Cheapo" in town. Have flown it with my X-plane a few times, and it's great! Too small prop for the Hawk, but for the F5D size planes it's kicking butt bit still gives 40sec motor time on a 4S2200.
X-plane Onboard HD wide (5 min 14 sec)
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Aug 18, 2014, 10:38 PM
JDMiller is offline
Find More Posts by JDMiller
Joined Jan 2005
I finally got around to trying my Hawk out on 5s. I managed to squeeze a TP 2700Mah 5s into it although it's a pretty tight fit. The extra cell sure makes a difference in power and speed.
F5B Hawk Hotliner 5s 3000W Flight 1 (4 min 38 sec)
JDMiller is offline Find More Posts by JDMiller
Old Aug 19, 2014, 02:51 AM
Arcteryxxx's Avatar
Joined Feb 2010
Nice flying!
Your video really shows the performance of the Cheapo drive
Old Aug 21, 2014, 04:45 PM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
JDMiller, very nice video and good flying, she really moves on fast and tracks nice.
I see you have the YEP 150A esc, did you do the mod ? to keep it safe..
What is you CG @? And does the break on the YEP esc work ok?
Sebbe
sebbe is offline Find More Posts by sebbe
Old Aug 24, 2014, 10:04 PM
57sailplane is offline
Find More Posts by 57sailplane
57sailplane's Avatar
United States, NE, Hebron
Joined Nov 2008
Sebbe
i have a yep 150a esc and am wondering what mod you are talking about?
thanks andrew k.
57sailplane is offline Find More Posts by 57sailplane
Old Aug 25, 2014, 04:09 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
thanks andrew k.
This one:
http://www.rcgroups.com/forums/showthread.php?t=2136643
Old Aug 25, 2014, 05:29 AM
blitzu is offline
Find More Posts by blitzu
The Prop is Where its At!
blitzu's Avatar
New Zealand, Bay Of Plenty, Omokoroa
Joined Dec 2012
Geez I'm getting worried with all this YEP 150A talk... (I have x2 sitting here)...seriously thinking of throwing them out and saving up for a couple of ice lite 200A esc's....surely they're hold up to 120-160A flying....
blitzu is offline Find More Posts by blitzu
Old Aug 25, 2014, 06:23 AM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
I looked at the YEP 150a, read the mod thread and then thought stuff it and got a re-flashed Red Brick 200a off Joe http://www.rcgroups.com/forums/showthread.php?t=2039518
Old Aug 25, 2014, 07:12 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
blitzu, YEP 150A after the mod tested by at least 3 of us, cool and running nice even at Higher amps, as long as you do the mod there should not be any problems more then other esc:s...
Old Aug 25, 2014, 07:14 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Should be interesting to hear what JDMiller is saying about his YEP 150.....
Old Aug 25, 2014, 03:13 PM
blitzu is offline
blitzu's Avatar
Joined Dec 2012
Ok cheers Sebbe
I take it you use the 750uf caps?
Same as whats in it already, but they're Panasonic fm caps...
I read your thread on the mods too.Excellent clear instructions-thankyou
Old Aug 25, 2014, 03:30 PM
Joined Nov 2008
i read the mod, sebbe
how did you determine which size cap to use. also why double up on the wires on the motor side. thanks for the help andrew k
Old Aug 26, 2014, 05:38 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Caps size dont matter * ,
* use FM caps from panasonic, and you have the best to keep the ripple down, they are so low in ESR value so dont matter even if you use one instead of 4 cheap ones..
Bigger better, but down overdo it ,,, I would say at least 470uF x 2, thats what original,, but better is to go even bigger or more caps...
also choose the higher voltage series, I think it was 50V ones I used..
57sailplane, the wires extra is for keeping the distrubition of current equal on both boards(fets) of the esc, otherwise one side will get hotter, not good at all.. You dont have to run full length wires, you can make an Y-connection 1 inch after, this way the current will split 50/50 anyway...
Also do the cable mod on both battery side AND motor side, this way you get more even flow...
With this mods the esc run much cooler, keep up guys...
Sebbe
Old Aug 29, 2014, 07:58 PM
SLCPilot is offline
Find More Posts by SLCPilot
Stillwater, Oklahoma
Joined May 2004
I have a Hawk copy, the Inertia from HK. Even though it only puts out 2200w on 5s, it's a hoot, and has been very reliable!
That being said, I have stripped out the threads that hold on the horizontal stab. Is there a good source for threaded inserts, and can anybody tell me what size they are? I suspect they are 3mm or 3.5 mm.
Thanks in advance,
SLCPilot
SLCPilot is offline Find More Posts by SLCPilot
Discussion blog: Open source firmware ESC for F5B Ron van Sommeren DIY Electronics 0 Jun 15, 2012 12:36 PM
Discussion Motor, ESC, propeller recommendations for Hawk F5B/Wilco skybattle High Performance 32 Mar 29, 2012 07:21 AM
Discussion Icare Mini-Hawk F5B Bob.R High Performance 8 Oct 14, 2011 10:18 PM
Discussion Hawk F5B motor suggestion JaRaMW High Performance 2 Aug 17, 2010 04:42 PM
Discussion Hawk F5B yaitsfast Electric Sailplanes 2 Jan 27, 2010 09:14 AM
