Old May 02, 2012, 11:36 AM
dougbthom is offline
Find More Posts by dougbthom
Joined Jan 2012
Park Zone Radian Plug and Play
Being brand new to the RC world (2 months) I am looking for some advice please. I recently purchased a Radian plug and play plane and had it out once for two disasterous flights. It took off like a dream and then all hell broke loose. I had very little control (it was overreacting) and hit the ground twice thankfully with very little damage. My learning experience witha good trainer was with an Easy Star which I feel I flew quite well. I fly this Radian with a Hitec Aurora 9 Radio and after looking at the radio settings which were at 100 % settings under the heading T Limit for the rudder and the same under the elevator settings. Should these settings be less such as around 60 % ? Any suggestions you can offer is appreciated.
dougbthom is offline Find More Posts by dougbthom
Old May 02, 2012, 11:56 AM
prefabu is online now
Find More Posts by prefabu
Kansas City
Joined Dec 2009
The T Limit is where you set the max throws for the servos after channel mixing. Since multiple inputs can be mixed together onto one output channel, you can exceed 100% throw even if the individual inputs are less than 100%. Elevon mixing is a very common example.
Even if you want to do some rudder to elevator mixing, you can still leave the T Limit at 100%. Just use the dual rate/expo screen to control your surface movements. Doesn't the Radian manual provide recommended control surface movement?
Keep in mind that the Radian wants to climb *steeply* under full power. It will sometimes do a loop if you don't give a little down elevator.
prefabu is online now Find More Posts by prefabu
Old May 02, 2012, 12:51 PM
paxfish is offline
Find More Posts by paxfish
United States, MD
Joined Jan 2012
How did your glide test go?
Try this: Get it trimmed out and gliding nicely to start with. Once you are comfortable there, face into the wind, and launch with a bit over 1/2 throttle with the nose angled up just a bit. Get stable, give it a bit more power, keeping the nose no more than 45 degrees to vertical. Get it up around 200 feet, kill the motor, and get your glide stable. Trim if need be.
SMALL inputs on the sticks, Bud. To turn, just tap the rudder slightly. It'll lean over into the turn and the nose will drop slightly. It'll start to trun, then level out. Tap again to continue your turn.
To land, start way down wind without power, and let it descend on it's own. Into the wind, it's moving very slowly. Don't nose into the turf, but don't stall either.
paxfish is offline Find More Posts by paxfish
Old May 02, 2012, 01:05 PM
Joined Jan 2012
Radian
Thanks for the replies and the good advice. I'll take it. I have a feeling that most of the problem I had was with the radio settings being way too high. I'm going to lower the rudder setting to 60% and the elevator to 70% and try that and see how that goes.
Old May 02, 2012, 02:30 PM
Kansas City
Joined Dec 2009
Just make sure you do that adjustment on the dual rate screen (D/R EXP), not the T Limit screen. Making changes on the T Limit screen will control the max throws, but will not change the sensitivity of the controls. Lowering the % on the D/R EXP screen will make the model easier to control.
Sold Parkzone Radian plug and play 1987tc Aircraft - Sailplanes (FS/W) 4 Aug 11, 2010 07:56 PM
Sold ***ParkZone Radian Plug & Play*** Just flyy Aircraft - Sailplanes (FS/W) 1 May 18, 2010 09:58 AM
Discussion Park Zone Radian Charles Hough Foamies (Kits) 2 Mar 13, 2009 10:37 AM
Discussion "Holy Floater Batman!!!" Maiden flight of my Park Zone Radian QuietRiot Electric Sailplanes 13 Dec 18, 2008 11:38 PM
